Crash de zigbee2mqtt
J’ai des plantages intempestifs de Zigbee2mqtt dont je ne comprends pas l’origine.
Celui-ci crash et il est quasiment impossible de le relancer.
Zigbee2mqtt 1.35.3-1
Mosquitto broker 6.4.0
Core 2024.2.2
Supervisor 2024.02.0
OS : 11.5
Frontend 202402027.1
Raspberry Pi 3
rpi3-64
Clé : SONOFF ZigBee 3.0 USB Dongle Plus, EFR32MG21
Zigbee2mqtt config :
data_path: /config/zigbee2mqtt
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: "-d -d"
  log: false
mqtt:
  mqtt:
    base_topic: zigbee2mqtt
    server: mqtt://core-mosquito
    user: mqtt
    password: XxX
serial:
  port: /dev/ttyACM0
  adapter: ezsp
Zigbee2mqtt configuration.yaml
homeassistant: true
advanced:
  network_key:
    - 185
    - 253
    - 143
    - 175
    - 242
    - 43
    - 154
    - 183
    - 197
    - 49
    - 162
    - 123
    - 155
    - 156
    - 237
    - 120
  pan_id: 11726
  ext_pan_id:
    - 115
    - 227
    - 46
    - 160
    - 130
    - 98
    - 32
    - 178
  homeassistant_legacy_entity_attributes: false
  legacy_api: false
  legacy_availability_payload: false
mqtt:
  user: addons
  password: YyY
serial:
  port: /dev/ttyACM0
  adapter: ezsp
frontend:
  port: 8099
device_options:
  legacy: false
devices:
  '0x54ef4410007def8b':
    friendly_name: Température salon
    description: Capteur de température chambre principale
    homeassistant: {}
    legacy: false
    optimistic: true
  '0xa4c1387421845932':
    friendly_name: Détecteur ouverture porte baie vitrée
    description: Détecteur ouverture porte baie vitrée
  '0x90395efffe2763c2':
    friendly_name: Radiateur Masterbedroom
    description: |-
      0x90395efffe2763c2
  '0x90395efffe4b1c01':
    friendly_name: Radiateur chambre invité
    description: |-
      0x90395efffe4b1c01
Mosquitto broker configuration :
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
  active: false
  folder: mosquitto
  logins:
    - username: mqtt
    - password: XxX
Supervisor log :
24-02-26 08:05:36 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 08:05:48 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 08:05:50 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:07:48 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 08:07:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:09:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:09:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:09:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:14:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:14:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:14:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:19:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:19:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:19:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:24:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:24:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:24:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:29:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:29:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:29:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:34:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:34:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:34:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:35:40 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-26 08:39:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:39:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:39:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:44:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:44:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:44:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:47:39 INFO (MainThread) [supervisor.backups.manager] Found 9 backup files
24-02-26 08:49:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:49:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:49:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:54:29 INFO (MainThread) [supervisor.backups.manager] Found 9 backup files
24-02-26 08:54:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:54:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:54:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 08:54:58 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-26 08:56:27 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-26 08:56:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-26 08:56:28 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-26 08:56:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-26 08:56:30 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-26 08:56:30 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-26 08:59:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 08:59:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 08:59:48 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:01:31 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 09:01:32 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:01:50 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 09:01:50 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:02:54 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-26 09:03:03 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-26 09:03:03 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-26 09:03:11 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-26 09:03:13 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-26 09:03:51 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 09:04:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 09:04:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 09:04:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:07:26 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
24-02-26 09:09:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 09:09:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 09:09:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:10:00 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 09:10:01 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:10:16 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 09:10:17 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:12:16 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 09:14:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 09:14:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 09:14:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:15:00 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 09:15:01 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:15:15 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 09:15:15 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:17:15 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 09:19:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 09:19:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 09:19:49 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:20:00 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 09:20:01 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:20:16 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 09:20:17 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ mqtt › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 09:22:18 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
Zigbee2Mqtt logt :
[09:35:21] INFO: Preparing to start…
[09:35:23] INFO: Socat not enabled
[09:35:32] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2024-02-26 09:36:13: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2024-02-26.09-36-09 › filename: log.txt
Zigbee2MQTT:info 2024-02-26 09:36:14: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-26 09:36:14: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-02-26 09:36:41: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-26 09:36:41: Failed to start zigbee
Zigbee2MQTT:error 2024-02-26 09:36:41: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-02-26 09:36:41: Exiting…
Zigbee2MQTT:error 2024-02-26 09:36:43: Error: Failure send version:{« type »:« Buffer »,« data »:[1,0,1,0,0,8]}
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:646:23
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at Ezsp.version (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:456:13)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:167:9)
at Zigbee.start (/app/lib/zigbee.ts:60:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
Merci.
Je pense que l’info est là
Et ça corresponds à l’erreur de syntaxe du fichier de config :
Voilà plutot ce que ça doit donner
socat:
  enabled: false
  options: "-d -d"
  log: false
mqtt:
  user: mqtt
  password: XxX
serial:
  port: /dev/ttyACM0
  adapter: ezsp
Après avoir apporté la modification (mqtt), sauvegardé et relancer HA.
J’ai les logs :
24-02-26 10:24:22 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
24-02-26 10:24:50 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
24-02-26 10:25:07 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-26 10:25:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-26 10:25:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 10:25:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 10:25:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 10:25:46 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-26 10:26:00 INFO (MainThread) [supervisor.auth] Auth request from ‹ core_mosquitto › for ‹ mqtt ›
24-02-26 10:26:05 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cache
24-02-26 10:26:58 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-26 10:27:15 ERROR (MainThread) [supervisor.homeassistant.api] Timeout on call http://172.30.32.1:8123/api/core/state.
24-02-26 10:27:38 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 10:27:38 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 10:27:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-26 10:27:40 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-26 10:28:26 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 10:30:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ logins › for Mosquitto broker (core_mosquitto)
24-02-26 10:30:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ require_certificate › for Mosquitto broker (core_mosquitto)
24-02-26 10:30:11 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 10:30:25 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 10:30:27 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
24-02-26 10:30:28 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 10:30:39 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 10:30:40 WARNING (MainThread) [supervisor.addons.options] Unknown option ‹ base_topic › for Zigbee2MQTT (45df7312_zigbee2mqtt)
Et Zigbee2mqtt :
[10:30:40] INFO: Preparing to start…
[10:30:42] INFO: Socat not enabled
[10:30:49] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2024-02-26 10:31:12: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2024-02-26.10-31-12 › filename: log.txt
Zigbee2MQTT:info 2024-02-26 10:31:13: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-26 10:31:13: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:info 2024-02-26 10:31:18: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-02-26 10:31:18: Coordinator firmware version: ‹ {« meta »:{« maintrel »:"3 ",« majorrel »:« 6 »,« minorrel »:« 10 »,« product »:8,« revision »:« 6.10.3.0 build 297 »},« type »:« EZSP v8 »} ›
Zigbee2MQTT:info 2024-02-26 10:31:18: Currently 4 devices are joined:
Zigbee2MQTT:info 2024-02-26 10:31:18: Température salon (0x54ef4410007def8b): VOCKQJK11LM - Aqara TVOC air quality monitor (EndDevice)
Zigbee2MQTT:info 2024-02-26 10:31:18: Détecteur ouverture porte baie vitrée (0xa4c1387421845932): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2024-02-26 10:31:18: Radiateur Masterbedroom (0x90395efffe2763c2): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-26 10:31:18: Radiateur chambre invité (0x90395efffe4b1c01): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-26 10:31:18: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-02-26 10:31:18: Connecting to MQTT server at mqtt://core-mosquito
Zigbee2MQTT:error 2024-02-26 10:31:23: MQTT error: getaddrinfo ENOTFOUND core-mosquito
Zigbee2MQTT:error 2024-02-26 10:31:23: MQTT failed to connect, exiting…
Zigbee2MQTT:info 2024-02-26 10:31:23: Stopping zigbee-herdsman…
Zigbee2MQTT:info 2024-02-26 10:31:24: Stopped zigbee-herdsman
Ta partie mosquito n’est bonne non plus
Regarde un exemple et compare
rarad
J’ai donc aussi modifier la partie Mosquitto :
logins:
  - username: mqtt
    password: XxX
customize:
  active: false
  folder: mosquitto
Par contre, Zigbee ne se lance toujours pas. Malgré un restart d’HA.
24-02-26 11:20:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-26 11:20:40 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-26 11:22:59 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 11:23:09 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 11:25:09 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 11:26:15 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 11:26:24 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 11:28:24 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
[11:26:24] INFO: Preparing to start…
[11:26:27] INFO: Socat not enabled
[11:26:34] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2024-02-26 11:26:55: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2024-02-26.11-26-55 › filename: log.txt
Zigbee2MQTT:info 2024-02-26 11:26:55: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-26 11:26:56: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:info 2024-02-26 11:27:00: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-02-26 11:27:00: Coordinator firmware version: ‹ {« meta »:{« maintrel »:"3 ",« majorrel »:« 6 »,« minorrel »:« 10 »,« product »:8,« revision »:« 6.10.3.0 build 297 »},« type »:« EZSP v8 »} ›
Zigbee2MQTT:info 2024-02-26 11:27:00: Currently 4 devices are joined:
Zigbee2MQTT:info 2024-02-26 11:27:00: Température salon (0x54ef4410007def8b): VOCKQJK11LM - Aqara TVOC air quality monitor (EndDevice)
Zigbee2MQTT:info 2024-02-26 11:27:00: Détecteur ouverture porte baie vitrée (0xa4c1387421845932): TS0203 - TuYa Door sensor (EndDevice)
Zigbee2MQTT:info 2024-02-26 11:27:00: Radiateur Masterbedroom (0x90395efffe2763c2): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-26 11:27:00: Radiateur chambre invité (0x90395efffe4b1c01): SIN-4-FP-21 - NodOn Pilot wire heating module (Router)
Zigbee2MQTT:info 2024-02-26 11:27:00: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2024-02-26 11:27:01: Connecting to MQTT server at mqtt://core-mosquito
Zigbee2MQTT:error 2024-02-26 11:27:06: MQTT error: getaddrinfo EAI_AGAIN core-mosquito
Zigbee2MQTT:error 2024-02-26 11:27:06: MQTT failed to connect, exiting…
Zigbee2MQTT:info 2024-02-26 11:27:06: Stopping zigbee-herdsman…
Zigbee2MQTT:info 2024-02-26 11:27:06: Stopped zigbee-herdsman
Mosquitto est bien lancé ?
Mosquitto broker est bien lancé
Les logs de zigbee :
[11:50:24] INFO: Preparing to start…
[11:50:26] INFO: Socat not enabled
[11:50:34] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2024-02-26 11:50:59: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2024-02-26.11-50-59 › filename: log.txt
Zigbee2MQTT:info 2024-02-26 11:51:00: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-26 11:51:00: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:error 2024-02-26 11:51:16: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2024-02-26 11:51:16: Failed to start zigbee
Zigbee2MQTT:error 2024-02-26 11:51:16: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
Zigbee2MQTT:error 2024-02-26 11:51:16: Exiting…
Zigbee2MQTT:error 2024-02-26 11:51:16: Error: Failure send version:{« type »:« Buffer »,« data »:[1,0,1,0,0,8]}
Du supervisor :
24-02-26 11:46:11 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to RUNNING
24-02-26 11:46:11 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
24-02-26 11:50:15 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application
24-02-26 11:50:23 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-aarch64 with version 1.35.3-1
24-02-26 11:52:23 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Zigbee2MQTT to start, took more than 120 seconds
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-26 11:56:38 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-26 11:56:39 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-26 11:56:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-26 11:56:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-26 11:56:40 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-26 11:56:40 INFO (MainThread) [supervisor.resolution.fixup] System autofix completen
bizarre, là ça marche coté z2m
et pas là ???
Avec les debug log de Zigbee.
2024-02-26T12:49:09.091Z zigbee-herdsman:adapter:ezsp:uart -± waiting (5) success
2024-02-26T12:49:09.292Z zigbee-herdsman:adapter:ezsp:ezsp ==> permitJoining: {« duration »:0}
2024-02-26T12:49:09.293Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« permitJoining »,« id »:34,« isRequest »:true,« duration »:0}
2024-02-26T12:49:09.294Z zigbee-herdsman:adapter:ezsp:uart → DATA (5,2,0): 350001220000
2024-02-26T12:49:09.295Z zigbee-herdsman:adapter:ezsp:uart → [527721a9762a158c927e]
2024-02-26T12:49:09.296Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (6)
2024-02-26T12:49:09.302Z zigbee-herdsman:adapter:ezsp:uart ← [2677a1a9762a15ebe57e]
2024-02-26T12:49:09.302Z zigbee-herdsman:adapter:ezsp:uart → parsed 2677a1a9762a15ebe57e
2024-02-26T12:49:09.304Z zigbee-herdsman:adapter:ezsp:uart ← DATA (2,6,0): 2677a1a9762a15ebe57e
2024-02-26T12:49:09.305Z zigbee-herdsman:adapter:ezsp:uart → ACK (3)
2024-02-26T12:49:09.306Z zigbee-herdsman:adapter:ezsp:uart → [83401b7e]
2024-02-26T12:49:09.307Z zigbee-herdsman:adapter:ezsp:uart ← ACK (6): 2677a1a9762a15ebe57e
2024-02-26T12:49:09.308Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 358001220000
2024-02-26T12:49:09.310Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x22: {« cls »:« permitJoining »,« id »:34,« isRequest »:false,« status »:0}
2024-02-26T12:49:09.311Z zigbee-herdsman:adapter:ezsp:uart -± waiting (6) success
2024-02-26T12:49:09.317Z zigbee-herdsman:controller:database:log Writing database to ‹ /config/zigbee2mqtt/database.db ›
2024-02-26T12:49:09.344Z zigbee-herdsman:controller:log Creating coordinator backup
2024-02-26T12:49:09.347Z zigbee-herdsman:adapter:ezsp:backup creating backup
2024-02-26T12:49:09.348Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {« desiredProtocolVersion »:8}
2024-02-26T12:49:09.349Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« version »,« id »:0,« isRequest »:true,« desiredProtocolVersion »:8}
2024-02-26T12:49:09.350Z zigbee-herdsman:adapter:ezsp:uart → DATA (6,3,0): 360001000008
2024-02-26T12:49:09.352Z zigbee-herdsman:adapter:ezsp:uart → [637421a9542a1dca307e]
2024-02-26T12:49:09.352Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (7)
2024-02-26T12:49:09.361Z zigbee-herdsman:adapter:ezsp:uart ← [3774a1a9542a1db069fe7d33077e]
2024-02-26T12:49:09.361Z zigbee-herdsman:adapter:ezsp:uart → parsed 3774a1a9542a1db069fe13077e
2024-02-26T12:49:09.362Z zigbee-herdsman:adapter:ezsp:uart ← DATA (3,7,0): 3774a1a9542a1db069fe13077e
2024-02-26T12:49:09.363Z zigbee-herdsman:adapter:ezsp:uart → ACK (4)
2024-02-26T12:49:09.364Z zigbee-herdsman:adapter:ezsp:uart → [8430fc7e]
2024-02-26T12:49:09.365Z zigbee-herdsman:adapter:ezsp:uart ← ACK (7): 3774a1a9542a1db069fe13077e
2024-02-26T12:49:09.366Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 36800100000802306a
2024-02-26T12:49:09.367Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x0: {« cls »:« version »,« id »:0,« isRequest »:false,« protocolVersion »:8,« stackType »:2,« stackVersion »:27184}
2024-02-26T12:49:09.367Z zigbee-herdsman:adapter:ezsp:uart -± waiting (7) success
2024-02-26T12:49:09.369Z zigbee-herdsman:adapter:ezsp:ezsp ==> getKey: {« keyType »:1}
2024-02-26T12:49:09.370Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« getKey »,« id »:106,« isRequest »:true,« keyType »:1}
2024-02-26T12:49:09.371Z zigbee-herdsman:adapter:ezsp:uart → DATA (7,4,0): 3700016a0001
2024-02-26T12:49:09.372Z zigbee-herdsman:adapter:ezsp:uart → [747521a93e2a146c2c7e]
2024-02-26T12:49:09.372Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (0)
2024-02-26T12:49:09.386Z zigbee-herdsman:adapter:ezsp:uart ← [4075a1a93e2a15a8599576dad9e7343de416c8faa9ada6c1ba9d63b9fc7d5e3fa7ebcddea45139392458ab890ba27e]
2024-02-26T12:49:09.387Z zigbee-herdsman:adapter:ezsp:uart → parsed 4075a1a93e2a15a8599576dad9e7343de416c8faa9ada6c1ba9d63b9fc7e3fa7ebcddea45139392458ab890ba27e
2024-02-26T12:49:09.389Z zigbee-herdsman:adapter:ezsp:uart ← DATA (4,0,0): 4075a1a93e2a15a8599576dad9e7343de416c8faa9ada6c1ba9d63b9fc7e3fa7ebcddea45139392458ab890ba27e
2024-02-26T12:49:09.389Z zigbee-herdsman:adapter:ezsp:uart → ACK (5)
2024-02-26T12:49:09.390Z zigbee-herdsman:adapter:ezsp:uart → [8520dd7e]
2024-02-26T12:49:09.391Z zigbee-herdsman:adapter:ezsp:uart ← ACK (0): 4075a1a93e2a15a8599576dad9e7343de416c8faa9ada6c1ba9d63b9fc7e3fa7ebcddea45139392458ab890ba27e
2024-02-26T12:49:09.393Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 3780016a00001a00013cff73b2a6747858ef514463c14a475b003000000000000000cbdec6feff8d79e0
2024-02-26T12:49:09.394Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x6a: {« cls »:« getKey »,« id »:106,« isRequest »:false,« status »:0,« keyStruct »:{« key »:{« contents »:[60,255,115,178,166,116,120,88,239,81,68,99,193,74,71,91]},« outgoingFrameCounter »:12288,« sequenceNumber »:0,« bitmask »:26,« type »:1,« incomingFrameCounter »:0,« partnerEUI64 »:{« type »:« Buffer »,« data »:[224,121,141,255,254,198,222,203]}}}
2024-02-26T12:49:09.395Z zigbee-herdsman:adapter:ezsp:uart -± waiting (0) success
2024-02-26T12:49:09.396Z zigbee-herdsman:adapter:ezsp:ezsp ==> getNetworkParameters: null
2024-02-26T12:49:09.396Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« getNetworkParameters »,« id »:40,« isRequest »:true}
2024-02-26T12:49:09.397Z zigbee-herdsman:adapter:ezsp:uart → DATA (0,5,0): 3800012800
2024-02-26T12:49:09.398Z zigbee-herdsman:adapter:ezsp:uart → [057a21a97c2abcd27e]
2024-02-26T12:49:09.399Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2024-02-26T12:49:09.410Z zigbee-herdsman:adapter:ezsp:uart ← [517aa1a97c2a15b32a7764852837b2fb526322a0edce678bfd3e9c8e6ef07e]
2024-02-26T12:49:09.410Z zigbee-herdsman:adapter:ezsp:uart → parsed 517aa1a97c2a15b32a7764852837b2fb526322a0edce678bfd3e9c8e6ef07e
2024-02-26T12:49:09.411Z zigbee-herdsman:adapter:ezsp:uart ← DATA (5,1,0): 517aa1a97c2a15b32a7764852837b2fb526322a0edce678bfd3e9c8e6ef07e
2024-02-26T12:49:09.412Z zigbee-herdsman:adapter:ezsp:uart → ACK (6)
2024-02-26T12:49:09.412Z zigbee-herdsman:adapter:ezsp:uart → [8610be7e]
2024-02-26T12:49:09.414Z zigbee-herdsman:adapter:ezsp:uart ← ACK (1): 517aa1a97c2a15b32a7764852837b2fb526322a0edce678bfd3e9c8e6ef07e
2024-02-26T12:49:09.415Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 3880012800000173e32ea0826220b2ce2d050b0000000000f8ff07
2024-02-26T12:49:09.416Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x28: {« cls »:« getNetworkParameters »,« id »:40,« isRequest »:false,« status »:0,« nodeType »:1,« parameters »:{« extendedPanId »:[115,227,46,160,130,98,32,178],« panId »:11726,« radioTxPower »:5,« radioChannel »:11,« joinMethod »:0,« nwkManagerId »:0,« nwkUpdateId »:0,« channels »:134215680}}
2024-02-26T12:49:09.417Z zigbee-herdsman:adapter:ezsp:uart -± waiting (1) success
2024-02-26T12:49:09.417Z zigbee-herdsman:adapter:ezsp:ezsp ==> getKey: {« keyType »:3}
2024-02-26T12:49:09.418Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« getKey »,« id »:106,« isRequest »:true,« keyType »:3}
2024-02-26T12:49:09.420Z zigbee-herdsman:adapter:ezsp:uart → DATA (1,6,0): 3900016a0003
2024-02-26T12:49:09.420Z zigbee-herdsman:adapter:ezsp:uart → [167b21a93e2a161f347e]
2024-02-26T12:49:09.421Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (2)
2024-02-26T12:49:09.435Z zigbee-herdsman:adapter:ezsp:uart ← [627ba1a93e2a15b15997f3d825fa606206f9e29a4fb5fc1710be7919ae7d5e3fa7ebcdde6f8fffc7dbd5d269b9e47e]
2024-02-26T12:49:09.436Z zigbee-herdsman:adapter:ezsp:uart → parsed 627ba1a93e2a15b15997f3d825fa606206f9e29a4fb5fc1710be7919ae7e3fa7ebcdde6f8fffc7dbd5d269b9e47e
2024-02-26T12:49:09.436Z zigbee-herdsman:adapter:ezsp:uart ← DATA (6,2,0): 627ba1a93e2a15b15997f3d825fa606206f9e29a4fb5fc1710be7919ae7e3fa7ebcdde6f8fffc7dbd5d269b9e47e
2024-02-26T12:49:09.437Z zigbee-herdsman:adapter:ezsp:uart → ACK (7)
2024-02-26T12:49:09.438Z zigbee-herdsman:adapter:ezsp:uart → [87009f7e]
2024-02-26T12:49:09.439Z zigbee-herdsman:adapter:ezsp:uart ← ACK (2): 627ba1a93e2a15b15997f3d825fa606206f9e29a4fb5fc1710be7919ae7e3fa7ebcdde6f8fffc7dbd5d269b9e47e
2024-02-26T12:49:09.440Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 3980016a0000030003b9fd8faff22b9ab7c531a27b9b9ced781a90520000000000000000000000000000
2024-02-26T12:49:09.442Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x6a: {« cls »:« getKey »,« id »:106,« isRequest »:false,« status »:0,« keyStruct »:{« key »:{« contents »:[185,253,143,175,242,43,154,183,197,49,162,123,155,156,237,120]},« outgoingFrameCounter »:5410842,« sequenceNumber »:0,« bitmask »:3,« type »:3,« incomingFrameCounter »:0,« partnerEUI64 »:{« type »:« Buffer »,« data »:[0,0,0,0,0,0,0,0]}}}
2024-02-26T12:49:09.443Z zigbee-herdsman:adapter:ezsp:uart -± waiting (2) success
2024-02-26T12:49:09.443Z zigbee-herdsman:adapter:ezsp:ezsp ==> getEui64: null
2024-02-26T12:49:09.444Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« getEui64 »,« id »:38,« isRequest »:true}
2024-02-26T12:49:09.445Z zigbee-herdsman:adapter:ezsp:uart → DATA (2,7,0): 3a00012600
2024-02-26T12:49:09.445Z zigbee-herdsman:adapter:ezsp:uart → [277821a9722a65167e]
2024-02-26T12:49:09.446Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (3)
2024-02-26T12:49:09.477Z zigbee-herdsman:adapter:ezsp:uart ← [7378a1a9722ade6c9f6ab5a8d3b57d3ae77e]
2024-02-26T12:49:09.478Z zigbee-herdsman:adapter:ezsp:uart → parsed 7378a1a9722ade6c9f6ab5a8d3b51ae77e
2024-02-26T12:49:09.478Z zigbee-herdsman:adapter:ezsp:uart ← DATA (7,3,0): 7378a1a9722ade6c9f6ab5a8d3b51ae77e
2024-02-26T12:49:09.479Z zigbee-herdsman:adapter:ezsp:uart → ACK (0)
2024-02-26T12:49:09.480Z zigbee-herdsman:adapter:ezsp:uart → [8070787e]
2024-02-26T12:49:09.481Z zigbee-herdsman:adapter:ezsp:uart ← ACK (3): 7378a1a9722ade6c9f6ab5a8d3b51ae77e
2024-02-26T12:49:09.482Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 3a80012600cbdec6feff8d79e0
2024-02-26T12:49:09.483Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x26: {« cls »:« getEui64 »,« id »:38,« isRequest »:false,« eui64 »:{« type »:« Buffer »,« data »:[224,121,141,255,254,198,222,203]}}
2024-02-26T12:49:09.484Z zigbee-herdsman:adapter:ezsp:uart -± waiting (3) success
2024-02-26T12:49:09.500Z zigbee-herdsman:controller:log Wrote coordinator backup to ‹ /config/zigbee2mqtt/coordinator_backup.json ›
2024-02-26T12:49:09.501Z zigbee-herdsman:adapter:ezsp:driv Stopping driver
2024-02-26T12:49:09.502Z zigbee-herdsman:adapter:ezsp:ezsp Closing Ezsp
2024-02-26T12:49:09.503Z zigbee-herdsman:adapter:ezsp:uart Closing UART
2024-02-26T12:49:09.510Z zigbee-herdsman:adapter:ezsp:uart Port closed. Error? null
2024-02-26T12:49:09.511Z zigbee-herdsman:adapter:ezsp:ezsp onSerialClose()
2024-02-26T12:49:09.512Z zigbee-herdsman:adapter:ezsp:driv onEzspClose()
2024-02-26T12:49:09.513Z zigbee-herdsman:adapter:ezsp:debg onDriverClose()
2024-02-26T12:49:09.514Z zigbee-herdsman:adapter:ezsp:ezsp onSerialClose()
2024-02-26T12:49:09.514Z zigbee-herdsman:adapter:ezsp:driv onEzspClose()
2024-02-26T12:49:09.515Z zigbee-herdsman:adapter:ezsp:debg onDriverClose()
Zigbee2MQTT:info 2024-02-26 13:49:09: Stopped zigbee-herdsman
J’ai vérifier que la clé était sur le bon port usb, ce qui est le cas.
Peut-être tenté en changeant de port USB, j’ai vu que sur les ports USB 3, cela pouvait poser problème, mais le RPI3, n’en a pas, seulement de l’USB 2.
J’ai tenté de mettre la référence de la clé au lieu du ttcACM0.
socat:
  enabled: false
  options: "-d -d"
  log: false
mqtt:
  user: mqtt
  password: XxX
serial:
  port: >-
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803114708-if00
  adapter: ezsp
zigbee_herdsman_debug: true
Et dans le fichier yaml
homeassistant: true
advanced:
  network_key:
    - 185
    - 253
    - 143
    - 175
    - 242
    - 43
    - 154
    - 183
    - 197
    - 49
    - 162
    - 123
    - 155
    - 156
    - 237
    - 120
  pan_id: 11726
  ext_pan_id:
    - 115
    - 227
    - 46
    - 160
    - 130
    - 98
    - 32
    - 178
  legacy_api: false
mqtt:
  user: addons
  password: YyY
serial:
  port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803114708-if00
  adapter: ezsp
frontend:
  port: 8099
device_options:
  legacy: false
devices:
    homeassistant: {}
    legacy: false
    optimistic: true
    description: |-
      0x90395efffe2763c2
    description: |-
      0x90395efffe4b1c01
Mais cela ne démarre toujours pas :
[16:41:11] INFO: Zigbee Herdsman debug logging enabled
[16:41:17] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:debug 2024-02-26 16:41:36: Loaded state from file /config/zigbee2mqtt/state.json
Zigbee2MQTT:info 2024-02-26 16:41:36: Logging to console and directory: ‹ /config/zigbee2mqtt/log/2024-02-26.16-41-35 › filename: log.txt
Zigbee2MQTT:debug 2024-02-26 16:41:36: Removing old log directory ‹ /config/zigbee2mqtt/log/2024-02-26.16-25-36 ›
Zigbee2MQTT:info 2024-02-26 16:41:36: Starting Zigbee2MQTT version 1.35.3 (commit #unknown)
Zigbee2MQTT:info 2024-02-26 16:41:36: Starting zigbee-herdsman (0.33.8)
Zigbee2MQTT:debug 2024-02-26 16:41:36: Using zigbee-herdsman with settings: ‹ {« adapter »:{« concurrent »:null,« delay »:null,« disableLED »:false},« backupPath »:« /config/zigbee2mqtt/coordinator_backup.json »,« databaseBackupPath »:« /config/zigbee2mqtt/database.db.backup »,« databasePath »:« /config/zigbee2mqtt/database.db »,« network »:{« channelList »:[11],« extendedPanID »:[115,227,46,160,130,98,32,178],« networkKey »:« HIDDEN »,« panID »:11726},« serialPort »:{« adapter »:« ezsp »,« path »:« /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803114708-if00 »}} ›
2024-02-26T15:41:38.711Z zigbee-herdsman:adapter Failed to validate path: ‹ Error: spawn udevadm ENOENT ›
2024-02-26T15:41:38.718Z zigbee-herdsman:adapter:ezsp:debg Adapter concurrent: 8
2024-02-26T15:41:38.724Z zigbee-herdsman:controller:log Starting with options ‹ {« network »:{« networkKeyDistribute »:false,« networkKey »:[185,253,143,175,242,43,154,183,197,49,162,123,155,156,237,120],« panID »:11726,« extendedPanID »:[115,227,46,160,130,98,32,178],« channelList »:[11]},« serialPort »:{« path »:« /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803114708-if00 »,« adapter »:« ezsp »},« databasePath »:« /config/zigbee2mqtt/database.db »,« databaseBackupPath »:« /config/zigbee2mqtt/database.db.backup »,« backupPath »:« /config/zigbee2mqtt/coordinator_backup.json »,« adapter »:{« disableLED »:false,« concurrent »:null,« delay »:null}} ›
2024-02-26T15:41:38.736Z zigbee-herdsman:adapter:ezsp:uart RTS/CTS config is off, enabling software flow control.
2024-02-26T15:41:38.736Z zigbee-herdsman:adapter:ezsp:uart Opening SerialPort with {« path »:« /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803114708-if00 »,« baudRate »:115200,« rtscts »:false,« autoOpen »:false,« parity »:« none »,« stopBits »:1,« xon »:true,« xoff »:true}
2024-02-26T15:41:38.767Z zigbee-herdsman:adapter:ezsp:uart Serialport opened
2024-02-26T15:41:38.769Z zigbee-herdsman:adapter:ezsp:uart Uart reseting
2024-02-26T15:41:38.773Z zigbee-herdsman:adapter:ezsp:uart → Write reset
2024-02-26T15:41:38.784Z zigbee-herdsman:adapter:ezsp:uart → [1ac038bc7e]
2024-02-26T15:41:38.791Z zigbee-herdsman:adapter:ezsp:uart -?- waiting reset
2024-02-26T15:41:38.844Z zigbee-herdsman:adapter:ezsp:uart ← [7d5e1ea7eb3d997e2e7fb1a96b2a15e2ac904b26aa5493499c4e27e6e6a867f8d47ec20251a8bd7e]
2024-02-26T15:41:38.848Z zigbee-herdsman:adapter:ezsp:uart → parsed 7e1ea7eb3d997e
2024-02-26T15:41:39.063Z zigbee-herdsman:adapter:ezsp:uart Error: ← CRC error: 7e1ea7eb3d997e|3d99|f421
at Frame.checkCRC (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/frame.ts:87:19)
at SerialDriver.onParsed (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:166:19)
at Parser.emit (node:events:517:28)
at Parser.parseNext (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/parser.ts:59:34)
at Parser._transform (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/parser.ts:40:14)
at Parser.Transform._write (node:internal/streams/transform:175:8)
at writeOrBuffer (node:internal/streams/writable:392:12)
at _write (node:internal/streams/writable:333:10)
at Parser.Writable.write (node:internal/streams/writable:337:10)
at SerialPort.ondata (node:internal/streams/readable:777:22)
2024-02-26T15:41:39.071Z zigbee-herdsman:adapter:ezsp:uart → [a0547d3a7e]
2024-02-26T15:41:39.075Z zigbee-herdsman:adapter:ezsp:uart → parsed 2e7fb1a96b2a15e2ac904b26aa5493499c4e27e6e6a867f8d47e
2024-02-26T15:41:39.077Z zigbee-herdsman:adapter:ezsp:uart ← DATA (2,6,1): 2e7fb1a96b2a15e2ac904b26aa5493499c4e27e6e6a867f8d47e
2024-02-26T15:41:39.077Z zigbee-herdsman:adapter:ezsp:uart → ACK (3)
2024-02-26T15:41:39.079Z zigbee-herdsman:adapter:ezsp:uart → [83401b7e]
2024-02-26T15:41:39.081Z zigbee-herdsman:adapter:ezsp:uart ← ACK (6): 2e7fb1a96b2a15e2ac904b26aa5493499c4e27e6e6a867f8d47e
2024-02-26T15:41:39.084Z zigbee-herdsman:adapter:ezsp:uart Unexpected packet sequence 6 | 0
2024-02-26T15:41:39.085Z zigbee-herdsman:adapter:ezsp:uart Skipping the packet as repeated (3)
2024-02-26T15:41:39.086Z zigbee-herdsman:adapter:ezsp:uart → parsed c20251a8bd7e
2024-02-26T15:41:39.088Z zigbee-herdsman:adapter:ezsp:uart ← Error c20251a8bd7e
2024-02-26T15:41:39.089Z zigbee-herdsman:adapter:ezsp:uart Uart reseting
2024-02-26T15:41:39.090Z zigbee-herdsman:adapter:ezsp:uart → Write reset
2024-02-26T15:41:39.092Z zigbee-herdsman:adapter:ezsp:uart → [1ac038bc7e]
2024-02-26T15:41:39.093Z zigbee-herdsman:adapter:ezsp:uart -?- waiting reset
2024-02-26T15:41:39.897Z zigbee-herdsman:adapter:ezsp:uart ← [c1020b0a527e]
2024-02-26T15:41:39.898Z zigbee-herdsman:adapter:ezsp:uart → parsed c1020b0a527e
2024-02-26T15:41:39.901Z zigbee-herdsman:adapter:ezsp:uart ← RSTACK c1020b0a527e
2024-02-26T15:41:39.902Z zigbee-herdsman:adapter:ezsp:uart RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
2024-02-26T15:41:39.907Z zigbee-herdsman:adapter:ezsp:uart -± waiting reset success
2024-02-26T15:41:39.910Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {« desiredProtocolVersion »:4}
2024-02-26T15:41:39.914Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« version »,« id »:0,« isRequest »:true,« desiredProtocolVersion »:4}
2024-02-26T15:41:39.921Z zigbee-herdsman:adapter:ezsp:uart → DATA (0,0,0): 00000004
2024-02-26T15:41:39.925Z zigbee-herdsman:adapter:ezsp:uart → [004221a850ed2c7e]
2024-02-26T15:41:39.927Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2024-02-26T15:41:40.997Z zigbee-herdsman:adapter:ezsp:uart ← [c1020b0a527e]
2024-02-26T15:41:40.998Z zigbee-herdsman:adapter:ezsp:uart → parsed c1020b0a527e
2024-02-26T15:41:40.999Z zigbee-herdsman:adapter:ezsp:uart ← RSTACK c1020b0a527e
2024-02-26T15:41:41.000Z zigbee-herdsman:adapter:ezsp:uart RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
2024-02-26T15:41:41.934Z zigbee-herdsman:adapter:ezsp:uart → Error: Error: {« sequence »:1} after 2000ms
2024-02-26T15:41:41.934Z zigbee-herdsman:adapter:ezsp:uart -!- break waiting (1)
2024-02-26T15:41:41.934Z zigbee-herdsman:adapter:ezsp:uart Can’t send DATA frame (0,0,0): 00000004
2024-02-26T15:41:42.438Z zigbee-herdsman:adapter:ezsp:uart ->> DATA (0,0,1): 00000004
2024-02-26T15:41:42.444Z zigbee-herdsman:adapter:ezsp:uart → [084221a850ef017e]
2024-02-26T15:41:42.446Z zigbee-herdsman:adapter:ezsp:uart -?- rewaiting (1)
2024-02-26T15:41:42.451Z zigbee-herdsman:adapter:ezsp:uart ← [8160597e0142a1a85c2825d8e12b7e]
2024-02-26T15:41:42.452Z zigbee-herdsman:adapter:ezsp:uart → parsed 8160597e
2024-02-26T15:41:42.452Z zigbee-herdsman:adapter:ezsp:uart ← ACK (1): 8160597e
2024-02-26T15:41:42.454Z zigbee-herdsman:adapter:ezsp:uart → parsed 0142a1a85c2825d8e12b7e
2024-02-26T15:41:42.454Z zigbee-herdsman:adapter:ezsp:uart ← DATA (0,1,0): 0142a1a85c2825d8e12b7e
2024-02-26T15:41:42.454Z zigbee-herdsman:adapter:ezsp:uart → ACK (1)
2024-02-26T15:41:42.455Z zigbee-herdsman:adapter:ezsp:uart → [8160597e]
2024-02-26T15:41:42.456Z zigbee-herdsman:adapter:ezsp:uart ← ACK (1): 0142a1a85c2825d8e12b7e
2024-02-26T15:41:42.457Z zigbee-herdsman:adapter:ezsp:uart Unexpected packet sequence 1 | 0
2024-02-26T15:41:42.459Z zigbee-herdsman:adapter:ezsp:ezsp <== Frame: 0080000802306a
2024-02-26T15:41:42.463Z zigbee-herdsman:adapter:ezsp:ezsp <== 0x0: {« cls »:« version »,« id »:0,« isRequest »:false,« protocolVersion »:8,« stackType »:2,« stackVersion »:27184}
2024-02-26T15:41:42.465Z zigbee-herdsman:adapter:ezsp:uart -± rewaiting (1) success
2024-02-26T15:41:42.466Z zigbee-herdsman:adapter:ezsp:ezsp Switching to eszp version 8
2024-02-26T15:41:42.468Z zigbee-herdsman:adapter:ezsp:ezsp ==> version: {« desiredProtocolVersion »:8}
2024-02-26T15:41:42.469Z zigbee-herdsman:adapter:ezsp:ezsp ==> {« cls »:« version »,« id »:0,« isRequest »:true,« desiredProtocolVersion »:8}
2024-02-26T15:41:42.472Z zigbee-herdsman:adapter:ezsp:uart → DATA (0,1,0): 010001000008
2024-02-26T15:41:42.473Z zigbee-herdsman:adapter:ezsp:uart → [014321a9542a1dfe047e]
2024-02-26T15:41:42.474Z zigbee-herdsman:adapter:ezsp:uart -?- waiting (1)
2024-02-26T15:41:42.480Z zigbee-herdsman:adapter:ezsp:uart ← [a1443b7e]
2024-02-26T15:41:42.481Z zigbee-herdsman:adapter:ezsp:uart → parsed a1443b7e
2024-02-26T15:41:42.483Z zigbee-herdsman:adapter:ezsp:uart ← NAK (1): a1443b7e
2024-02-26T15:41:42.485Z zigbee-herdsman:adapter:ezsp:uart NAK Expected packet sequence 1
2024-02-26T15:41:42.488Z zigbee-herdsman:adapter:ezsp:uart → Error: Error: Recv NAK frame
2024-02-26T15:41:42.489Z zigbee-herdsman:adapter:ezsp:uart -!- break waiting (1)
2024-02-26T15:41:42.489Z zigbee-herdsman:adapter:ezsp:uart Can’t send DATA frame (0,1,0): 010001000008
2024-02-26T15:41:42.991Z zigbee-herdsman:adapter:ezsp:uart ->> DATA (0,1,1): 010001000008
2024-02-26T15:41:42.993Z zigbee-herdsman:adapter:ezsp:uart → [094321a9542a1d6da97e]
2024-02-26T15:41:42.995Z zigbee-herdsman:adapter:ezsp:uart -?- rewaiting (1)
2024-02-26T15:41:43.002Z zigbee-herdsman:adapter:ezsp:uart ← [8160597e]
2024-02-26T15:41:43.003Z zigbee-herdsman:adapter:ezsp:uart → parsed 8160597e
2024-02-26T15:41:43.004Z zigbee-herdsman:adapter:ezsp:uart ← ACK (1): 8160597e
2024-02-26T15:41:43.005Z zigbee-herdsman:adapter:ezsp:uart -± rewaiting (1) success
2024-02-26T15:41:49.914Z zigbee-herdsman:adapter:ezsp:ezsp Time to watchdog … 0
2024-02-26T15:41:49.915Z zigbee-herdsman:adapter:ezsp:ezsp ==> nop: null
Tu n’as pas ZHA qui tourne en même temps ?
ZHA est dans les modules ignorés:
Est-ce normal de ne pas avoir les mêmes ID et pwd entre la configuration de zigbee2mqtt et le fichier configuration.yaml de zigbee ?
Effectivement c’est un contournement.
Hélas il ne fonctionne pas pour ma part, cela fait relancer toutes les 5mns Zigbee tellement celui-ci ne réponds pas.
Cela fonctionne depuis hier sans coupure avec la configuration suivante
Zigbee configuration.yaml
homeassistant: true
advanced:
network_key:
- 185
- 253
- 143
- 175
- 242
- 43
- 154
- 183
- 197
- 49
- 162
- 123
- 155
- 156
- 237
- 120
pan_id: 11726
ext_pan_id:
- 115
- 227
- 46
- 160
- 130
- 98
- 32
- 178
legacy_api: false
mqtt:
user: addons
password: YyY
serial:
adapter: ezsp
frontend:
port: 8099
device_options:
legacy: false
devices:
‹ 0x54ef4410007def8b ›:
homeassistant: {}
legacy: false
optimistic: true
‹ 0xa4c1387421845932 ›:
‹ 0x90395efffe2763c2 ›:
description: |-
0x90395efffe2763c2
‹ 0x90395efffe4b1c01 ›:
description: |-
0x90395efffe4b1c01
Zigbee configuration :
socat:
enabled: false
options: « -d -d »
log: false
mqtt:
user: mqtt
password: XxX
serial:
port: >-
adapter: ezsp
zigbee_herdsman_debug: false
Mosquitto broker :
logins:
  • username: mqtt
    password: XxX
    customize:
    active: false
    folder: mosquitto
Merci pour l’aide.
En espérant que ça aidera un futur.
