Calcul des heures creuses/pleines via Utility_meter et script automation
A la main :wink: sinon ce n’est pas drôle.
En fait j’essaye d’apprendre et je n’aime pas trop les UI.
Tu peu faire en yaml mais par le UI.
Tout pareil :frowning:
Logger: homeassistant.components.automation
Source: components/automation/config.py:207
Integration: Automatisation (documentation, issues)
First occurred: 10:46:23 (1 occurrences)
Last logged: 10:46:23
Unnamed automation could not be validated and has been disabled: extra keys not allowed @ data['automation']. Got [{'id': 'tarifhphc', 'alias': 'tarifelec', 'trigger': [{'platform': 'time', 'at': '07:00:00', 'variables': {'tariff': 'peak'}}, {'platform': 'time', 'at': '23:00:00', 'variables': {'tariff': 'offpeak'}}], 'condition': [], 'action': [{'service': 'select.select_option', 'target': {'entity_id': 'select.energie_quotidienne'}, 'data': {'option': '{{ tariff }}'}}, {'service': 'select.select_option', 'target': {'entity_id': 'select.energie_hebdomadaire'}, 'data': {'option': '{{ tariff }}'}}, {'servi... required key not provided @ data['action']. Got None required key not provided @ data['trigger']. Got None
Je vais essayer avec l’UI
ta essayé de supprimer la condition sur les jours ???
exemple pour une automation ,
par automations.yaml:
- id: '1634540099944'
  alias: Quitter Zone Maison / Activation Alarme
  description: ''
  - platform: device
    device_id: 8f275328e566032a5eda5808b34ddc99
    domain: device_tracker
    entity_id: device_tracker.m2101k9g
    type: leaves
    zone: zone.home
  - platform: zone
    entity_id: person.warcozes
    zone: zone.home
    event: leave
  - platform: state
    entity_id:
    - device_tracker.pc_95
    to: not_home
  - platform: geo_location
    source: device_tracker.warcozes_mi11lite5g
    zone: zone.home
    event: leave
  condition:
  - condition: device
    device_id: b9253bcaf37d89932619b9092f6a5f38
    domain: alarm_control_panel
    entity_id: alarm_control_panel.alarmo
    type: is_disarmed
  - device_id: b9253bcaf37d89932619b9092f6a5f38
    type: arm_away
Par le UI:
description: ""
  - platform: device
    type: leaves
    zone: zone.home
  - platform: zone
    zone: zone.home
    event: leave
  - platform: state
    entity_id:
    to: not_home
    zone: zone.home
    event: leave
condition:
  - condition: device
    type: is_disarmed
    type: arm_away
  - service: notify.mobile_app_m2101k9g
      message: TTS
        ttl: 0
        priority: high
        media_stream: alarm_stream_max
        tts_text: Alarme maison activée!
L’indexion est différence, ta pas d’espace sous trigger, condition et action sous automations.yaml contrairement par le UI.
Dans ton automation.yaml faut enlever les espaces sous action.
Alors, je n’arrive pas à faire par l’UI!
J’ai une erreur : response error: 500 au moment d’enregistrer
Regarde dans les logs de HA, après l’erreur.
Logger: aiohttp.server
Source: components/config/automation.py:70
First occurred: 10:55:56 (6 occurrences)
Last logged: 10:58:46
Error handling request
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/config/__init__.py", line 148, in post
    self._write_value(hass, current, config_key, data)
  File "/usr/src/homeassistant/homeassistant/components/config/automation.py", line 70, in _write_value
    cur_value[CONF_ID] = uuid.uuid4().hex
TypeError: 'str' object does not support item assignment
Tu peu simplifier l’action, en mettant toute les entitées select dans une seul action.
    - service: select.select_option
        entity_id:
          - select.energie_quotidienne
          - select.energie_hebdomadaire
          - select.energie_mensuelle
          - select.energie_annuelle
        option: "{{ tariff }}"
Je viens de le modifier, mais j’avais déjà écrit comme ça. Comme ça ne marchait pas, j’avais essayé autrement. :wink:
Salut à tous,
J’ai trouvé la solution à mon problème.
Après des heures de recherche, je suis tombé sur ce post
J’ai remplacé dans configuration.yaml :
automation: !include_dir_merge_list automations
Et je n’ai plus d’erreur. Je n’ai plus qu’a savoir si cela va changer de paramètre ce soir :wink:
Merci pour votre aide qui m’a bien aidé à avancer dans mes recherches.
FaB
bonjour,
du coup, peux tu redonner l’ensemble de ton code stp ?
