Je suis sous RPI4 avec Home Assistant, j’essaye de demander à mon Ecovacs Deebot ozmo 920 de nettoyer couloir par exemple, j’ai fait un scipt que je mets dans ma carte Vaccum il me dit « clean bedroom déclanché » mais rien ne se passe.
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:508
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 01:13:54 (2 occurrences)
Last logged: 01:14:45
The system cannot restart because the configuration is not valid: Component error: deebot - Integration 'deebot' not found.
______
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/__init__.py:518
Integration: Home Assistant WebSocket API (documentation, issues)
[2956906424] The system cannot restart because the configuration is not valid: Component error: deebot - Integration 'deebot' not found.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 518, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Component error: deebot - Integration 'deebot' not found.
