Déconnexions récurentes Zigbee 7.4.4 Sonoff Dongle E
Bonjour, je rencontre des déconnexions récurrentes au niveau de mon dongle SonOff model E avec le firmware 7.4.4 [GA] .
Voici un de mes logs :
> z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Circuit_Portail_Pompe', payload '{"current":0.1,"energy":0.01,"last_seen":"2024-12-19T06:42:43.387Z","linkquality":232,"power":7.6,"voltage":236.2}'
> [2024-12-19 07:42:43] info: 	zh:ember:uart:ash: Port closed.
> [2024-12-19 07:42:43] info: 	zh:ember:uart:ash: ======== ASH stopped ========
> [2024-12-19 07:42:43] info: 	zh:ember:ezsp: ======== EZSP stopped ========
> [2024-12-19 07:42:43] info: 	zh:ember: ======== Ember Adapter Stopped ========
> [2024-12-19 07:42:43] error: 	z2m: Adapter disconnected, stopping
> [2024-12-19 07:42:43] debug: 	zh:controller:endpoint: ZCL command 0xa4c13815a0a05094/1 manuSpecificTuya.mcuSyncTime({"payloadSize":8,"payload":[103,99,192,99,103,99,206,115]}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false})
> [2024-12-19 07:42:43] debug: 	zh:ember: ~~~> [ZCL to=0xa4c13815a0a05094:47781 apsFrame={"profileId":260,"clusterId":61184,"sourceEndpoint":1,"destinationEndpoint":1,"options":4416,"groupId":0,"sequence":0} header={"frameControl":{"reservedBits":0,"frameType":1,"direction":0,"disableDefaultResponse":false,"manufacturerSpecific":false},"transactionSequenceNumber":31,"commandIdentifier":36}]
> [2024-12-19 07:42:43] debug: 	zh:ember:ezsp: [SEND COMMAND] NOT CONNECTED
> [2024-12-19 07:42:44] debug: 	zh:ember: ~x~> [ZCL to=0x70ac08fffe11f60e:42635] Failed to send request attempt 1/3 with status=NETWORK_DOWN.
> [2024-12-19 07:42:44] debug: 	zh:ember:ezsp: [SEND COMMAND] NOT CONNECTED
> [2024-12-19 07:42:44] debug: 	zh:ember: ~x~> [ZCL to=0xa4c13815a0a05094:47781] Failed to send request attempt 1/3 with status=NETWORK_DOWN.
> [2024-12-19 07:42:46] debug: 	zh:ember: ~x~> [ZCL to=0x70ac08fffe11f60e:42635] Failed to send request attempt 2/3 with status=NETWORK_DOWN.
> [2024-12-19 07:42:46] debug: 	zh:ember:ezsp: [SEND COMMAND] NOT CONNECTED
> [2024-12-19 07:42:46] debug: 	zh:controller:endpoint: Error: ZCL command 0x70ac08fffe11f60e/1 manuSpecificTuya.defaultRsp({"cmdId":2,"statusCode":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"transactionSequenceNumber":98,"writeUndiv":false}) failed (~x~> [ZCL to=0x70ac08fffe11f60e:42635 apsFrame={"profileId":260,"clusterId":61184,"sourceEndpoint":1,"destinationEndpoint":1,"options":4352,"groupId":0,"sequence":0}] Failed to send request with status=NETWORK_DOWN.)
>     at /app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2110:27
>     at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
>     at EmberAdapter.sendZclFrameToEndpoint (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2070:16)
>     at Request.send (/app/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:82:20)
>     at Endpoint.sendRequest (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:325:20)
>     at Endpoint.zclCommand (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:951:28)
>     at Endpoint.defaultResponse (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:650:9)
>     at Device.onZclData (/app/node_modules/zigbee-herdsman/src/controller/model/device.ts:508:17)
>     at Controller.onZclPayload (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:976:13)
> [2024-12-19 07:42:46] debug: 	zh:controller:device: Default response to 0x70ac08fffe11f60e failed (Error: ZCL command 0x70ac08fffe11f60e/1 manuSpecificTuya.defaultRsp({"cmdId":2,"statusCode":0}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"transactionSequenceNumber":98,"writeUndiv":false}) failed (~x~> [ZCL to=0x70ac08fffe11f60e:42635 apsFrame={"profileId":260,"clusterId":61184,"sourceEndpoint":1,"destinationEndpoint":1,"options":4352,"groupId":0,"sequence":0}] Failed to send request with status=NETWORK_DOWN.))
> [2024-12-19 07:42:46] debug: 	zh:ember: ~x~> [ZCL to=0xa4c13815a0a05094:47781] Failed to send request attempt 2/3 with status=NETWORK_DOWN.
> [2024-12-19 07:42:46] debug: 	zh:controller:endpoint: Error: ZCL command 0xa4c13815a0a05094/1 manuSpecificTuya.mcuSyncTime({"payloadSize":8,"payload":[103,99,192,99,103,99,206,115]}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (~x~> [ZCL to=0xa4c13815a0a05094:47781 apsFrame={"profileId":260,"clusterId":61184,"sourceEndpoint":1,"destinationEndpoint":1,"options":4416,"groupId":0,"sequence":0}] Failed to send request with status=NETWORK_DOWN.)
>     at Endpoint.command (/app/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:723:23)
>     at Object.onEventSetLocalTime [as onEvent] (/app/node_modules/zigbee-herdsman-converters/src/lib/tuya.ts:238:13)
>     at OnEvent.callOnEvent (/app/lib/extension/onEvent.ts:50:13)
>     at OnEvent.stop (/app/lib/extension/onEvent.ts:37:13)
> [2024-12-19 07:42:46] debug: 	z2m: Saving state to file /config/zigbee2mqtt/state.json
> [2024-12-19 07:42:46] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'offline'
> [2024-12-19 07:42:46] info: 	z2m: Disconnecting from MQTT server
> [2024-12-19 07:42:46] info: 	z2m: Stopping zigbee-herdsman...
> [2024-12-19 07:42:46] debug: 	zh:controller:database: Writing database to '/config/zigbee2mqtt/database.db'
> [2024-12-19 07:42:57] info: 	z2m: Stopped zigbee-herdsman
> [2024-12-19 07:42:57] info: 	z2m: Stopped Zigbee2MQTT
Je suis sous la dernière version de HA. Si vous avec des astuces.
Bonne journée.
J’ai des déconnexions avec le dernier message des logs :
Après Zigbee2mqtt redémarre tout seul et reprend du service jusqu’au prochain zh:ember:uart:ash: Port closed.
Tu as bien ZHA qui est ignoré ?
Ça aurait été bien de mettre ta configuration du système ( comme demander dans un sujet d’entraide ).
Oui bien ignoré depuis le début (3 ans)
Mon système :
Pi4 avec SD 128Gb
  • Core2024.12.2
  • Supervisor2024.12.0
  • Operating System14.0
  • Interface utilisateur20241127.7
  • Version de Zigbee2MQTT [1.42.0]
    Type de coordinateur EmberZNet
    Révision du coordinateur 7.4.4 [GA]
As tu une rallonge USB sur la clé ?
As tu la clé sur un port USB2 ( port noir ) ?
Je suis bien en USB 2 avec une rallonge. Je suis passé provisoirement sur un PC standard x86, aucune déconnexion depuis hier. Je pense l’OS HA sur le Pi4 en avait un coup.
J’ai remis ce matin ma sauvegarde du PC sur mon Pi4 y’a bien un soucis sur le Pi4, ça saute comme avant.
Un problème d’alimentation ?
tu as une alimentation officielle 5V 3A ?
Tu es en HA OS 14.0, la dernière version de HA OS est actuellement 14.1 (mise à jour Linux kernel 6.6.51 > 6.6.62) : Release Home Assistant OS 14.1 · home-assistant/operating-system · GitHub
Il y a déjà eu des problèmes de gestion des ports USB en fonction de la version du kernel Linux.
Tu peux tenter de mettre à jour HA OS.
akenad :slight_smile:
Il peut tenter, mais je n’ai pas eu de soucis de port USB depuis que j’utilise un RPI4 avec HAOS ( 2 ans ). Avec une clé Sonoff P + une clé bluetooth sur port USB2 et un SSD sur un port USB3.
On dirait plus un souci d’alimentation.
