j’ai quelques erreurs dans le journal et j’ai quelqu’une que je n’ai pas réussi à résoudre
voici le journal complet
2024-06-10 02:27:01.918 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-10 02:27:01.920 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration battery_notes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-06-10 02:27:03.889 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2024-06-10 02:27:05.876 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-06-10 02:27:12.600 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.helpers.event. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from event directly at custom_components/hacs/base.py, line 642: self.hass.helpers.event.async_track_time_interval(, please create a bug report at https://github.com/hacs/integration/issues
2024-06-10 02:47:31.120 WARNING (Thread-7) [pychromecast.socket_client] [Chromecast Salon(192.168.1.87):8009] Heartbeat timeout, resetting connection
2024-06-10 02:47:42.593 ERROR (Thread-7) [pychromecast.socket_client] [Chromecast Salon(192.168.1.87):8009] Failed to connect to service HostServiceInfo(host='192.168.1.87', port=8009), retrying in 5.0s
2024-06-10 02:51:41.830 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547021938624] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 241, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2741, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2784, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 145, in async_handle_turn_service
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1002, in entity_service_call
raise result from None
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1601, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1049, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 637, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File "/usr/src/homeassistant/homeassistant/components/zha/light.py", line 471, in async_turn_off
result = await self._on_off_cluster_handler.off()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 81, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
self.gen.throw(value)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 73, in wrap_zigpy_exceptions
raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver packet: <TXStatus.NWK_ROUTE_DISCOVERY_FAILED: 208>
2024-06-10 05:15:25.529 ERROR (MainThread) [zigpy.zcl] [0x87DB:1:0x0020] Traceback (most recent call last):
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 342, in request
return await req.result
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 377, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 265, in request
return await self.device.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 341, in request
async with asyncio_timeout(timeout):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
raise TimeoutError from exc_val
TimeoutError
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/general.py", line 631, in check_in_response
await self.checkin_response(True, self.CHECKIN_FAST_POLL_TIMEOUT, tsn=tsn)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 64, in wrap_zigpy_exceptions
homeassistant.exceptions.HomeAssistantError: Failed to send request: device did not respond
2024-06-10 06:10:13.626 ERROR (MainThread) [zigpy.zcl] [0x87DB:1:0x0020] Traceback (most recent call last):
TimeoutError
2024-06-10 06:29:08.828 WARNING (MainThread) [zigpy_deconz.zigbee.application] Unexpected transmit confirm for request id 123, Status: TXStatus.SUCCESS
2024-06-10 07:05:01.739 ERROR (MainThread) [zigpy.zcl] [0x87DB:1:0x0020] Traceback (most recent call last):
TimeoutError
2024-06-10 07:59:09.255 ERROR (MainThread) [zigpy.zcl] [0x87DB:1:0x0020] Traceback (most recent call last):
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request
await send_request()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request
await self.send_packet(
File "/usr/local/lib/python3.12/site-packages/zigpy_deconz/zigbee/application.py", line 530, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver packet: <TXStatus.MAC_TRANSACTION_EXPIRED: 240>
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to deliver packet: <TXStatus.MAC_TRANSACTION_EXPIRED: 240>
2024-06-10 10:32:35.892 WARNING (MainThread) [zigpy_deconz.zigbee.application] Unexpected transmit confirm for request id 240, Status: TXStatus.SUCCESS
[center]## System Information
| version |
core-2024.6.1 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.12.2 |
| os_name |
Linux |
| os_version |
6.6.28-haos-raspi |
| arch |
aarch64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.34.0 |
| Stage |
running |
| Available Repositories |
1392 |
| Downloaded Repositories |
2 |
| HACS Data |
ok |
| logged_in |
true |
| subscription_expiration |
19 juin 2024 à 02:00 |
| relayer_connected |
true |
| relayer_region |
eu-central-1 |
| remote_enabled |
true |
| remote_connected |
true |
| alexa_enabled |
true |
| google_enabled |
true |
| remote_server |
eu-central-1-4.ui.nabu.casa |
| certificate_status |
ready |
| instance_id |
a828aec66441480ab4ca9092fe4c848e |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 12.3 |
| update_channel |
stable |
| supervisor_version |
supervisor-2024.06.0 |
| agent_version |
1.6.0 |
| docker_version |
25.0.5 |
| disk_total |
219.3 GB |
| disk_used |
6.3 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
| board |
rpi5-64 |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
File editor (5.8.0), Node-RED (17.0.13), Advanced SSH & Web Terminal (18.0.0) |
| dashboards |
2 |
| resources |
0 |
| views |
0 |
| mode |
storage |
| oldest_recorder_run |
9 juin 2024 à 21:04 |
| current_recorder_run |
10 juin 2024 à 02:27 |
| estimated_db_size |
6.11 MiB |
| database_engine |
sqlite |
| database_version |
3.44.2 |
[/center]
