### Describe the issue you are experiencing
on RPI4: Lovelace interface hangs m…aybe an hour after the update to 15.2. Background automations still worked - but the interface not accessible either local or through Nabu. Downgrade after reset to 15.1 works stable now for half a day, so it looks really like a 15.2 issue. (Also checked was the core update to 2025.4.2 that seems innocent, as well as the Z-Wave JS UI update that did not showed to be the core of the trouble)
### What operating system image do you use?
rpi4-64 (Raspberry Pi 4/400 64-bit OS)
### What version of Home Assistant Operating System is installed?
15.2
### Did the problem occur after upgrading the Operating System?
Yes
### Hardware details
SkyConnect (ZigBee) ZBT1
ZW090 AEON Labs Z-wave Stick (Gen5)
### Steps to reproduce the issue
1.Update to HASS 15.2 and Core 2025.4.2 and Z-Wave JS UI
2.Lovelace hangs after a while(30min to 2h), automations still working (just UI hanging and not accessible through Browser (local and through Nabu)
3.Downgrade core to 2025.4.1 and downgrade Z-Wave JS UI
4.Lovelace working - but hanging after some time
5.Downgrade to HASS 15.1
6.All fine for > 1h
7.Update Core again to 2025.4.2 and latest Z-Wave JS UI
8.All fine still for >4h
### Anything in the Supervisor logs that might be useful for us?
```txt
2025-04-15 13:47:46.176 INFO (MainThread) [supervisor.os.manager] Completed download of OTA update file /data/tmp/hassos-15.2.raucb
2025-04-15 13:48:32.903 INFO (MainThread) [supervisor.os.manager] Install of Home Assistant Operating System 15.2 success
2025-04-15 13:48:32.906 INFO (MainThread) [supervisor.host.control] Initialize host reboot using logind
2025-04-15 13:48:32.917 INFO (MainThread) [supervisor.addons.manager] Phase 'application' stopping 2 add-ons
2025-04-15 13:48:32.947 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping addon_a0d7b954_nodered application
2025-04-15 13:48:33.493 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_nodered] Home Assistant WebSocket API closed
2025-04-15 13:48:33.496 INFO (MainThread) [supervisor.api.proxy] [a0d7b954_nodered] Home Assistant WebSocket API closed
2025-04-15 13:48:37.653 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
2025-04-15 13:48:37.846 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping addon_core_configurator application
2025-04-15 13:48:41.849 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_core_configurator application
2025-04-15 13:48:41.967 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant application
2025-04-15 13:49:06.140 INFO (MainThread) [supervisor.addons.manager] Phase 'services' stopping 0 add-ons
2025-04-15 13:49:06.141 INFO (MainThread) [supervisor.addons.manager] Phase 'system' stopping 1 add-ons
2025-04-15 13:49:06.158 INFO (SyncWorker_3) [supervisor.docker.manager] Stopping addon_a0d7b954_zwavejs2mqtt application
2025-04-15 13:49:36.753 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_zwavejs2mqtt application
2025-04-15 13:49:36.819 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' stopping 0 add-ons
2025-04-15 13:49:36.819 INFO (MainThread) [supervisor.plugins.cli] Stopping cli plugin
2025-04-15 13:49:36.826 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping hassio_cli application
2025-04-15 13:49:40.456 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning hassio_cli application
2025-04-15 13:49:40.520 INFO (MainThread) [supervisor.plugins.dns] Stopping CoreDNS plugin
2025-04-15 13:49:40.528 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping hassio_dns application
2025-04-15 13:49:44.315 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning hassio_dns application
2025-04-15 13:49:44.388 INFO (MainThread) [supervisor.plugins.audio] Stopping Audio plugin
2025-04-15 13:49:44.395 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping hassio_audio application
2025-04-15 13:49:48.429 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning hassio_audio application
2025-04-15 13:49:48.523 INFO (MainThread) [supervisor.plugins.multicast] Stopping Multicast plugin
2025-04-15 13:49:48.530 INFO (SyncWorker_7) [supervisor.docker.manager] Stopping hassio_multicast application
2025-04-15 13:49:52.056 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning hassio_multicast application
2025-04-15 13:49:52.584 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled tasks
2025-04-15 13:49:52.587 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitor
2025-04-15 13:49:52.588 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2
2025-04-15 13:49:52.594 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitor
2025-04-15 13:49:52.608 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.
2025-04-15 13:49:52.627 INFO (MainThread) [supervisor.core] Supervisor is down - 0
2025-04-15 13:49:52.629 INFO (MainThread) [__main__] Closing Supervisor
[11:49:52] INFO: Watchdog restart after closing
[11:49:53] WARNING: Halt Supervisor
[11:49:53] INFO: Supervisor restart after closing
cont-init: info: running /etc/cont-init.d/udev.sh
[20:01:32] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[20:01:32] INFO: Starting local supervisor watchdog...
### Anything in the Host logs that might be useful for us?
```txt
File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 270, in request
return await self.device.request(
...<11 lines>...
File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 378, in request
await send_request()
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 841, in request
await self.send_packet(
...<14 lines>...
File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 921, in send_packet
async with asyncio_timeout(
MESSAGE_SEND_TIMEOUT_MAINS
if not packet.extended_timeout
else MESSAGE_SEND_TIMEOUT_BATTERY
File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
raise TimeoutError from exc_val
TimeoutError
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1352, in handler
return await func(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 184, in async_turn_on
await self.entity_data.entity.async_turn_on(
...<6 lines>...
File "/usr/local/lib/python3.13/site-packages/zha/application/platforms/light/__init__.py", line 375, in async_turn_on
result = await self._level_cluster_handler.move_to_level_with_on_off(
...<2 lines>...
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 85, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
self.gen.throw(value)
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 70, in wrap_zigpy_exceptions
raise ZHAException("Failed to send request: device did not respond") from exc
zha.exceptions.ZHAException: Failed to send request: device did not respond
File "/usr/src/homeassistant/homeassistant/core.py", line 2814, in _run_service_call_catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2837, in _execute_service
return await target(service_call)
File "/config/custom_components/adaptive_lighting/hass_utils.py", line 62, in service_func_proxy
await existing_service.job.target(call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 648, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/zha/helpers.py", line 1354, in handler
raise HomeAssistantError(err) from err
homeassistant.exceptions.HomeAssistantError: Failed to send request: device did not respond[0m
[31m2025-04-15 23:33:24.393 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall light.turn_on (c:01JRXNXSXN:al:IFSG:ntrv:19): entity_id=['light.decke_tv_licht'], params=transition=45.0, color_temp=370, color_temp_kelvin=2702>
File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 926, in send_packet
send_status, _ = await req.result
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 68, in wrap_zigpy_exceptions
yield
File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 86, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File "/usr/local/lib/python3.13/site-packages/zigpy/util.py", line 136, in retry
return await func()
File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 378, in request
return await self._endpoint.request(
...<9 lines>...
...<11 lines>...
...<14 lines>...
### System information
## System Information
version | core-2025.4.2
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.2
os_name | Linux
os_version | 6.6.74-haos-raspi
arch | aarch64
timezone | Europe/Zurich
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
Installed Version | 2.0.5
Stage | running
Available Repositories | 1666
Downloaded Repositories | 6
</details>
logged_in | true
subscription_expiration |
relayer_connected | true
relayer_region | eu-central-1
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | false
cloud_ice_servers_enabled | true
remote_server | eu-central-1-3.ui.nabu.casa
certificate_status | ready
instance_id | 88c8cbbe6fa349098c7d40a2ddf568d4
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 15.1
update_channel | stable
### Additional information
_No response_
