Intégration enphase indisponible depuis quelques jours :
Cette erreur provient d’une intégration personnalisée
Logger: homeassistant.config_entries
Source: custom_components/enphase_envoy/init.py:131
Integration: Enphase Envoy (DEV)
First occurred: 14:37:09 (1 occurrences)
Last logged: 14:37:09
Error setting up entry Envoy 122239063542 for enphase_envoy
File « /usr/src/homeassistant/homeassistant/config_entries.py », line 387, in async_setup
result = await component.async_setup_entry(hass, self)
File « /config/custom_components/enphase_envoy/init.py », line 131, in async_setup_entry
hass.config_entries.async_setup_platforms(entry, PLATFORMS)
AttributeError: ‹ ConfigEntries › object has no attribute ‹ async_setup_platforms ›
version |
core-2023.5.2 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.11 |
os_name |
Linux |
os_version |
6.1.21-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.32.1 |
Stage |
running |
Available Repositories |
1352 |
Downloaded Repositories |
11 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
pending |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 10.1 |
update_channel |
stable |
supervisor_version |
supervisor-2023.04.1 |
agent_version |
1.5.1 |
docker_version |
23.0.3 |
disk_total |
28.5 GB |
disk_used |
6.8 GB |
healthy |
true |
supported |
true |
board |
rpi3-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Duck DNS (1.15.0), File editor (5.6.0), Samba share (10.0.1), Terminal & SSH (9.7.0), Home Assistant Google Drive Backup (0.110.4), AppDaemon (0.12.2), Mosquitto broker (6.2.1), MyElectricalData (0.8.16), Filebrowser (2.23.0-5) |
dashboards |
1 |
resources |
3 |
views |
6 |
mode |
storage |
oldest_recorder_run |
25 avril 2023 à 17:25 |
current_recorder_run |
8 mai 2023 à 14:33 |
estimated_db_size |
170.71 MiB |
database_engine |
sqlite |
database_version |
3.40.1 |
Sonoff
version |
3.5.1 (122751c) |
cloud_online |
0 / 1 |
local_online |
0 / 0 |
Voir ici… integration not working Enphase Envoy (DEV) · Issue #92562 · home-assistant/core · GitHub
Et la solution semble être d’utiliser une autre intégration (maintenue celle-ci) pour enphase.
Effectivement golfvert, la solution fonctionne bien.
Merci beaucoup
Dans HACS, j’ai ajouté le dépôt suivant : GitHub - briancmpbll/home_assistant_custom_envoy et ensuite installé l’intégration.
Après le redémarrage de HA et la mise à jour vers 2023.5.4, l’intégration fonctionne correctement.
