Jeal
Août 2, 2025, 9:25
1
J’ai le message suivant dans mes logs zigbeemqtt
Je ne retrouve pas dans ma config trace de ce device
zh:controller:endpoint: Tried to get unknown/deleted device 0x385cfbfffee766f7 from endpoint 1.
Comment retouver
[center]## System Information
version
core-2025.7.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
container_arch
amd64
user
root
virtualenv
false
python_version
3.13.3
os_name
Linux
os_version
6.12.35-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
4994
Installed Version
2.0.5
Stage
running
Available Repositories
2122
Downloaded Repositories
7
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 16.0
update_channel
stable
supervisor_version
supervisor-2025.07.2
agent_version
1.7.2
docker_version
28.3.0
disk_total
116.7 GB
disk_used
5.7 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
false
virtualization
board
generic-x86-64
supervisor_api
ok
version_api
ok
installed_addons
Terminal & SSH (9.18.0), Mosquitto broker (6.5.1), File editor (5.8.0), Zigbee2MQTT (2.5.1-1)
dashboards
4
resources
5
views
7
mode
storage
Network Configuration
adapters
lo (disabled), enp1s0 (enabled, default, auto), hassio (disabled), docker0 (disabled), vethd9f8f15 (disabled), vethe0944b3 (disabled), veth70a1003 (disabled), vethad47f06 (disabled), vethc7a9625 (disabled), vetha2ecf84 (disabled), veth7399cec (disabled), veth976699a (disabled), vethac8a1b4 (disabled), veth2558754 (disabled)
ipv4_addresses
lo (127.0.0.1/8), enp1s0 (192.168.1.82/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), vethd9f8f15 (), vethe0944b3 (), veth70a1003 (), vethad47f06 (), vethc7a9625 (), vetha2ecf84 (), veth7399cec (), veth976699a (), vethac8a1b4 (), veth2558754 ()
ipv6_addresses
lo (::1/128), enp1s0 (fe80::5d4a:c91b:9ebd:3d01/64), hassio (fe80::d076:41ff:fe1e:aaff/64), docker0 (fe80::846f:70ff:fea9:3dc1/64), vethd9f8f15 (fe80::d8a6:52ff:fe7f:6760/64), vethe0944b3 (fe80::649a:ccff:fe15:59ab/64), veth70a1003 (fe80::9069:c1ff:fe11:b208/64), vethad47f06 (fe80::a065:49ff:feba:a01b/64), vethc7a9625 (fe80::b4d1:c2ff:fea8:ef27/64), vetha2ecf84 (fe80::2064:84ff:fe6a:5df4/64), veth7399cec (fe80::f0c8:ddff:fe36:a1f7/64), veth976699a (fe80::54ae:cfff:fecf:483b/64), vethac8a1b4 (fe80::cd6:bbff:fe55:a2a5/64), veth2558754 (fe80::9895:98ff:fed5:3f84/64)
announce_addresses
192.168.1.82, fe80::5d4a:c91b:9ebd:3d01
oldest_recorder_run
18 juillet 2025 à 14:22
current_recorder_run
2 août 2025 à 05:00
estimated_db_size
51.72 MiB
database_engine
sqlite
database_version
3.48.0
Hello @Jeal ,
Essaye de voir dans ton fichier addon_configs/xxx_zigbee2mqtt/zigbee2mqtt/configuration.yaml ou database.db si l’équipement n’apparait pas.
Jeal
Août 2, 2025, 10:42
3
l’appareil en question a du mal se comporter et a été blocklister dans Yaml config
j’ai donc aussi supprimer ce ligne et tout est ok, c’est suite a une plantage du module zigbeemqtt. je sais pas qui a pondu l’oeuf…
Je viens de decouvrir que mon indentation de la config zigbee était pas bonne et qui rendait instable cette integration… J’ai refait des tests en ce sens…
Je croise les doigts pour tout fonctionne encore quand je repasserais sur site, je n’ai pas de conenxion internet la bas…
Merci a toi pour tes indiquations
Je serais tenter de dire qu’on peut le supprimer mais je ne sais pas ce que c’est. Tu peux arrêter Z2M, renommer le fichier et redémarrer pour voir. Tu le supprimes si c’est ok après qqes temps
system
A fermé ce sujet ()
Août 5, 2025, 7:05
5
