Bonsoir,
System Health
version | core-2021.3.4 |
dev | false |
hassio | true |
docker | true |
virtualenv | false |
python_version | 3.8.7 |
os_name | Linux |
os_version | 5.4.83-v8 |
arch | aarch64 |
timezone | Europe/Paris |
GitHub API | ok |
Github API Calls Remaining | 4672 |
Installed Version | 1.11.3 |
Stage | running |
Available Repositories | 780 |
Installed Repositories | 22 |
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | ok |
Hass.io
host_os | Home Assistant OS 5.12 |
update_channel | stable |
supervisor_version | supervisor-2021.03.9 |
docker_version | 19.03.13 |
disk_total | 116.7 GB |
disk_used | 17.3 GB |
healthy | true |
supported | true |
board | rpi4-64 |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (9.3.1), Mosquitto broker (5.1.1), ADB - Android Debug Bridge (0.8.0), deCONZ (6.8.0), InfluxDB (4.0.4), Grafana (6.2.0), Node-RED (8.2.1), Let’s Encrypt (4.11.0), ESPHome (1.16.2), Samba Backup (4.5.0), File editor (5.2.0), Visual Studio Code (3.3.0), Z-Wave JS to MQTT (0.9.1) |
Lovelace
dashboards | 7 |
resources | 15 |
views | 23 |
mode | storage |
j’ai des erreurs récurrentes malgré redémarrage dans le log du superviseur :
21-04-06 21:52:45 ERROR (MainThread) [supervisor.api.ingress] Ingress error: 400, message='Invalid response status', url=URL('http://172.30.33.1:8099/socket.io/?EIO=4&transport=websocket&sid=j6CTXS0XVaXcX2edAAAK')
21-04-06 22:00:54 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-2882' coro=<HomeAssistantWebSocket.async_supervisor_update_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:133> exception=TypeError('Received message 8:1000 is not str')>
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 138, in async_supervisor_update_event
await self.async_send_command(
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 129, in async_send_command
return await self._client.async_send_command(message)
File "/usr/src/supervisor/supervisor/homeassistant/websocket.py", line 46, in async_send_command
response = await self.client.receive_json()
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py", line 291, in receive_json
data = await self.receive_str(timeout=timeout)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py", line 276, in receive_str
raise TypeError(f"Received message {msg.type}:{msg.data!r} is not str")
TypeError: Received message 8:1000 is not str
et le core est aussi en erreur :
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7daee940>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-04-07 00:07:31 ERROR (SyncWorker_4) [pynetgear_enhanced] Connection error: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7c2cd160>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 169, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 96, in create_connection
raise err
File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 86, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 394, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 234, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.8/http/client.py", line 1255, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1301, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1250, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.8/http/client.py", line 1010, in _send_output
self.send(msg)
File "/usr/local/lib/python3.8/http/client.py", line 950, in send
self.connect()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 200, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f7c2cd160>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 573, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7c2cd160>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.8/site-packages/pynetgear_enhanced/__init__.py", line 102, in _make_request
response = requests.post(self.soap_url, headers=headers,
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 119, in post
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.0.9', port=5000): Max retries exceeded with url: /soap/server_sa/ (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f7c2cd160>: Failed to establish a new connection: [Errno 111] Connection refused'))
2021-04-07 00:07:36 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 4464 100 4464 0 0 272k 0 --:--:-- --:--:-- --:--:-- 290k
2021-04-07 00:07:37 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2021-04-07 00:07:46 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2021-04-07 00:07:47 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2021-04-07 00:07:56 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2021-04-07 00:07:57 ERROR (MainThread) [homeassistant.components.upnp] Unexpected error fetching Freebox Server data: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 151, in async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 139, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 156, in async_get_traffic_data
values = await asyncio.gather(
File "/usr/local/lib/python3.8/site-packages/async_upnp_client/profiles/igd.py", line 89, in async_get_total_bytes_received
result = await action.async_call()
File "/usr/local/lib/python3.8/site-packages/async_upnp_client/client.py", line 519, in async_call
raise UpnpError('Error during async_call(), status: %s, body: %s' %
async_upnp_client.client.UpnpError: Error during async_call(), status: 500, body: <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>401</errorCode><errorDescription>Invalid Action</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
2021-04-07 00:08:06 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
2021-04-07 00:08:16 ERROR (MainThread) [homeassistant.components.alexa.state_report] Error when sending ChangeReport to Alexa: INVALID_ACCESS_TOKEN_EXCEPTION: Access token is not valid.
Que faut-il que je fasse pour supprimer ces erreurs superviseur et core ?
Merci à tous
