La concaténation et l’accès aux variables du contexte flow ça ne marche pas comme ça dans jsonata.
Si tu affiches {"start_date_time":flow.journee,"duration":"23:59:00"}
dans un noeud debug, ça ne va pas avoir le format voulu.
Ou veux tu configurer la date de début, de fin et les heures ?
J’aurais tendance à faire ça avec un input_date :
[{"id":"44b4b6fdef012dbb","type":"api-current-state","z":"f889cf0b770cdb33","name":"","server":"d28c9492.f419c8","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_datetime.mydate","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":5160,"wires":[["a3e6ef3422433082"]]},{"id":"eec091af6d02f319","type":"inject","z":"f889cf0b770cdb33","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":5160,"wires":[["44b4b6fdef012dbb"]]},{"id":"33185c97d9624530","type":"debug","z":"f889cf0b770cdb33","name":"debug 135","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":990,"y":5160,"wires":[]},{"id":"a3e6ef3422433082","type":"api-call-service","z":"f889cf0b770cdb33","name":"","server":"d28c9492.f419c8","version":5,"debugenabled":false,"domain":"calendar","service":"get_events","areaId":[],"deviceId":[],"entityId":["calendar.chauffage"],"data":"{\t \"start_date_time\": payload,\t \"end_date_time\":\"2024-07-01 22:00:00\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"results"}],"queue":"none","x":740,"y":5160,"wires":[["33185c97d9624530"]]},{"id":"d28c9492.f419c8","type":"server","name":"hassio","version":5,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
