Salut à tous.
Après bien des galères et tests divers je suis presque arrivé à un fonctionnement automatique de ma ventile mais ce n’est pas parfait.
Je me retrouve avec deux flows. Un qui gère la Vmc suivant les températures externes et le second suivant la quantité de Co2 dans la maison. Comme dit plus haut je n’aime pas trop l’idée d’avoir un On On sur mon Fibaro FGS223. Et cela arrive encore, meme si cela n’a pas l’aire de le déranger.
Comment interagir entre les flows ? Ou peut-on ne faire qu’un Flows de ces deux flows ?
[{"id":"b0e1c2d036894a43","type":"tab","label":"Vmc T° ext haut","disabled":false,"info":"","env":[]},{"id":"410c36c5e4f0069a","type":"server-state-changed","z":"b0e1c2d036894a43","name":"exterieur","server":"330a1fbf.3e98d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.netatmo_jardin_temperature","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"dehors","propertyType":"msg","value":"","valueType":"entityState"}],"x":140,"y":120,"wires":[["ff9f2d9492104bfa"]]},{"id":"407e1a01961d2598","type":"server-state-changed","z":"b0e1c2d036894a43","name":"salon","server":"330a1fbf.3e98d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.netatmo_salon_temperature","entityidfiltertype":"exact","outputinitially":true,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"salon","propertyType":"msg","value":"","valueType":"entityState"}],"x":130,"y":240,"wires":[["18c6fe7785e9b3db"]]},{"id":"ff9f2d9492104bfa","type":"api-current-state","z":"b0e1c2d036894a43","name":"salon","server":"330a1fbf.3e98d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.netatmo_salon_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"salon","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":330,"y":140,"wires":[["20a16e861c237296"]]},{"id":"18c6fe7785e9b3db","type":"api-current-state","z":"b0e1c2d036894a43","name":"exterieur","server":"330a1fbf.3e98d","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.netatmo_jardin_temperature","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"exterieur","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":340,"y":220,"wires":[["20a16e861c237296"]]},{"id":"20a16e861c237296","type":"switch","z":"b0e1c2d036894a43","name":"","property":"exterieur","propertyType":"msg","rules":[{"t":"gte","v":"salon","vt":"msg"},{"t":"lt","v":"salon","vt":"msg"},{"t":"lt","v":"salon","vt":"msg"}],"checkall":"true","repair":false,"outputs":3,"x":570,"y":180,"wires":[["2ca6dfc332fbc422"],["c14897d3f4bb59f0"],["3e8fe18144937658"]]},{"id":"2ca6dfc332fbc422","type":"api-call-service","z":"b0e1c2d036894a43","name":"VMC OFF","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":760,"y":140,"wires":[[]]},{"id":"3e8fe18144937658","type":"api-call-service","z":"b0e1c2d036894a43","name":"VMC ON","server":"330a1fbf.3e98d","version":5,"debugenabled":true,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":760,"y":260,"wires":[[]]},{"id":"c14897d3f4bb59f0","type":"api-call-service","z":"b0e1c2d036894a43","name":"VMC GV stop","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":800,"y":200,"wires":[[]]},{"id":"330a1fbf.3e98d","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
[{"id":"1ebc8baf9030074a","type":"tab","label":"Vmc Sur Co2 haut","disabled":false,"info":"","env":[]},{"id":"51db46ed2f7f68f4","type":"server-state-changed","z":"1ebc8baf9030074a","name":"co2","server":"330a1fbf.3e98d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.netatmo_chambre_parents_co2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"co2","propertyType":"msg","value":"","valueType":"entityState"}],"x":150,"y":120,"wires":[["60f9626b87b38a1d"]]},{"id":"246614b0e94f4376","type":"server-state-changed","z":"1ebc8baf9030074a","name":"co2","server":"330a1fbf.3e98d","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.netatmo_salon_co2","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"num","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"salon","propertyType":"msg","value":"","valueType":"entityState"}],"x":150,"y":180,"wires":[["60f9626b87b38a1d"]]},{"id":"60f9626b87b38a1d","type":"switch","z":"1ebc8baf9030074a","name":"","property":"co2","propertyType":"msg","rules":[{"t":"gte","v":"1250","vt":"num"},{"t":"lt","v":"900","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":140,"wires":[["af02ceb6f3578c19"],["ce2f8390c02cce51"]]},{"id":"ea0b5eaadf299b49","type":"api-call-service","z":"1ebc8baf9030074a","name":"VMC GV ok","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":790,"y":120,"wires":[[]]},{"id":"38b77a8b9b8c934a","type":"api-call-service","z":"1ebc8baf9030074a","name":"VMC PV","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":780,"y":180,"wires":[[]]},{"id":"af02ceb6f3578c19","type":"api-call-service","z":"1ebc8baf9030074a","name":"VMC PV stop","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["sensor.conso_vmc_pv"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":60,"wires":[["ea0b5eaadf299b49"]]},{"id":"ce2f8390c02cce51","type":"api-call-service","z":"1ebc8baf9030074a","name":"VMC GV stop","server":"330a1fbf.3e98d","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.vmc_simple_flux_2"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":220,"wires":[["38b77a8b9b8c934a"]]},{"id":"330a1fbf.3e98d","type":"server","name":"Home Assistant","addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"","connectionDelay":false,"cacheJson":false,"heartbeat":false,"heartbeatInterval":"","statusSeparator":"","enableGlobalContextStore":false}]
Merci de vos idées car finalement je trouve node red efficace mais un poil compliquer a comprendre.
