Changement de l'adresse serveur mosquitto Z2mqtt
bonsoir
j’ai besoin d’un coup de main sur le changement d’adresse ip de mon serveur mosquitto
ancienne adresse de mon serveur : mqtt://mosquitto-core:1883
noucelle adresse du serveur : mqtt://192.168.31.3:1883
meme user , meme mot de passe pour le nouveau serveur
ma configuration Z2Mqtt
mqtt:
  # Required: MQTT server URL (use mqtts:// for SSL/TLS connection)
  server: 'mqtt://192.168.31.3:1883'
  # Optional: MQTT base topic for Zigbee2MQTT MQTT messages (default: zigbee2mqtt)
  base_topic: zigbee2mqtt
  # Optional: absolute path to SSL/TLS certificate of CA used to sign server and client certificates (default: nothing)
  #ca: '/etc/ssl/mqtt-ca.crt'
  # Optional: absolute paths to SSL/TLS key and certificate for client-authentication (default: nothing)
  #key: '/etc/ssl/mqtt-client.key'
  #cert: '/etc/ssl/mqtt-client.crt'
  # Optional: MQTT server authentication user (default: nothing)
  user: ********
  # Optional: MQTT server authentication password (default: nothing)
  password: ********
  # Optional: MQTT client ID (default: nothing)
  client_id: 'Z2Mqtt'
  # Optional: disable self-signed SSL certificates (default: true)
  reject_unauthorized: true
  # Optional: Include device information to mqtt messages (default: false)
  include_device_information: true
  # Optional: MQTT keepalive in seconds (default: 60)
  keepalive: 60
  # Optional: MQTT protocol version (default: 4), set this to 5 if you
  # use the 'retention' device specific configuration
  version: 4
  # Optional: Disable retain for all send messages. ONLY enable if you MQTT broker doesn't
  # support retained message (e.g. AWS IoT core, Azure IoT Hub, Google Cloud IoT core, IBM Watson IoT Platform).
  # Enabling will break the Home Assistant integration. (default: false)
  #force_disable_retain: false
mais lors du demarrage , la nouvelle adresse est ignorée et l’adresse mosquitto-core est utilisée
(meme apres reboot etc etc )
pour info le fichier de configuration est bien lu car j’ai changé le client_id: ‹ Z2Mqtt › et celui ci change
si quelqu’un a une idée …
bon j’ai externalisé mon z2mqtt dans un docker , tous fonctionne ,avec le meme fichier de config …
bug de l’extension ?
bref je m’en suis sorti autrement :slight_smile:
