Bonjour a vous,
Je reprends mon lovelace pour passe sur decluterring-card mais je ne comprends rien.
je suivie le tuto avec ce liens 'https://forum.hacf.fr/t/carte-decluttering-card-reduiser-vos-lignes-de-code-lovelace/4580/5
et ca fonctionne.
Quand je rentre ca dans mon lovelace j’ai bien le sun.sun qui fonctionne
decluttering_templates:
entity:
card:
type: entities
- entity: '[[entity]]'
icon: mdi:[[icon]]
secondary_info: last-updated
light_button_with_brightness:
tap_action:
action: toggle
hold_action:
action: more-info
layout: icon_label
show_label: true
label_template: >
var bri = Math.round(entity.attributes.brightness / 2.55); return (bri ?
bri : '0') + '%';
show_name: true
state:
- styles:
card:
- box-shadow: 0px 0px 10px 3px var(--paper-item-icon-active-color)
icon:
- color: var(--paper-item-icon-active-color)
value: 'on'
styles:
card:
- border-radius: 15px
- height: 76px
- width: 76px
- margin: 5px 5px 0px 0px
- padding: 0px 0px
- '--paper-card-background-color': rgba(40, 40, 40, 0.5)
grid:
- grid-template-rows: 42px auto 0px
- grid-template-columns: 42px auto
icon:
- width: 30px
- color: white
label:
- font-size: 12px
- font-weight: bold
- color: white
name:
- justify-self: start
- align-self: end
- padding: 9px 10px
- font-size: 12px
- font-weight: bold
- color: white
je cree la card
type: custom:button-card
template: light_button_with_brightness
entity: light.ampoule_salon_2
icon: mdi:lightbulb
Merci pour vos retours.
System Health
version
core-2022.3.3
installation_type
Home Assistant Supervised
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.9
os_name
Linux
os_version
4.19.0-17-amd64
arch
x86_64
timezone
Europe/Paris
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
2522
Installed Version
1.23.0
Stage
running
Available Repositories
1018
Downloaded Repositories
70
AccuWeather
can_reach_server
ok
remaining_requests
5
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Debian GNU/Linux 10 (buster)
update_channel
beta
supervisor_version
supervisor-2022.03.2
docker_version
20.10.8
disk_total
113.6 GB
disk_used
23.2 GB
healthy
true
supported
failed to load: Unsupported
supervisor_api
ok
version_api
ok
installed_addons
Samba share (9.5.1), MQTT Server & Web client (1.2.0), Terminal & SSH (9.3.0), Spotify Connect (0.10.0), Grafana (7.4.1), Tydom2MQTT - Beta (release_v1.2.4), InfluxDB (4.3.0), Glances (0.14.2), Dnsmasq (1.4.4), Duck DNS (1.14.0), Studio Code Server (4.1.0), File editor (5.3.3), Zigbee2mqtt (1.24.0-1), Zigbee2mqtt Edge (edge), ESPHome (2022.2.6), Node-RED (11.0.4), Check Home Assistant configuration (3.10.0), Mosquitto broker (6.0.1)
Lovelace
dashboards
3
resources
45
views
16
mode
storage
Spotify
api_endpoint_reachable
ok
Et c’est quoi le problème en fait…
Bob
Bob
Mars 10, 2022, 12:17
4
Je n’utilise pas ça mai il ne te manquerai pas ce petit bout :
entity:
default:
- name: Kitchen
- entity: light.ampoule_salon_2
- icon: mdi:lightbulb
Et comme le demanderai beaucoup ici, que veux tu faire exactement ?
@nonome1 Je pense que le message est plutôt explicit en fait « You should define either a card or an element in the template. »
Dans ton « light_button_with_brightness: » tu n’as pas de carte, ça n’a pas l’air comme ça dans le tuto.
:rolf:
je possede ca comme carte light
show_entity_picture: true
state:
- value: 'on'
color: rgb(201, 244, 254)
entity_picture: null
spin: false
styles:
name:
- color: rgb(0, 0, 0, 100%)
- font: bold italic 15px/30px roboto
- text-shadow: 2px 5px 8px rgb(255, 255, 254)
card:
- background-color: rgb(89, 166, 128, 100%)
- value: 'off'
styles:
name:
- color: rgb(89, 166, 128, 100%)
- text-shadow: 2px 5px 8px rgb(89, 166, 128)
styles:
card:
- margin: 0
- padding: 1
- font: 20px/35px Roboto
- background: null
- box-shadow: 0px 0px 10px rgb(89, 166, 128, 100%)
tap_action:
action: toggle
entity: switch.switchsalon_l1
aspect_ratio: 1/0.6
hold_action:
action: fire-dom-event
browser_mod:
command: popup
deviceID:
- this
- dashboard
title: Salon
style:
.mdc-dialog .mdc-dialog__container {
width: 40%;
.mdc-dialog .mdc-dialog__container .mdc-dialog__surface {
width:40%;
box-shadow:none;
:host {
--mdc-theme-surface: rgba(0,0,0,0);
--secondary-background-color: rgba(0,0,0,0);
--ha-card-background: rgba(0,0,0,0);
--ha-card-box-shadow: none;
--mdc-dialog-scrim-color: rgba(0,0,0,0.8);
--mdc-dialog-min-height: 100%;
--mdc-dialog-min-width: 100%;
--mdc-dialog-max-width: 100%;
mwc-icon-button {
color: #FFF;
card:
type: custom:light-popup-card
actionsInARow: 8
brightnessWidth: 150px
brightnessHeight: 400px
switchWidth: 150px
switchHeight: 400px
actions:
- color: '#8BCBDD'
service: automation.toggle
service_data:
entity_id: automation.rainbow_lampe_elena
settings:
openButton: Réglages
closeButton: Fermer
settingsCard:
type: entities
cardOptions:
- type: custom:button-card
toggle: true
je voudrais en faire un decluterring car j’ai 11 light donc a chaque modification 11 modification
