2024-10-15 14:29:25.059 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-10-15 14:29:25.551 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-10-15 14:29:25.572 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=93 from 2024-10-15 12:22:16.955817)
2024-10-15 14:29:36.114 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7f77c73da3d0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) inside the event loop by integration 'freebox' at homeassistant/components/freebox/__init__.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/ssl.py, line 713: context.load_default_certs(purpose)), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+freebox%22
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 461, in _async_setup_component
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/setup.py", line 463, in <genexpr>
create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 742, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 594, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/freebox/__init__.py", line 26, in async_setup_entry
2024-10-15 14:29:36.129 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_verify_locations with args (<ssl.SSLContext object at 0x7f77c73da3d0>,) inside the event loop by integration 'freebox' at homeassistant/components/freebox/__init__.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/site-packages/freebox_api/aiofreepybox.py, line 78: ssl_ctx.load_verify_locations(cafile=cert_path)), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+freebox%22
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_verify_locations
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
create_eager_task(
2024-10-15 14:29:36.133 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (PosixPath('/config/.storage/freebox/h3td0r55_fbxos_fr.conf'), 'r') inside the event loop by integration 'freebox' at homeassistant/components/freebox/__init__.py, line 26: await api.open(entry.data[CONF_HOST], entry.data[CONF_PORT]) (offender: /usr/local/lib/python3.12/site-packages/freebox_api/aiofreepybox.py, line 255: with open(file, "r") as f:), please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+freebox%22
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#open
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
create_eager_task(
2024-10-15 14:29:37.143 WARNING (SyncWorker_1) [homeassistant.components.file.sensor] File or data not present at the moment: pool_pump_log.txt
2024-10-15 14:29:37.244 WARNING (MainThread) [homeassistant.components.freebox.router] Router Freebox Server (r2) API does not support RAID
2024-10-15 14:29:37.317 WARNING (MainThread) [homeassistant.components.freebox.router] Home access is not granted
Merci je n’avais pensé au log mais j’avoue ne pas comprendre grand chose.
