Clavier Keypad 4x3 ouverture portail
Bonsoir,
J’aimerai adapter ce code trouvé sur internet, mais avec Esphome.
 * This ESP32 code is created by esp32io.com
 * This ESP32 code is released in the public domain
 * For more detail (instruction and wiring diagram), visit https://esp32io.com/tutorials/esp32-door-lock-system-using-password
#include <Keypad.h>
#define RELAY_PIN   19 // ESP32 pin GPIO19 connected to the relay
#define ROW_NUM     4  // keypad four rows
#define COLUMN_NUM  3  // keypad three columns
char keys[ROW_NUM][COLUMN_NUM] = {
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
byte pin_rows[ROW_NUM] = {12, 14, 27, 26};   // ESP32 pin: GPIO12, GPIO14, GPIO27, GPIO26 connected to the row pins
byte pin_column[COLUMN_NUM] = {25, 33, 32};  // ESP32 pin: GPIO25, GPIO33, GPIO32 connected to the column pins
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
const String password_1 = "1234"; // change your password here
const String password_2 = "4444";  // change your password here
const String password_3 = "55555";  // change your password here
String input_password;
void setup() {
  Serial.begin(9600);
  input_password.reserve(32); // maximum input characters is 32
  pinMode(RELAY_PIN, OUTPUT);
  digitalWrite(RELAY_PIN, HIGH); // lock the door
void loop() {
  char key = keypad.getKey();
  if (key) {
    Serial.println(key);
    if (key == '*') {
      input_password = ""; // reset the input password
    } else if (key == '#') {
      if (input_password == password_1 || input_password == password_2 || input_password == password_3) {
        Serial.println("Valid Password => unlock the door");
        digitalWrite(RELAY_PIN, LOW);  // unlock the door for 20 seconds
        delay(20000);
      } else {
        Serial.println("Invalid Password => Try again");
    } else {
      input_password += key; // append new character to input password string
#include <LiquidCrystal_I2C.h>
#include <Keypad.h>
  {'1', '2', '3'},
  {'4', '5', '6'},
  {'7', '8', '9'},
  {'*', '0', '#'}
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27 (from DIYables LCD), 16 column and 2 rows
void setup() {
  Serial.begin(9600);
  lcd.init();                    // initialize the lcd
  lcd.backlight();
void loop() {
  if (key) {
    if (key == '*') {
      lcd.clear();
      lcd.clear();
        lcd.setCursor(0, 0);
        lcd.print("CORRECT!");
        lcd.setCursor(0, 1);
        lcd.print("DOOR UNLOCKED!");
        delay(20000);
      } else {
        lcd.print("INCORRECT!");
        lcd.print("ACCESS DENIED!");
    } else {
      if (input_password.length() == 0) {
        lcd.clear();
      lcd.setCursor(input_password.length(), 0); // move cursor to new position
      lcd.print('*');                 // print * key as hiden character
Est ce que certains d’entre vous on déjà fait ça?
Merci et bonne soirée.
