Bonsoir,
j’ai créer ce script et malgré tout mes efforts voici mon erreur
« Unexpected error calling config validator: ‹ NoneType › object is not iterable » je ne vois pas le souci
vendredi_soir_lumière: null
alias: Lumière Shabbat
description: Allume les lumières et désactive les automatisations pour Shabbat
platform: state
entity_id: binary_sensor.jewish_calendar_issur_melacha_in_effect
to: on
condition:
- condition: time
weekday: fri
- service: switch.turn_on
entity_id: switch.bandeau_plaque
entity_id: switch.salle_de_bain
entity_id: switch.couloir_toilettes_right
- service: homeassistant.turn_off
entity_id: automation.detection_wc_2
entity_id: automation.detection_wc_nocturne
- service: light.turn_on
entity_id: light.lampe_sejour
brightness: 255
- wait_template: '{{ states.sensor.time.state == "23:00" }}'
- service: switch.turn_off
brightness: 127
merci
version |
core-2023.3.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.10 |
os_name |
Linux |
os_version |
5.15.90 |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.31.0 |
Stage |
running |
Available Repositories |
1320 |
Downloaded Repositories |
40 |
HACS Data |
ok |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 9.5 |
update_channel |
stable |
supervisor_version |
supervisor-2023.03.1 |
agent_version |
1.4.1 |
docker_version |
20.10.22 |
disk_total |
50.5 GB |
disk_used |
13.9 GB |
healthy |
true |
supported |
true |
board |
ova |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Samba share (10.0.0), File editor (5.5.0), Studio Code Server (5.5.3), Home Assistant Google Drive Backup (0.105.2), Mosquitto broker (6.1.3), Samba Backup (5.2.0), Check Home Assistant configuration (3.11.0), Terminal & SSH (9.6.1), Log Viewer (0.14.0), ESPHome (2022.3.1), MariaDB (2.5.2), Nginx Proxy Manager (0.12.3), Vaultwarden (Bitwarden) (0.19.0), Zigbee2MQTT (1.30.2-1), ESPHome (2023.2.4) |
dashboards |
1 |
resources |
24 |
views |
10 |
mode |
storage |
oldest_recorder_run |
12 mars 2023 à 08:00 |
current_recorder_run |
14 mars 2023 à 19:33 |
estimated_db_size |
298.65 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
Tu as essayé en virant la 1ere ligne et dans l’ui ?
Syntaxiquement c’est pas correct sinon (ou alors c’est un raté dans ton copié/collé)
Merci tu veux dire le vendredi soir lumiere ?
oui
ça donne ça ici
et une fois sorti du mode yaml
merci encore mais nouveau souci je ne le trouve pas dans mes scripts malgré un redémarrage c’est normal?
