J’utilise HA OS dans une VM Proxmox avec une clé bluetooth Trust 15542-05 (« Qualcomm Atheros Communications AR3011 Bluetooth » retourné par lsusb)
L’intégration Bluetooth finit en « Echec de la configuration »
Merci d’avance pour toute aide.
Pour info :
Mes logs
2024-01-09 18:35:25.661 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to recover bluetooth adapter hci0 with mac address 00:02:72:B0:A5:6C
2024-01-09 18:35:25.661 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to power cycle bluetooth adapter hci0 [00:02:72:B0:A5:6C]
2024-01-09 18:35:25.662 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Found adapters from hci: {0: {'dev_id': 0, 'name': 'hci0', 'bdaddr': '00:02:72:B0:A5:6C', 'flags': 5, 'type': 1, 'features': <ifaddr._shared.c_ubyte_Array_8 object at 0x7f66f7c82b10>, 'pkt_type': 52472, 'link_policy': 7, 'link_mode': 32768, 'acl_mtu': 1022, 'acl_pkts': 8, 'sco_mtu': 121, 'sco_pkts': 3, 'stat': <bluetooth_adapters.systems.linux_hci.hci_dev_stats object at 0x7f66f7c82ba0>}}
2024-01-09 18:35:25.662 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Found adapter 00:02:72:B0:A5:6C in hci device as 0
2024-01-09 18:35:25.662 DEBUG (MainThread) [bluetooth_auto_recovery.recover] hci0 (00:02:72:B0:A5:6C) idx is 0
2024-01-09 18:35:25.663 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Attempting to power cycle bluetooth adapter hci0 [00:02:72:B0:A5:6C]
2024-01-09 18:35:25.663 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2024-01-09 18:35:25.663 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2024-01-09 18:35:25.663 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2024-01-09 18:35:25.663 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2024-01-09 18:35:25.663 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding address as type Address
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding bluetooth_version as type IntUL
2024-01-09 18:35:25.664 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding manufacturer as type IntUL
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding supported_settings as type IntUL
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding class_of_device as type IntUL
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding name as type Name
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding short_name as type IntUL
2024-01-09 18:35:25.665 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=283> <command_opcode=ReadControllerInformation, status=Success> <address=00:02:72:B0:A5:6C, bluetooth_version=5, manufacturer=69, supported_settings=69887, current_settings={Powered: True, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: False, Advertising: False, SecureConnections: False, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}, class_of_device=7077888, name=b'homeassistant', short_name=0>
2024-01-09 18:35:25.666 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Current power state of bluetooth adapter is ON.
2024-01-09 18:35:25.666 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding powered as type IntUL
2024-01-09 18:35:25.666 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2024-01-09 18:35:25.666 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2024-01-09 18:35:25.666 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2024-01-09 18:35:25.667 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2024-01-09 18:35:25.667 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2024-01-09 18:35:25.667 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2024-01-09 18:35:25.667 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=7> <command_opcode=SetPowered, status=Success> <current_settings={Powered: False, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: False, Advertising: False, SecureConnections: False, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}>
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2024-01-09 18:35:25.668 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding class_of_device as type IntUL
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket read <event_code=ClassOfDeviceChangedEvent, controller_idx=0, param_len=3> <class_of_device=0>
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding address as type Address
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding bluetooth_version as type IntUL
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding manufacturer as type IntUL
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding supported_settings as type IntUL
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding name as type Name
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding short_name as type IntUL
2024-01-09 18:35:25.669 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=283> <command_opcode=ReadControllerInformation, status=Success> <address=00:02:72:B0:A5:6C, bluetooth_version=5, manufacturer=69, supported_settings=69887, current_settings={Powered: False, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: False, Advertising: False, SecureConnections: False, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}, class_of_device=0, name=b'homeassistant', short_name=0>
2024-01-09 18:35:25.670 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Bouncing Bluetooth adapter hci0
2024-01-09 18:35:25.670 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Setting hci0 down
2024-01-09 18:35:26.171 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Setting hci0 up
2024-01-09 18:35:27.774 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Finished bouncing hci0
2024-01-09 18:35:27.774 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding powered as type IntUL
2024-01-09 18:35:27.774 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2024-01-09 18:35:27.774 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2024-01-09 18:35:27.774 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding event_code as type EvtCode
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding controller_idx as type Controller
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding param_len as type ParamLen
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding command_opcode as type CmdCode
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding status as type Status
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=7> <command_opcode=SetPowered, status=Success> <current_settings={Powered: True, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: False, Advertising: False, SecureConnections: False, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}>
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding cmd_code as type CmdCode
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding controller_idx as type Controller
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Encoding param_len as type ParamLen
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding address as type Address
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding bluetooth_version as type IntUL
2024-01-09 18:35:27.775 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding manufacturer as type IntUL
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding supported_settings as type IntUL
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding current_settings as type CurrentSettings
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding class_of_device as type IntUL
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding name as type Name
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Decoding short_name as type IntUL
2024-01-09 18:35:27.776 DEBUG (MainThread) [btsocket.btmgmt_protocol] Socket Read: <event_code=CommandCompleteEvent, controller_idx=0, param_len=283> <command_opcode=ReadControllerInformation, status=Success> <address=00:02:72:B0:A5:6C, bluetooth_version=5, manufacturer=69, supported_settings=69887, current_settings={Powered: True, Connectable: False, FastConnectable: False, Discoverable: False, Bondable: False, LinkLevelSecurity: False, SecureSimplePairing: True, BREDR: True, HighSpeed: False, LowEnergy: False, Advertising: False, SecureConnections: False, DebugKeys: False, Privacy: False, ControllerConfiguration: False, StaticAddress: False, PHYConfiguration: False, WidebandSpeech: False}, class_of_device=7077888, name=b'homeassistant', short_name=0>
2024-01-09 18:35:27.776 DEBUG (MainThread) [bluetooth_auto_recovery.recover] Power state of bluetooth adapter hci0 [00:02:72:B0:A5:6C] is ON after power cycle
| version |
core-2024.1.2 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.11.6 |
| os_name |
Linux |
| os_version |
6.1.71-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 11.4 |
| update_channel |
stable |
| supervisor_version |
supervisor-2023.12.0 |
| agent_version |
1.6.0 |
| docker_version |
24.0.7 |
| disk_total |
30.8 GB |
| disk_used |
4.5 GB |
| healthy |
true |
| supported |
true |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Advanced SSH & Web Terminal (17.0.2) |
| dashboards |
1 |
| resources |
0 |
| mode |
auto-gen |
| oldest_recorder_run |
7 janvier 2024 à 14:45 |
| current_recorder_run |
9 janvier 2024 à 18:14 |
| estimated_db_size |
0.68 MiB |
| database_engine |
sqlite |
| database_version |
3.41.2 |
