J’ai cree mon sensor dans configuration.yaml et reboot mon sensor remonte bien puis 20s apres il me plante HA puis apres impossible de redemarrer HA
mqtt:
- name: "pv_router"
state_topic: "pvrouter/"
unit_of_measurement: "W"
device_class: power
value_template: "{{ value_json.svalue }}"
Voici mon debug MQtt de node red
{"topic":"pvrouter","payload":" { \"idx\" : 62 , \"svalue\" : \"-917\", \"nvalue\" : 2 } ","qos":0,"retain":false,"_msgid":"e397bac9b518df1f"}
Merci d’avance pour vos retour
version | core-2023.1.7 |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.10.7 |
os_name | Linux |
os_version | 5.15.90 |
arch | x86_64 |
timezone | Europe/Paris |
config_dir | /config |
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 4994 |
Installed Version | 1.30.0 |
Stage | running |
Available Repositories | 1262 |
Downloaded Repositories | 37 |
HACS Data | ok |
logged_in | true |
subscription_expiration | 15 février 2023 à 01:00 |
relayer_connected | true |
remote_enabled | true |
remote_connected | true |
alexa_enabled | true |
google_enabled | true |
remote_server | eu-central-1-2.ui.nabu.casa |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
host_os | Home Assistant OS 9.5 |
update_channel | stable |
supervisor_version | supervisor-2023.01.1 |
agent_version | 1.4.1 |
docker_version | 20.10.22 |
disk_total | 114.8 GB |
disk_used | 12.7 GB |
healthy | true |
supported | true |
board | generic-x86-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | ESPHome (2022.12.8), Samba share (10.0.0), Spotify Connect (0.12.2), tydom2mqtt (2.6.6), Terminal & SSH (9.6.1), Zigbee2MQTT (1.30.0-1), File editor (5.5.0), Duck DNS (1.15.0), tydom2mqtt (latest), Home Panel (2.5.0), Studio Code Server (5.5.2), Node-RED (14.0.2) |
dashboards | 2 |
resources | 22 |
views | 13 |
mode | storage |
oldest_recorder_run | 29 janvier 2023 à 21:19 |
current_recorder_run | 29 janvier 2023 à 22:19 |
estimated_db_size | 770.17 MiB |
database_engine | sqlite |
database_version | 3.38.5 |
Renseigner votre problème
Dans votre HA, Menu latéral
Paramètres
> Système
> Corrections
puis une fois en bas Copier
