J’ai reçu un module Zigbee ZBMINIR2 de chez Sonoff, je ne comprends pas comment puis-je le connecter à mon télérupteur ? J’ai essayé de connecter sur un bouton poussoir mais ça ne fonctionne pas et apparemment je peux le connecter entre le télérupteur et l’éclairage, pouvez-vous m’aider ?
## System Information
version | core-2025.3.3
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.2
os_name | Linux
os_version | 6.6.62-haos-raspi
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 4998
Installed Version | 2.0.5
Stage | running
Available Repositories | 1596
Downloaded Repositories | 4
</details>
logged_in | true
subscription_expiration | 31 mars 2025 à 02:00
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | true
google_enabled | false
cloud_ice_servers_enabled | true
remote_server | eu-central-1-25.ui.nabu.casa
certificate_status | ready
instance_id | eedc8ee960b9456ea85b314dec309670
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 14.2
update_channel | stable
supervisor_version | supervisor-2025.03.3
agent_version | 1.6.0
docker_version | 27.2.0
disk_total | 116.5 GB
disk_used | 7.4 GB
healthy | true
supported | true
host_connectivity | true
ntp_synchronized | true
virtualization |
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Terminal & SSH (9.16.0), Mosquitto broker (6.5.0), Zigbee2MQTT (2.1.3-1), Studio Code Server (5.18.3)
</details>
dashboards | 2
resources | 0
views | 1
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), wlan0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth938e5e8 (disabled), veth78b91be (disabled), veth29c69c5 (disabled), vethe1e45a3 (disabled), vethd0b650f (disabled), veth2924050 (disabled), vethd14029c (disabled), veth549e36a (disabled), veth8245145 (disabled)
ipv4_addresses | lo (127.0.0.1/8), wlan0 (192.168.1.109/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth938e5e8 (), veth78b91be (), veth29c69c5 (), vethe1e45a3 (), vethd0b650f (), veth2924050 (), vethd14029c (), veth549e36a (), veth8245145 ()
ipv6_addresses | lo (::1/128), wlan0 (2a01:e0a:555:3a70:1a1:2b91:24c5:4290/64, fe80::cdc4:4643:5a93:1507/64), hassio (fe80::42:72ff:fe99:88bf/64), docker0 (fe80::42:cbff:feb5:4385/64), veth938e5e8 (fe80::7ccd:17ff:fed5:7cec/64), veth78b91be (fe80::1429:edff:fed2:fb60/64), veth29c69c5 (fe80::e4ef:beff:feb6:d612/64), vethe1e45a3 (fe80::40a9:56ff:fed9:1fe6/64), vethd0b650f (fe80::a87c:47ff:feff:302f/64), veth2924050 (fe80::e099:b2ff:fef3:28a6/64), vethd14029c (fe80::64b1:1aff:fe19:5d59/64), veth549e36a (fe80::8cbe:17ff:fefc:1a25/64), veth8245145 (fe80::dcb1:cff:fefe:ed1c/64)
announce_addresses | 192.168.1.109, 2a01:e0a:555:3a70:1a1:2b91:24c5:4290, fe80::cdc4:4643:5a93:1507
</details>
oldest_recorder_run | 6 mars 2025 à 13:19
current_recorder_run | 17 mars 2025 à 16:41
estimated_db_size | 13.98 MiB
database_engine | sqlite
database_version | 3.48.0
</details>
