Eaton Onduleur Ellipse PRO 650 FR / Intégration NUT impossible à configurer
J’ai branché mon UPS Eaton 650 pro en USB sur mon mini PC Proxmox.
Je tente en vain de remonter les infos dans HA malgré quelques lectures de topic en FR et EN.
Voici mon process :
  • Activation de l’USB dans ma VM HA sur Proxmox, onduleur reconnu :
Bus 001 Device 002: ID 0463:ffff MGE UPS Systems UPS
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0463 MGE UPS Systems
  idProduct          0xffff UPS
  bcdDevice            1.00
  iManufacturer           1 EATON
  iProduct                2 Ellipse PRO
  iSerial                 4 G354R28218
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               20mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bCountryCode           33 US
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength    1173
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              20
Device Status:     0x0001
  Self Powered
  • Installation de l’add-on NUT, elle démarre, voici le log :
s6-rc: info: service base-addon-timezone: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-timezone successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service base-addon-banner: starting
Add-on: Network UPS Tools
Manage battery backup (UPS) devices
Add-on version: 0.17.0
You are running the latest version of this add-on.
System: Home Assistant OS 16.3 (amd64 / qemux86-64)
Home Assistant Core: 2025.11.3
Home Assistant Supervisor: 2025.11.5
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-timezone: starting
s6-rc: info: service base-addon-log-level: starting
[21:34:05] INFO: Configuring timezone (Europe/Brussels)...
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service base-addon-timezone successfully started
cont-init: info: running /etc/cont-init.d/nut.sh
[21:34:06] INFO: Setting mode to netserver...
[21:34:06] INFO: Connected USB devices:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0627:0001 Adomax Technology Co., Ltd QEMU Tablet
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 009 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 002: ID 0463:ffff MGE UPS Systems UPS
Bus 010 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
[21:34:06] INFO: Generating /etc/nut/upsd.users...
[21:34:06] INFO: Configuring user: admin
[21:34:06] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[21:34:06] INFO: Configuring Device named myups...
[21:34:06] INFO: Starting the UPS drivers...
Using subdriver: MGE HID 1.46
Network UPS Tools - Generic HID driver 0.52 (2.8.1)
USB communication driver (libusb 1.0) 0.46
WARNING: Needed to fix group access to filesystem socket of this driver, but failed; run he driver with more debugging to see how exactly.
Consumers of the socket, such as upsd data server, can fail to interact with the driver and represent the device: /run/nut/usbhid-ups-myups
Network UPS Tools - UPS driver controller 2.8.1
[21:34:12] WARNING: UPS Shutdown will shutdown the host
cont-init: info: /etc/cont-init.d/nut.sh exited 0
cont-init: info: running /etc/cont-init.d/nutclient.sh
cont-init: info: /etc/cont-init.d/nutclient.sh exited 0
services-up: info: copying legacy longrun upsd (no readiness notification)
services-up: info: copying legacy longrun upsmon (no readiness notification)
[21:34:13] INFO: Starting the UPS information server...
0.000000 fopen /run/nut/upsd.pid: No such file or directory
0.000013 Could not find PID file '/run/nut/upsd.pid' to see if previous upsd instance is already running!
0.000220 [D1] debug level is '1'
0.000309 listening on 0.0.0.0 port 3493
0.000396 [D1] Succeeded to become_user(root): now UID=0 GID=0
0.000415 [D1] chdired into statepath /run/nut for driver sockets
0.000498 Connected to UPS [myups]: usbhid-ups-myups
0.000522 Found 1 UPS defined in ups.conf
0.000927 Running as foreground process, not saving a PID file
0.000952 upsnotify: notify about state 2 with libsystemd: was requested, but not running as a service unit now, will not spam more about it
0.000972 upsnotify: failed to notify about state 2: no notification tech defined, will not spam more about it
0.000985 upsnotify: logged the systemd watchdog situation once, will not spam more about it
[21:34:13] INFO: Starting the UPS monitor and shutdown controller...
0.000000 fopen /run/nut/upsmon.pid: No such file or directory
0.000016 Could not find PID file to see if previous upsmon instance is already running!
0.000261 Using power down flag file /etc/killpower
0.000431 UPS: myups@localhost (primary) (power value 1)
0.000525 [D1] debug level is '1'
0.000578 Warning: running as one big root process by request (upsmon -p)
0.000648 [D1] Saving PID 326 into /run/nut/upsmon.pid
Init SSL without certificate database
0.002493 upsnotify: notify about state 2 with libsystemd: was requested, but not running as a service unit now, will not spam more about it
0.002504 upsnotify: failed to notify about state 2: no notification tech defined, will not spam more about it
0.002507 upsnotify: logged the systemd watchdog situation once, will not spam more about it
0.002509 [D1] Trying to connect to UPS [myups@localhost]
0.511156 User upsmonmaster@127.0.0.1 logged into UPS [myups]
0.003390 [D1] Logged into UPS myups@localhost``
Merci déjà à ceux qui prendront la peine de me lire et de mon répondre :slight_smile:
Belle soirée à tous !
|Version|core-2025.11.3|
|Type d’installation|Home Assistant OS|
|Développement|false|
|Supervisor|true|
|Docker|true|
|Architecture des conteneurs|amd64|
|Utilisateur|root|
|Environnement virtuel|false|
|Version de Python|3.13.9|
|Famille du système d’exploitation|Linux|
|Version du système d’exploitation|6.12.51-haos|
|Architecture du processeur|x86_64|
|Fuseau horaire|Europe/Brussels|
|Répertoire de configuration|/config|
Dans la configuration de l’intégration, pour local host, il faut mettre le nom d’hôte que tu as dans le module complémentaire nuts. a0d7b954-nut
Tu peux déjà commencer par ça.
4 « J'aime »
Dans mon cas j’ai monté nut dans proxmox et je connecté l’intégration de HA sur le nut de proxmox ce qui est bien plus logique
Un tout grand merci, cela fonctionne !
Fallait le savoir :sweat_smile:
C’est noté dans la doc d’installation, mais j’ai eu le problème aussi, je suis passé trop rapidement sur la doc.
Bonjour, cela tombe bien. Car j’ai un onduleur eaton 3s 700fr.
J’avais cru comprendre qu’il fallait passer par un raspberry pi avant pour qu’il soit visiblement par HA.
Je peux le connecter directement sur le nuc avec le cable usb b vers usb a ?
en l’ajoutant avec proxmox
Merci d’avance
oui tout a fait
moi j préfère l’ajouter directement dans proxmox plutot que le passthrough dans HA
ça me permet de monitorer l’onduleur directement dans proxmox puis j’ai connecté dans HA le nut de proxmox j’ai ainsi tous les sensors dans HA
Il faudra que je regarde cela
alors, merci =)
du coup j’ai pas besoin du raspberry pi =)
non aucun besoin d’un rpi
