Mon système frigate qui fonctionnait bien jusqu’à présent est crashed.l add on ne veut plus démarrer.
Merci de votre avis
Le log est
2022-12-27 10:34:59] frigate.video
ERROR : pi_cam: ffmpeg process is not running. exiting capture thread...
[2022-12-27 10:35:03] watchdog.pi_cam
ERROR : Ffmpeg process crashed unexpectedly for pi_cam.
ERROR : The following ffmpeg logs include the last 100 lines prior to exit.
[2022-12-27 10:35:03] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55731f8e50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:03] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:03] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:08] frigate.video
ERROR : pi_cam: Unable to read frames from ffmpeg process.
[2022-12-27 10:35:13] watchdog.pi_cam
[2022-12-27 10:35:13] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x5590e91e50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:13] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:13] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:18] frigate.video
[2022-12-27 10:35:23] watchdog.pi_cam
ErROR : Ffmpeg process crashed unexpectedly for pi_cam.
[2022-12-27 10:35:23] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x559675be50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:23] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:23] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:29] frigate.video
[2022-12-27 10:35:33] watchdog.pi_cam
[2022-12-27 10:35:33] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x557c7c0e50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:33] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:33] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:38] frigate.video
[2022-12-27 10:35:43] watchdog.pi_cam
[2022-12-27 10:35:43] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55a7358e50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:43] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:43] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:48] frigate.video
[2022-12-27 10:35:53] watchdog.pi_cam
[2022-12-27 10:35:53] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55a088ee50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:35:53] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:35:53] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:35:58] frigate.video
[2022-12-27 10:36:03] watchdog.pi_cam
[2022-12-27 10:36:03] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55b495ae50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:03] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:03] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:08] frigate.video
[2022-12-27 10:36:13] watchdog.pi_cam
[2022-12-27 10:36:13] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55b7c0ee50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:13] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:13] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:19] frigate.video
[2022-12-27 10:36:23] watchdog.pi_cam
[2022-12-27 10:36:23] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55a73cae50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:23] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:23] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:28] frigate.video
[2022-12-27 10:36:33] watchdog.pi_cam
[2022-12-27 10:36:33] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x5595ebce50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:33] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:33] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:38] frigate.video
[2022-12-27 10:36:43] watchdog.pi_cam
[2022-12-27 10:36:43] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55b17eae50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:43] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:43] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:49] frigate.video
[2022-12-27 10:36:53] watchdog.pi_cam
[2022-12-27 10:36:53] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x55a0f29e50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:36:53] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:36:53] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:36:59] frigate.video
[2022-12-27 10:37:03] watchdog.pi_cam
[2022-12-27 10:37:03] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x558766ae50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:37:03] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:37:03] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
[2022-12-27 10:37:09] frigate.video
[2022-12-27 10:37:13] watchdog.pi_cam
[2022-12-27 10:37:13] ffmpeg.pi_cam.detect ERROR : [rtsp @ 0x556933ae50] Could not find codec parameters for stream 0 (Video: h264, none): unspecified size
[2022-12-27 10:37:13] ffmpeg.pi_cam.detect ERROR : Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
[2022-12-27 10:37:13] ffmpeg.pi_cam.detect ERROR : Output file #0 does not contain any stream
Renseigner votre problème
Home Assistant 2022.12.8
Supervisor 2022.11.2
Operating System 9.4
Interface utilisateur : 20221213.1 - latest
Dans votre HA, Menu latéral
Paramètres
> Système
> Corrections
puis une fois en bas Copier
