> s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.0.1
You are running the latest version of this add-on.
System: Home Assistant OS 9.4 (aarch64 / raspberrypi3-64)
Home Assistant Core: 2023.1.7
Home Assistant Supervisor: 2022.12.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
[18:57:56] FATAL:
[18:57:56] FATAL: Configuration of this add-on is incomplete.
[18:57:56] FATAL:
[18:57:56] FATAL: Please be sure to set the "credential_secret" option.
[18:57:56] FATAL:
[18:57:56] FATAL: The credential secret is an encryption token, much like
[18:57:56] FATAL: a password, that is used by Node-RED for encrypting
[18:57:56] FATAL: credentials you put into Node-RED.
[18:57:56] FATAL:
[18:57:56] FATAL: Just like a password, a credential secret can be
[18:57:56] FATAL: anything you like. Just be sure to store it somewhere
[18:57:56] FATAL: safe for later, e.g., in case of a recovery.
[18:57:56] FATAL:
s6-rc: warning: unable to start service init-nodered: command exited 1
[18:57:57] FATAL:
[18:57:57] FATAL: SSL has been enabled using the 'ssl' option,
[18:57:57] FATAL: this requires a SSL certificate file which is
[18:57:57] FATAL: configured using the 'certfile' option in the
[18:57:57] FATAL: add-on configuration.
[18:57:57] FATAL:
[18:57:57] FATAL: Unfortunately, the file specified in the
[18:57:57] FATAL: 'certfile' option does not exists.
[18:57:57] FATAL:
[18:57:57] FATAL: Please ensure the certificate file exists and
[18:57:57] FATAL: is placed in the '/ssl/' directory.
[18:57:57] FATAL:
[18:57:57] FATAL: In case you don't have SSL yet, consider getting
[18:57:57] FATAL: a SSL certificate or setting the 'ssl' option
[18:57:57] FATAL: to 'false' in case you are not planning on using
[18:57:57] FATAL: SSL with this add-on.
[18:57:57] FATAL:
[18:57:57] FATAL: Check the add-on manual for more information.
[18:57:57] FATAL:
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
prog: fatal: stopping the container.
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
[19:41:11] FATAL:
[19:41:11] FATAL: SSL has been enabled using the ‹ ssl › option,
[19:41:11] FATAL: this requires a SSL certificate file which is
[19:41:11] FATAL: configured using the ‹ certfile › option in the
[19:41:11] FATAL: add-on configuration.
[19:41:11] FATAL:
[19:41:11] FATAL: Unfortunately, the file specified in the
[19:41:11] FATAL: ‹ certfile › option does not exists.
[19:41:11] FATAL:
[19:41:11] FATAL: Please ensure the certificate file exists and
[19:41:11] FATAL: is placed in the ‹ /ssl/ › directory.
[19:41:11] FATAL:
[19:41:11] FATAL: In case you don’t have SSL yet, consider getting
[19:41:11] FATAL: a SSL certificate or setting the ‹ ssl › option
[19:41:11] FATAL: to ‹ false › in case you are not planning on using
[19:41:11] FATAL: SSL with this add-on.
[19:41:11] FATAL:
[19:41:11] FATAL: Check the add-on manual for more information.
