Je n’arrive pas a mettre en oeuvre la doc d’installation de google assistant
Go to the Google Actions Console and create a new project.
After you created the project on the bottom of the page click on "Device registration". Keep this tab open for later use.
je n’ai pas l’onglet « device registration »
est-ce lié à l’abandon le 16/06/2023 de google des actions de dialog flow
aujourd’hui on ne peut plus créé que des smarthome action
version |
core-2023.6.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.11.4 |
os_name |
Linux |
os_version |
6.1.21-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.32.1 |
Stage |
running |
Available Repositories |
1282 |
Downloaded Repositories |
6 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.3 |
update_channel |
stable |
supervisor_version |
supervisor-2023.06.4 |
agent_version |
1.5.1 |
docker_version |
23.0.6 |
disk_total |
27.8 GB |
disk_used |
8.6 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.6.0), Advanced SSH & Web Terminal (15.0.2), Node-RED (14.2.2), Mosquitto broker (6.2.1), Piper (0.1.3), Duck DNS (1.15.0), InfluxDB (4.7.0), EnOcean MQTT (dev) (0.1.26), MyElectricalData (0.8.16), Grafana (8.3.0), Let’s Encrypt (4.12.9), NGINX Home Assistant SSL proxy (3.5.0), Google Assistant SDK (2.5.0) |
dashboards |
1 |
resources |
1 |
views |
11 |
mode |
storage |
oldest_recorder_run |
June 23, 2023 at 9:45 PM |
current_recorder_run |
July 2, 2023 at 2:16 AM |
estimated_db_size |
48.56 MiB |
database_engine |
sqlite |
database_version |
3.41.2 |
