pas la bonne info en fonction du clic
bonjour, je vient de recevoir 2 boutons acheter sur aliexpress (TSF004) et lorsque je :
clic 1 fois sur le bouton cela me donne comme info (Boutons Bureau Toggle event was fired)
clic longtemps (Boutons Bureau Remote Button Double Press - Button event was fired)
double clic (Boutons Bureau Remote Button Short Press - Button event was fired)
| version | core-2025.3.3 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.13.2 |
| os_name | Linux |
| os_version | 6.12.18-haos |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 1601 |
| Downloaded Repositories | 12 |
| update_channel | stable |
| supervisor_version | supervisor-2025.03.3 |
| agent_version | 1.7.2 |
| docker_version | 28.0.1 |
| disk_total | 123.3 GB |
| disk_used | 5.8 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | kvm |
| board | generic-aarch64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Get HACS (1.3.1), File editor (5.8.0), Z-Wave JS (0.10.0), Matter Server (7.0.0) |
Quelqu’un aurait une idée de comment faire pour que chaque clic corresponde bien ce que je fait ?
je suis sous ZHA.
