Configurer un 0,96 Zoll Oled Display
j’essaie de configurer un 0,96 Zoll Oled connecté a un esp32S avec ESPHOME,
Renseigner votre problème
version core-2023.4.1
python_version 3.10.10
os_version 5.15.84-v8
Installed Version 1.31.0
Available Repositories 1319
Downloaded Repositories 8
logged_in true
subscription_expiration 6 mars 2024 à 01:00
relayer_connected true
relayer_region eu-central-1
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled false
remote_server eu-central-1-3.ui.nabu.casa
host_os Home Assistant OS 9.5
supervisor_version supervisor-2023.04.0
agent_version 1.4.1
docker_version 20.10.22
disk_total 219.4 GB
disk_used 5.9 GB
board rpi4-64
installed_addons File editor (5.5.0), Terminal & SSH (9.6.1), Mosquitto broker (6.2.0), Zigbee2MQTT (1.30.3-1), Samba share (10.0.0), ESPHome (2023.3.2)
dashboards 1
resources 2
views 4
oldest_recorder_run 24 mars 2023 à 07:13
current_recorder_run 10 avril 2023 à 12:21
estimated_db_size 17.62 MiB
database_version 3.38.5
Mon fichier yaml: ``` esphome: name: esphome-web-a21470 friendly_name: ESPHome Web a21470
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: "
ota:
wifi:
ssid: !secret wifi_ssid
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: « Esphome-Web-A21470 »
password: « xHhiE9ucYXrA »
captive_portal:
Example configuration entry
  • platform: dht
    pin: 16
    temperature:
    name: « ESP32 Temperature »
    humidity:
    name: « ESP32Room Humidity »
    update_interval: 30s
light:
  • platform: binary
    name: « Desk Lamp »
    output: light_output
output:
  • id: light_output
    platform: gpio
    pin: GPIO4
time:
  • platform: homeassistant
i2c:
sda: 21
scl: 22
display:
  • platform: ssd1306_i2c
    model: « SSD1306 128x64 »
    #reset_pin: D0
    address: 0x3C
    lambda: |-
    it.print(0, 0, id(font), « Hello World! »);
L'erreur lors de l'install:
[floatl]INFO Reading configuration /config/esphome/esphome-web-a21470.yaml...
WARNING GPIO4 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Detected timezone 'Europe/Paris'
Failed config
display.ssd1306_i2c: [source /config/esphome/esphome-web-a21470.yaml:66]
  model: SSD1306_128X64
  address: 0x3C
  Couldn't find ID 'font'. Please check you have defined an ID with that name in your configuration.
  lambda: !lambda |-
    it.print(0, 0, id(font), "Hello World!");
  auto_clear_enabled: True
  brightness: 1.0
  contrast: 1.0
  flip_x: True
  flip_y: True
  offset_x: 0
  offset_y: 0
  invert: False
  update_interval: 1s[/floatl]
copie ton programme en mode programme car là on ne voit pas les problèmes de syntaxe et d’indentation
et donc ça me semble difficile de te répondre même si je ne suis pas expert!
Cordialement
i2c:
  sda: 21
  scl: 22
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    #reset_pin: D0
    address: 0x3C
    lambda: |-
Bonjour problème de câblage de ton esp et pas du prog :
Failed config
Bonjour a tous ,
J’ai solutionné mon problème. Je mets la configuration de mon yaml au cas ou cela intéresserai quelqu’un
# Example configuration entry
light:
  - platform: binary
output:
  - id: light_output
    platform: gpio
    pin: GPIO16
#Get Time
time:
  - platform: homeassistant
  - platform: dht
    pin: 17
    temperature:
    humidity:
i2c:
  sda: 21
  scl: 22
  scan: false
font:
  - file: "gfonts://Roboto"
display:
    address: 0x3C
    lambda: |-
      // Print "Mitt Smarta Hus" in top center.
      it.printf(64, 0, id(roboto3), TextAlign::TOP_CENTER, "Lumbin");
      // Print time in HH:MM format
      it.strftime(0, 60, id(roboto2), TextAlign::BASELINE_LEFT, "%H:%M", id(esptime).now());
      // Print inside temperature (from homeassistant sensor)
      if (id(temp).has_state()) {
        it.printf(127, 23, id(roboto3), TextAlign::TOP_RIGHT , "%.1f°", id(temp).state);
      // Print outside temperature (from homeassistant sensor)
      if (id(hum).has_state()) {
        it.printf(127, 60, id(roboto3), TextAlign::BASELINE_RIGHT , "%.1f°", id(hum).state);
      }saisissez ou collez du code ici
J’ai sur mon breadbord un NodeMCU ESP32 kit un capteur température et humidité DHT22 ,un display 0.96 Oled et j’ai ajouté une Led que je peux allumer ou éteindre depuis le tableau de bord de HA
Merci d’avoir pris le temps de me lire et de me répondre
