J’ai un input select qui determine une valeur d’humidité cible, j’y soustrais 2 et additionne 2 afin de borner l’hysteresie de travail; je veux donc comparer l’humidité d’une pièce avec cible+2 et cible-2 pour allumer ou eteindre l’humidificateur.
[{"id":"065a679317c74b4c","type":"calculator","z":"eb04ae37.a0f68","name":"","inputMsgField":"payload","outputMsgField":"payload","operation":"sum","constant":"2","round":false,"decimals":0,"x":610,"y":360,"wires":[["1c733fd7c024a5d1"]]},{"id":"58865237a311e788","type":"trigger-state","z":"eb04ae37.a0f68","name":"Humidité <= cible-2 ?","server":"f2e51979.838dd8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.temperature_dependance","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":"<=","comparatorValueDatatype":"str","comparatorValue":"payload"}],"inputs":1,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"num","enableInput":true,"x":800,"y":440,"wires":[["e40c6dbad76b3dc0"],[]]},{"id":"e695d42c90af635c","type":"calculator","z":"eb04ae37.a0f68","name":"","inputMsgField":"payload","outputMsgField":"payload","operation":"sub","constant":"2","round":false,"decimals":0,"x":620,"y":440,"wires":[["58865237a311e788"]]},{"id":"47049b013160fc9e","type":"server-state-changed","z":"eb04ae37.a0f68","name":"Humidité cible (input.select)","server":"f2e51979.838dd8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.humidite_cible","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":360,"y":400,"wires":[["e695d42c90af635c","065a679317c74b4c"]]},{"id":"1c733fd7c024a5d1","type":"trigger-state","z":"eb04ae37.a0f68","name":"Humidité > cible+2 ?","server":"f2e51979.838dd8","version":2,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.temperature_dependance","entityidfiltertype":"exact","debugenabled":false,"constraints":[{"targetType":"this_entity","targetValue":"","propertyType":"current_state","propertyValue":"new_state.state","comparatorType":">","comparatorValueDatatype":"str","comparatorValue":"payload"}],"inputs":1,"outputs":2,"customoutputs":[],"outputinitially":false,"state_type":"num","enableInput":true,"x":790,"y":360,"wires":[["8455affe041d2f34"],[]]},{"id":"e40c6dbad76b3dc0","type":"api-call-service","z":"eb04ae37.a0f68","name":"Humidificateur On","server":"f2e51979.838dd8","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.humidificateur"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1010,"y":440,"wires":[[]]},{"id":"8455affe041d2f34","type":"api-call-service","z":"eb04ae37.a0f68","name":"Humidificateur Off","server":"f2e51979.838dd8","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.humidificateur"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"data"}],"queue":"none","x":1010,"y":360,"wires":[[]]},{"id":"f2e51979.838dd8","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
A priori rien de méchant mais je butte sur le edit trigger state note Humidité > cible+2 ?
merci de votre aide
System Health
version |
core-2022.4.6 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.9.9 |
os_name |
Linux |
os_version |
5.10.108 |
arch |
x86_64 |
timezone |
Europe/Paris |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.24.5 |
Stage |
running |
Available Repositories |
1097 |
Downloaded Repositories |
23 |
logged_in |
true |
subscription_expiration |
23 avril 2022, 02:00 |
relayer_connected |
true |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
true |
google_enabled |
false |
remote_server |
eu-central-1-3.ui.nabu.casa |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 7.6 |
update_channel |
stable |
supervisor_version |
supervisor-2022.04.0 |
docker_version |
20.10.9 |
disk_total |
111.1 GB |
disk_used |
12.0 GB |
healthy |
true |
supported |
true |
board |
generic-x86-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
deCONZ (6.12.0), Mosquitto broker (6.0.1), ESPHome (2022.3.1), Z-Wave JS (0.1.56), Samba share (9.5.1), Node-RED (10.4.0), File editor (5.3.3) |
dashboards |
3 |
resources |
15 |
views |
9 |
mode |
storage |
