Bonjour a tous, comment ajouter une courbe de référence ?
Peut on, via une date précise, faire afficher la courbe ?
[center]## System Information
version |
core-2024.8.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.4 |
os_name |
Linux |
os_version |
6.6.31-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.0 |
Stage |
running |
Available Repositories |
1456 |
Downloaded Repositories |
17 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 13.1 |
update_channel |
stable |
supervisor_version |
supervisor-2024.08.0 |
agent_version |
1.6.0 |
docker_version |
26.1.4 |
disk_total |
116.7 GB |
disk_used |
8.8 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
ZeroTier One (0.18.0), File editor (5.8.0), Silicon Labs Multiprotocol (2.4.5), Terminal & SSH (9.14.0), InfluxDB (5.0.0), Mosquitto broker (6.4.1), Zigbee2MQTT (1.40.0-1), ESPHome (2024.8.1), Advanced SSH & Web Terminal (18.0.0), AppDaemon (0.16.6), Studio Code Server (5.15.0) |
dashboards |
2 |
resources |
11 |
views |
3 |
mode |
storage |
oldest_recorder_run |
23 août 2024 à 08:16 |
current_recorder_run |
2 septembre 2024 à 11:11 |
estimated_db_size |
314.68 MiB |
database_engine |
sqlite |
database_version |
3.45.3 |
[/center]
