Erreur de la configuration de périphériques zeegbee depuis MAJ du dongle-e vers le FW 7.4.3
Develco HESZB-120 control via MQTT | Zigbee2MQTT
[2024-06-02 09:47:56] info: |
z2m:mqtt: MQTT publish: topic ‹ zigbee2mqtt/bridge/response/device/configure ›, payload ‹ {data:{id:Alarme incendie palier 1},error:Failed to configure (Bind 0x0015bc00310209af/35 genBasic from ‹ 0xe0798dfffe9f1856/1 › failed ([ZDO] Failed response by NCP for \18555\ cluster \32801\ with status=ZDP_TABLE_FULL.)),status:error,transaction:yhwyx-1} › |
[2024-06-02 09:47:58] info: |
z2m:mqtt: MQTT publish: topic ‹ zigbee2mqtt/Alarme incendie palier 1 ›, payload ‹ {alarm:null,battery:100,battery_low:false,enrolled:true,fault:false,ias_cie_address:0xe0798dfffe9f1856,linkquality:128,max_duration:240,reliability:no_fault_detected,restore_reports:true,smoke:false,supervision_reports:true,temperature:19.06,test:false,update:{installed_version:262152,latest_version:262152,state:idle},update_available:null,voltage:3000,zone_id:23} › |
Chose étonnante, il y a le message d’erreur ( 2024-06-02 09:47:56 ) , puis tout semble correcte (2024-06-02 09:47:58)
Qu’en pensez-vous ?
version |
core-2024.5.5 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.6.29-haos |
arch |
x86_64 |
timezone |
Europe/Brussels |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4998 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1393 |
Downloaded Repositories |
21 |
logged_in |
true |
subscription_expiration |
18 novembre 2024 à 01:00 |
relayer_connected |
true |
relayer_region |
eu-central-1 |
remote_enabled |
true |
remote_connected |
true |
alexa_enabled |
false |
google_enabled |
true |
remote_server |
eu-central-1-14.ui.nabu.casa |
certificate_status |
ready |
instance_id |
f7e4a448d0ea4e549014b68e0f39ac80 |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 12.3 |
update_channel |
stable |
supervisor_version |
supervisor-2024.05.1 |
agent_version |
1.6.0 |
docker_version |
25.0.5 |
disk_total |
439.4 GB |
disk_used |
17.9 GB |
healthy |
true |
supported |
true |
board |
generic-x86-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
ESPHome (2024.5.4), File editor (5.8.0), Terminal & SSH (9.14.0), Home Assistant Google Drive Backup (0.112.1), Mosquitto broker (6.4.1), Zigbee2MQTT (1.38.0-1), SQLite Web (4.1.2), MQTT Explorer (browser-1.0.1), FTP (5.0.2), Studio Code Server (5.15.0), Grafana (10.0.0), InfluxDB (5.0.0), Spotify Connect (0.13.0), Music Assistant (2.0.4) |
dashboards |
3 |
resources |
10 |
views |
16 |
mode |
storage |
oldest_recorder_run |
1 juin 2024 à 18:05 |
current_recorder_run |
1 juin 2024 à 22:22 |
estimated_db_size |
216.65 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
Solcast PV Forecast
can_reach_server |
ok |
used_requests |
2 |
rooftop_site_count |
1 |
Spotify
api_endpoint_reachable |
ok |
Les erreurs semblent avoir disparus avec le temps. Donc, tout roule pour le moment.
