mon système fonctionne depuis plusieurs année, suite à la nouvelle mise à jour du module Zigbee2Mqtt
je n’ai plus accès à ce module,
avec ce message d’erreur,
[20:27:18] INFO: Preparing to start…
[20:27:18] INFO: Socat not enabled
[20:27:19] INFO: Starting Zigbee2MQTT…
[2025-05-05 20:27:22] debug: z2m: Removing old log directory ‹ /config/zigbee2mqtt/log/2025-05-05.19-04-16 ›
[2025-05-05 20:27:22] info: z2m: Logging to console, file (filename: log.log)
[2025-05-05 20:27:22] debug: z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2025-05-05 20:27:22] info: z2m: Starting Zigbee2MQTT version 2.3.0 (commit #unknown)
[2025-05-05 20:27:22] info: z2m: Starting zigbee-herdsman (4.0.0)
[2025-05-05 20:27:22] debug: z2m: Using zigbee-herdsman with settings: ‹ « {"network":{"panID":22594,"extendedPanID":[92,22,230,170,44,114,117,92,11],"channelList":[11],"networkKey":"HIDDEN"},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json","serialPort":{"baudRate":115200,"path":"/dev/ttyUSB0","adapter":"zstack"},"adapter":{"disableLED":false}} » ›
[2025-05-05 20:27:22] error: z2m: Error while starting zigbee-herdsman
[2025-05-05 20:27:22] error: z2m: Failed to start zigbee-herdsman
[2025-05-05 20:27:22] error: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-05-05 20:27:22] error: z2m: Exiting…
[2025-05-05 20:27:22] error: z2m: Error: ExtendedPanID must be an 8 digits long array, got 92,22,230,170,44,114,117,92,11.
at new Controller (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:112:19)
at Zigbee.start (/app/lib/zigbee.ts:69:29)
at Controller.start (/app/lib/controller.ts:104:13)
at start (/app/index.js:149:5)
j’ai donc tenté
d’ajouter adapter: zstack
et différents adapter
un mise à jour du firmware de la clé vers
CC1352P2_CC2652P_launchpad_coordinator_20211114
en lisant que cette version était stable, ma clé était d’origine, avec texas instrument, et avec Putty j’avais toujours des erreurs, avec sonoff directement sur le site ça semble passer mais je ne vois pas comment verifier, car je n’ai plus accès à Z2M, j’ai essayé également d’autres coordinator pour puce 2652
en remettant ma clé sur le raspberry j’ai toujours les memes erreurs
désolé c’est un énième sujet sur le meme problème, mais ne trouvant pas de solution je me permet de poser la question
version
core-2025.4.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.13.2
os_name
Linux
os_version
6.6.74-haos-raspi
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
5000
Installed Version
2.0.5
Stage
running
Available Repositories
1699
Downloaded Repositories
5
logged_in
true
subscription_expiration
1 janvier 2018 à 01:00
relayer_connected
false
relayer_region
null
remote_enabled
false
remote_connected
false
alexa_enabled
true
google_enabled
true
cloud_ice_servers_enabled
true
remote_server
null
certificate_status
null
instance_id
acecd9d873f44bab86981c0a1c67f1a2
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 15.2
update_channel
stable
supervisor_version
supervisor-2025.04.1
agent_version
1.7.2
docker_version
28.0.4
disk_total
109.3 GB
disk_used
10.6 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Spotify Connect (0.14.0), File editor (5.8.0), Samba share (12.5.1), Terminal & SSH (9.17.0), ESPHome Device Builder (2025.4.1), Mosquitto broker (6.5.0), Duck DNS (1.19.0), Matter Server (7.0.0), Google Assistant SDK (2.5.0), Studio Code Server (5.19.2), Zigbee2MQTT (2.3.0-1)
j’avais oublié j’ai aussi essayé de revenir a des version précedente de Z2M
en enlever le dernier (11) il me disait qu’il y avait 2 digit identiques j’ai donc enlevé le 92 qui y était effectivement deux fois, je ne sais meme pas ce que je suis en train de toucher
depuis il tourne debug mais fini par
[2025-05-05 21:28:34] error: z2m: Error: network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby (Error: AREQ - ZDO - stateChangeInd after 60000ms
at Object.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/utils/waitress.ts:67:23)
at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:362:31)
at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:91:21)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:154:16)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
at Zigbee.start (/app/lib/zigbee.ts:70:27)
at start (/app/index.js:149:5))
at ZnpAdapterManager.beginCommissioning (/app/node_modules/.pnpm/zigbee-herdsman@4.0.0/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:364:23)
Tu peux avoir plusieurs fois, ma même valeur, c’est pas un souci, ce qu’il faut c’es 8 valeurs séparées par une virgule.
Accessoirement, et non des moindre, c’est la clé secrète de ton réseau zigbee, celle qui permet aux appareils de dialoguer entre eux. Donc c’est pas une bonne idée de trop bidouiller… Tu avais quoi comme valeur avant ? Tu es certain de ne pas y avoir touché ?
c’est ce que je regardais, si j’avais des valeurs identique avant, et effectivement j’avais deux fois 92 et pas le 11 dans mon fichier configuration backup du mois de janvier, je vais essayer de remettre à l’identique,
ext_pan_id:
- 22
- 92
- 230
- 170
- 44
- 114
- 117
- 92
merci pour l’explication, et oui pour ca j’aime bien bidouiller mais de là à toucher tout et n’importe quoi… je me doute que c’est pas forcement une bonne idée
et oui je suis certain de ne pas être aller dans ce fichier.
ca refonctionne Bon ok un peu bébête, j’avais pas penser à ce fichier Backup dans file editor,
faut vraiment que je me mette à ce fichu .yaml
merci beaucoup pour ton explication, de m’avoir orienté et réglé mon soucis
merci merci
