Je viens de recevoir une Home Assistant Green et il m’est impossible de terminer l’installation initiale.
Ci dessous le contenu du fichier de log.
Que me conseillez vous ?
Merci pour votre aide.
cont-init: info: running /etc/cont-init.d/udev.sh
[10:48:17] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[10:48:17] INFO: Starting local supervisor watchdog...
24-02-16 10:48:21 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-16 11:48:21 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
24-02-16 11:48:21 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.01.1
24-02-16 11:48:21 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-02-16 11:48:21 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.10.0']
24-02-16 11:48:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-16 11:48:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 11:48:23 INFO (MainThread) [__main__] Setting up Supervisor
24-02-16 11:48:23 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-16 11:48:23 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-16 11:48:23 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-16 11:48:24 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 11:48:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 11:48:24 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 11:48:24 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-16 11:48:24 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-16 11:48:24 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-16 11:48:24 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.06.0
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-16 11:48:25 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.06.0
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-16 11:48:25 INFO (MainThread) [supervisor.plugins.manager] cli does not have the latest version 2023.11.0, updating
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-cli:2023.06.0 to ghcr.io/home-assistant/aarch64-hassio-cli:2023.11.0
24-02-16 11:48:25 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-cli with tag 2023.11.0.
24-02-16 11:48:32 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_cli application
24-02-16 11:48:40 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-16 11:48:40 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-cli:2023.06.0']
24-02-16 11:48:40 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-16 11:48:41 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-16 11:48:41 INFO (MainThread) [supervisor.plugins.manager] audio does not have the latest version 2023.12.0, updating
24-02-16 11:48:41 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/aarch64-hassio-audio:2023.06.0 to ghcr.io/home-assistant/aarch64-hassio-audio:2023.12.0
24-02-16 11:48:41 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-audio with tag 2023.12.0.
24-02-16 11:53:27 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping hassio_audio application
24-02-16 11:53:32 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-16 11:53:32 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-audio:2023.06.0']
24-02-16 11:53:33 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-16 11:53:33 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-16 11:53:33 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-16 11:53:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/green-homeassistant with version landingpage
24-02-16 11:53:33 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-16 11:53:33 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
24-02-16 11:53:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-02-16 11:53:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-16 11:53:34 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-16 11:53:35 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-16 11:53:35 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-16 11:53:35 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-16 11:53:35 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-16 11:53:35 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 11:53:35 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-16 11:53:35 INFO (MainThread) [__main__] Running Supervisor
24-02-16 11:53:35 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-16 11:53:35 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-16 11:53:35 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-16 11:53:35 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-16 11:53:35 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-16 11:53:35 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-16 11:53:35 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-16 11:53:35 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-16 11:53:35 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-16 11:53:35 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 11:53:35 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 11:53:35 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-16 11:53:35 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-16 11:53:35 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-16 11:53:36 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-16 11:53:37 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 11:53:37 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 11:53:37 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 11:53:37 WARNING (SyncWorker_3) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-16 11:53:37 INFO (MainThread) [supervisor.host.manager] Host information reload completed
[11:23:42] INFO: Using udev information from host
[11:23:43] INFO: Starting local supervisor watchdog...
24-02-16 11:23:48 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-16 12:23:48 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
24-02-16 12:23:48 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.01.1
24-02-16 12:23:48 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-16 12:23:48 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:23:48 INFO (MainThread) [__main__] Setting up Supervisor
24-02-16 12:23:48 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-16 12:23:49 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-16 12:23:49 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-16 12:23:49 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 12:23:49 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 12:23:49 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-16 12:23:50 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 12:23:50 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-16 12:23:50 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-16 12:23:50 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-16 12:23:50 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-02-16 12:23:50 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-16 12:23:50 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-16 12:23:51 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-16 12:23:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-16 12:23:51 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-16 12:23:51 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-02-16 12:23:52 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-16 12:23:52 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-16 12:23:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-02-16 12:23:52 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-16 12:23:52 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-16 12:23:53 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-16 12:23:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-16 12:23:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-16 12:23:53 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-16 12:23:53 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-02-16 12:23:54 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-02-16 12:23:54 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-16 12:23:54 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/green-homeassistant with version landingpage
24-02-16 12:23:54 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-16 12:23:54 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-16 12:23:54 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
24-02-16 12:23:54 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:23:56 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-16 12:23:56 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-02-16 12:23:56 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-16 12:23:57 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-16 12:23:57 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-16 12:23:57 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-16 12:23:57 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-16 12:23:57 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:23:57 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-16 12:23:57 INFO (MainThread) [__main__] Running Supervisor
24-02-16 12:23:57 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-16 12:23:57 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-16 12:23:57 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-16 12:23:57 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-16 12:23:57 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-16 12:23:57 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-16 12:23:57 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-16 12:23:57 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-16 12:23:57 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-16 12:23:57 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:23:57 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:23:57 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-16 12:23:57 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 12:23:57 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-16 12:23:57 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-16 12:23:57 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 12:23:57 WARNING (SyncWorker_2) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-16 12:23:57 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-16 12:23:58 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:23:58 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-16 12:23:58 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
[11:33:47] INFO: Using udev information from host
[11:33:47] INFO: Starting local supervisor watchdog...
24-02-16 11:33:52 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-16 12:33:53 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
24-02-16 12:33:53 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.01.1
24-02-16 12:33:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-16 12:33:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:33:53 INFO (MainThread) [__main__] Setting up Supervisor
24-02-16 12:33:58 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-16 12:33:58 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-16 12:33:58 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-16 12:33:59 WARNING (MainThread) [supervisor.dbus.timedate] No timedate support on the host. Time/Date functions have been disabled.
24-02-16 12:33:59 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 12:33:59 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 12:33:59 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-16 12:33:59 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-16 12:34:04 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
24-02-16 12:34:04 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Cannot connect to host services.home-assistant.io:443 ssl:default [Try again]
24-02-16 12:34:04 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-16 12:34:09 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
24-02-16 12:34:09 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-02-16 12:34:09 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-16 12:34:09 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-16 12:34:10 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-16 12:34:10 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-16 12:34:10 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-16 12:34:10 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-02-16 12:34:11 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-16 12:34:11 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-16 12:34:16 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-02-16 12:34:16 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-16 12:34:16 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-16 12:34:17 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-16 12:34:17 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-16 12:34:17 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-16 12:34:17 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-16 12:34:17 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-02-16 12:34:18 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-02-16 12:34:18 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-16 12:34:18 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/green-homeassistant with version landingpage
24-02-16 12:34:18 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-16 12:34:18 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:34:18 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
24-02-16 12:34:18 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-16 12:34:19 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:34:19 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-16 12:34:19 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:34:20 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-16 12:34:20 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:34:20 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-16 12:34:20 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-16 12:34:20 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-02-16 12:34:21 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
24-02-16 12:34:21 INFO (SyncWorker_3) [supervisor.docker.manager] Starting homeassistant
24-02-16 12:34:21 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-16 12:34:21 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-16 12:34:21 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-16 12:34:21 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-16 12:34:21 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-16 12:34:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-16 12:34:21 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 12:34:21 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-16 12:34:21 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:34:21 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-16 12:34:21 INFO (MainThread) [__main__] Running Supervisor
24-02-16 12:34:21 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-16 12:34:21 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-16 12:34:22 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-16 12:34:22 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-16 12:34:22 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-16 12:34:22 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-16 12:34:22 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-16 12:34:22 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-16 12:34:22 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-16 12:34:22 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:34:22 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:34:22 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-16 12:34:22 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-16 12:34:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-16 12:34:22 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1261' coro=<HostManager.reload() done, defined at /usr/src/supervisor/supervisor/host/manager.py:127> exception=DBusInterfaceMethodError('Failed to read RTC: Invalid argument')>
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 108, in call_dbus
return await getattr(proxy_interface, method)(
File "/usr/local/lib/python3.12/site-packages/dbus_fast/aio/proxy_object.py", line 108, in method_fn
BaseProxyInterface._check_method_return(msg, intr_method.out_signature)
File "/usr/local/lib/python3.12/site-packages/dbus_fast/proxy_object.py", line 80, in _check_method_return
raise DBusError._from_message(msg)
dbus_fast.errors.DBusError: Failed to read RTC: Invalid argument
File "/usr/src/supervisor/supervisor/host/manager.py", line 129, in reload
await self.info.update()
File "/usr/src/supervisor/supervisor/host/info.py", line 153, in update
await self.sys_dbus.timedate.update()
File "/usr/src/supervisor/supervisor/dbus/interface.py", line 127, in update
self.properties = await self.dbus.get_properties(self.properties_interface)
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 205, in get_properties
return await self.properties.call_get_all(interface)
File "/usr/src/supervisor/supervisor/utils/dbus.py", line 113, in call_dbus
raise DBus.from_dbus_error(err)
supervisor.exceptions.DBusInterfaceMethodError: Failed to read RTC: Invalid argument
24-02-16 12:34:22 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:34:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:34:27 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
24-02-16 12:34:27 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-16 12:34:27 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-16 12:34:32 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
24-02-16 12:34:32 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-16 12:34:37 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
24-02-16 12:34:37 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 12:34:37 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-16 12:34:37 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:34:37 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-16 12:34:37 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-16 12:34:52 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:34:52 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:34:52 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:34:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:35:22 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:35:22 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:35:22 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:35:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:35:52 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:35:52 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:35:52 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:35:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:36:22 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:36:22 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:36:22 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:36:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:36:52 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:36:52 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:36:52 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:36:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:37:22 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:37:22 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:37:22 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:37:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:37:52 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:37:52 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:37:52 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:37:52 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:38:22 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:38:22 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:38:23 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:38:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:38:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/usb/hiddev0 - None
24-02-16 12:38:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw0 - None
24-02-16 12:38:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/mouse0 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:38:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/event1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:38:38 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw1 - None
24-02-16 12:38:38 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/mouse1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:38:38 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/event2 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:38:38 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw2 - None
24-02-16 12:38:38 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/002/002 - None
24-02-16 12:38:53 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:38:53 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:38:53 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:38:53 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:39:23 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:39:23 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:39:23 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:39:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:39:36 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/002/003 - None
24-02-16 12:39:36 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/usb/hiddev0 - None
24-02-16 12:39:36 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw0 - None
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/mouse0 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw1 - None
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/mouse1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event2 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:39:37 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw2 - None
24-02-16 12:39:53 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:39:53 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:39:53 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:39:53 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:39:58 INFO (MainThread) [supervisor.core] Starting repair of Supervisor Environment
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Prune stale containers
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Prune stale images
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Prune stale builds
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Prune stale volumes
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Prune stale networks
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Fix stale container on hassio network
24-02-16 12:39:58 INFO (SyncWorker_3) [supervisor.docker.manager] Fix stale container on host network
24-02-16 12:39:58 INFO (MainThread) [supervisor.jobs] 'AddonManager.repair' blocked from execution, no host internet connection
24-02-16 12:39:58 INFO (MainThread) [supervisor.jobs] 'HomeAssistantCore.repair' blocked from execution, no host internet connection
24-02-16 12:39:58 INFO (MainThread) [supervisor.supervisor] Repairing Supervisor 2024.01.1
24-02-16 12:39:58 INFO (MainThread) [supervisor.core] Finished repair of Supervisor Environment
24-02-16 12:40:23 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:40:23 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:40:23 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:40:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:40:53 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:40:53 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:40:53 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:40:53 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:41:23 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:41:23 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:41:23 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:41:23 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-02-16 12:41:52 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/usb/hiddev0 - None
24-02-16 12:41:52 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw0 - None
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/mouse0 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/event1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw1 - None
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/mouse1 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-mouse
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/input/event2 - /dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/hidraw2 - None
24-02-16 12:41:53 INFO (MainThread) [supervisor.hardware.monitor] Detecting remove hardware /dev/bus/usb/002/003 - None
24-02-16 12:41:53 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:41:53 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:41:53 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/green-homeassistant:2024.2.1: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.2.1&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error ("Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io: Temporary failure in name resolution")
24-02-16 12:41:53 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[11:49:05] INFO: Using udev information from host
[11:49:05] INFO: Starting local supervisor watchdog...
24-02-16 11:49:11 INFO (MainThread) [__main__] Initializing Supervisor setup
24-02-16 12:49:11 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
24-02-16 12:49:11 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.01.1
24-02-16 12:49:11 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-02-16 12:49:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:49:11 INFO (MainThread) [__main__] Setting up Supervisor
24-02-16 12:49:11 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-02-16 12:49:11 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-02-16 12:49:11 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-02-16 12:49:12 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 12:49:12 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 12:49:12 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
24-02-16 12:49:12 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 12:49:12 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
24-02-16 12:49:12 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-02-16 12:49:12 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-02-16 12:49:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0
24-02-16 12:49:13 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-02-16 12:49:13 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
24-02-16 12:49:13 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2023.11.0 - 172.30.32.5
24-02-16 12:49:13 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2
24-02-16 12:49:14 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-02-16 12:49:14 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
24-02-16 12:49:14 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-02-16 12:49:15 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-02-16 12:49:15 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
24-02-16 12:49:15 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-02-16 12:49:15 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
24-02-16 12:49:16 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
24-02-16 12:49:16 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
24-02-16 12:49:16 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2
24-02-16 12:49:16 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-02-16 12:49:16 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
24-02-16 12:49:17 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2023.06.2 - Host
24-02-16 12:49:17 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-02-16 12:49:17 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/green-homeassistant found.
24-02-16 12:49:17 INFO (MainThread) [supervisor.homeassistant.core] Setting up Home Assistant landingpage
24-02-16 12:49:17 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag landingpage.
24-02-16 12:49:21 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-02-16 12:49:21 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-02-16 12:49:21 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/green-homeassistant with version landingpage
24-02-16 12:49:21 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.1 / BootSlot A
24-02-16 12:49:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
24-02-16 12:49:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
24-02-16 12:49:23 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
24-02-16 12:49:23 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-02-16 12:49:23 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-02-16 12:49:23 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-02-16 12:49:23 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-02-16 12:49:23 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-02-16 12:49:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-02-16 12:49:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 12:49:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-02-16 12:49:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:49:23 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
24-02-16 12:49:23 INFO (MainThread) [__main__] Running Supervisor
24-02-16 12:49:23 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-02-16 12:49:23 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
24-02-16 12:49:23 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
24-02-16 12:49:23 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
24-02-16 12:49:24 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-02-16 12:49:24 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
24-02-16 12:49:24 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-02-16 12:49:24 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-02-16 12:49:24 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-02-16 12:49:24 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/green-homeassistant:landingpage to ghcr.io/home-assistant/green-homeassistant:2024.2.1
24-02-16 12:49:24 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/green-homeassistant with tag 2024.2.1.
24-02-16 12:49:24 INFO (MainThread) [supervisor.host.info] Updating local host information
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-02-16 12:49:24 INFO (MainThread) [supervisor.host.services] Updating service information
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-02-16 12:49:24 INFO (MainThread) [supervisor.host.network] Updating local network information
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-02-16 12:49:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-02-16 12:49:24 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
24-02-16 12:49:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
