Me revoilà encore à faire appel à la communauté et je m’en excuse par avance.
J’ai un ESP 32 pour faire une station météo.
J’ai un capteur bme280, bh1750, un capteur d’uv.
J’ai également un pluviomètre à bascule.
J’ai essayé d’en faire la programmation. Malheureusement, malgré les pluies, je n’ai pas de remonté de donnée.
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/station-meteo.yaml...
INFO Detected timezone 'Europe/Paris'
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from 192.168.1.41 using esphome API
INFO Successfully connected to station-meteo @ 192.168.1.41 in 0.010s
INFO Successful handshake with station-meteo @ 192.168.1.41 in 0.104s
[15:40:11][I][app:100]: ESPHome version 2024.9.2 compiled on Oct 3 2024, 14:18:14
[15:40:11][C][wifi:600]: WiFi:
[15:40:11][C][wifi:428]: Local MAC: E4:65:B8:E7:28:50
[15:40:11][C][wifi:433]: SSID: [redacted]
[15:40:11][C][wifi:436]: IP Address: 192.168.1.41
[15:40:11][C][wifi:440]: BSSID: [redacted]
[15:40:11][C][wifi:441]: Hostname: 'station-meteo'
[15:40:11][C][wifi:443]: Signal strength: -67 dB ▂▄▆█
[15:40:11][C][wifi:447]: Channel: 1
[15:40:11][C][wifi:448]: Subnet: 255.255.255.0
[15:40:11][C][wifi:449]: Gateway: 192.168.1.254
[15:40:11][C][wifi:450]: DNS1: 0.0.0.0
[15:40:11][C][wifi:451]: DNS2: 0.0.0.0
[15:40:11][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
[15:40:11][C][logger:185]: Logger:
[15:40:11][C][logger:186]: Level: DEBUG
[15:40:11][C][logger:188]: Log Baud Rate: 115200
[15:40:11][C][logger:189]: Hardware UART: UART0
[15:40:11][C][i2c.arduino:071]: I2C Bus:
[15:40:11][C][i2c.arduino:072]: SDA Pin: GPIO21
[15:40:11][C][i2c.arduino:073]: SCL Pin: GPIO22
[15:40:11][C][i2c.arduino:074]: Frequency: 50000 Hz
[15:40:11][C][i2c.arduino:086]: Recovery: bus successfully recovered
[15:40:11][I][i2c.arduino:096]: Results from i2c bus scan:
[15:40:11][I][i2c.arduino:102]: Found i2c device at address 0x77
[15:40:11][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:11][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:11][C][i2c.arduino:072]: SDA Pin: GPIO18
[15:40:11][C][i2c.arduino:073]: SCL Pin: GPIO19
[15:40:11][I][i2c.arduino:102]: Found i2c device at address 0x5C
[15:40:11][C][uptime.sensor:033]: Uptime Sensor 'Station_meteo_Allumé depuis (s)'
[15:40:11][C][uptime.sensor:033]: Device Class: 'duration'
[15:40:11][C][uptime.sensor:033]: State Class: 'total_increasing'
[15:40:11][C][uptime.sensor:033]: Unit of Measurement: 's'
[15:40:11][C][uptime.sensor:033]: Accuracy Decimals: 0
[15:40:11][C][uptime.sensor:033]: Icon: 'mdi:timer-outline'
[15:40:12][C][uptime.sensor:034]: Type: Seconds
[15:40:12][C][template.sensor:022]: Template Sensor 'Station_meteo_UV index'
[15:40:12][C][template.sensor:022]: State Class: ''
[15:40:12][C][template.sensor:022]: Unit of Measurement: ''
[15:40:12][C][template.sensor:022]: Accuracy Decimals: 0
[15:40:12][C][template.sensor:022]: Icon: 'mdi:sun-wireless'
[15:40:12][C][template.sensor:023]: Update Interval: 60.0s
[15:40:12][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
[15:40:12][C][template.sensor:022]: Template Sensor 'station_meteo_compteur_pluviometre'
[15:40:12][C][template.sensor:022]: Unit of Measurement: 'bascules'
[15:40:12][C][template.sensor:023]: Update Interval: 2.0s
[15:40:12][C][template.sensor:022]: Template Sensor 'station_meteo_pluie_du_jour'
[15:40:12][C][template.sensor:022]: Device Class: 'precipitation'
[15:40:12][C][template.sensor:022]: State Class: 'total_increasing'
[15:40:12][C][template.sensor:022]: Unit of Measurement: 'mm'
[15:40:12][C][template.sensor:022]: Accuracy Decimals: 3
[15:40:12][C][template.sensor:022]: Icon: 'mdi:water'
[15:40:12][C][template.sensor:023]: Update Interval: 10.0s
[15:40:12][C][template.sensor:022]: Template Sensor 'station_meteo_pluie_veille'
[15:40:12][C][template.sensor:022]: State Class: 'total'
[15:40:12][C][template.sensor:022]: Icon: 'mdi:water-clock'
[15:40:12][C][template.sensor:023]: Update Interval: never
[15:40:12][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:12][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:12][C][template.text_sensor:020]: Template Sensor 'Station_meteo_Allumé depuis (j)'
[15:40:12][C][template.text_sensor:020]: Icon: 'mdi:clock-start'
[15:40:12][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'station_meteo_pluviometre_Trigger'
[15:40:12][C][gpio.binary_sensor:016]: Pin: GPIO12
[15:40:12][C][status:034]: Status Binary Sensor 'Station_meteo_Statut'
[15:40:12][C][status:034]: Device Class: 'connectivity'
[15:40:12][C][bme280_i2c.sensor:025]: Address: 0x77
[15:40:12][C][bme280.sensor:182]: BME280:
[15:40:12][C][bme280.sensor:194]: IIR Filter: OFF
[15:40:12][C][bme280.sensor:195]: Update Interval: 10.0s
[15:40:12][C][bme280.sensor:197]: Temperature 'station_meteo_temperature_extérieure'
[15:40:12][C][bme280.sensor:197]: Device Class: 'temperature'
[15:40:12][C][bme280.sensor:197]: State Class: 'measurement'
[15:40:12][C][bme280.sensor:197]: Unit of Measurement: '°C'
[15:40:12][C][bme280.sensor:197]: Accuracy Decimals: 2
[15:40:12][C][bme280.sensor:197]: Icon: 'mdi:water-percent'
[15:40:12][C][bme280.sensor:198]: Oversampling: 16x
[15:40:12][C][bme280.sensor:199]: Pressure 'station_meteo_pression'
[15:40:12][C][bme280.sensor:199]: Device Class: 'atmospheric_pressure'
[15:40:12][C][bme280.sensor:199]: State Class: 'measurement'
[15:40:12][C][bme280.sensor:199]: Unit of Measurement: 'hPa'
[15:40:12][C][bme280.sensor:199]: Accuracy Decimals: 0
[15:40:12][C][bme280.sensor:200]: Oversampling: 16x
[15:40:12][C][bme280.sensor:201]: Humidity 'station_meteo_humidite_exterieure'
[15:40:12][C][bme280.sensor:201]: Device Class: 'humidity'
[15:40:12][C][bme280.sensor:201]: State Class: 'measurement'
[15:40:12][C][bme280.sensor:201]: Unit of Measurement: '%'
[15:40:12][C][bme280.sensor:201]: Accuracy Decimals: 0
[15:40:12][C][bme280.sensor:202]: Oversampling: 16x
[15:40:12][C][bh1750.sensor:118]: BH1750 'station_meteo_luminosite'
[15:40:12][C][bh1750.sensor:118]: Device Class: 'illuminance'
[15:40:12][C][bh1750.sensor:118]: State Class: 'measurement'
[15:40:12][C][bh1750.sensor:118]: Unit of Measurement: 'lux'
[15:40:12][C][bh1750.sensor:118]: Accuracy Decimals: 1
[15:40:12][C][bh1750.sensor:119]: Address: 0x5C
[15:40:12][C][bh1750.sensor:124]: Update Interval: 10.0s
[15:40:12][C][adc:097]: ADC Sensor 'Station_meteo_UV'
[15:40:12][C][adc:097]: Device Class: 'voltage'
[15:40:12][C][adc:097]: State Class: 'measurement'
[15:40:12][C][adc:097]: Unit of Measurement: 'V'
[15:40:12][C][adc:097]: Accuracy Decimals: 3
[15:40:12][C][adc:107]: Pin: GPIO33
[15:40:12][C][adc:113]: Attenuation: 0db
[15:40:12][C][adc:141]: Samples: 1
[15:40:12][C][adc:142]: Update Interval: 60.0s
[15:40:12][C][restart:068]: Restart Switch 'Station_meteo_Redémarrage'
[15:40:12][C][restart:070]: Icon: 'mdi:restart'
[15:40:12][C][restart:091]: Restore Mode: always OFF
[15:40:12][C][homeassistant.time:010]: Home Assistant Time:
[15:40:12][C][homeassistant.time:011]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[15:40:12][C][captive_portal:089]: Captive Portal:
[15:40:12][C][web_server:145]: Web Server:
[15:40:12][C][web_server:146]: Address: 192.168.1.41:80
[15:40:12][C][mdns:116]: mDNS:
[15:40:12][C][mdns:117]: Hostname: station-meteo
[15:40:12][C][esphome.ota:073]: Over-The-Air updates:
[15:40:12][C][esphome.ota:074]: Address: 192.168.1.41:3232
[15:40:12][C][esphome.ota:075]: Version: 2
[15:40:12][C][esphome.ota:078]: Password configured
[15:40:12][C][safe_mode:018]: Safe Mode:
[15:40:12][C][safe_mode:020]: Boot considered successful after 60 seconds
[15:40:12][C][safe_mode:021]: Invoke after 10 boot attempts
[15:40:12][C][safe_mode:023]: Remain in safe mode for 300 seconds
[15:40:12][C][api:139]: API Server:
[15:40:12][C][api:140]: Address: 192.168.1.41:6053
[15:40:12][C][api:142]: Using noise encryption: YES
[15:40:12][C][wifi_signal.sensor:010]: WiFi Signal 'Station_meteo_Signal Wifi'
[15:40:12][C][wifi_signal.sensor:010]: Device Class: 'signal_strength'
[15:40:12][C][wifi_signal.sensor:010]: State Class: 'measurement'
[15:40:12][C][wifi_signal.sensor:010]: Unit of Measurement: 'dBm'
[15:40:12][C][wifi_signal.sensor:010]: Accuracy Decimals: 0
[15:40:13][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
[15:40:13][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:13][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:14][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
[15:40:14][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:14][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:15][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:15][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:15][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
[15:40:16][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state ON
[15:40:16][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[15:40:16][D][binary_sensor:036]: 'station_meteo_pluviometre_Trigger': Sending state OFF
Ben déja comme indiqué par ESPHome quand tu compiles tu vas utiliser un autre GPIO que le 12 pour détecter tes coupelles car c’est un GPIO qui a des fonctions système !
Ensuite une fois recablé sur un autre GPIO retester pour voir si les impulsions remontent toujours pas ou si c’est bon cette fois-ci
Je viens de faire une modification du cablage. Je l’ai mis sur le GPIO14.
Je n’ai pas de remonté de basculement. Par contre, j’ai toujours un basculement on/off permanent de station_meteo_pluviometre_Trigger sans en comprendre la raison.
parfait comme ça déja ça évite un soucis de moins et tu as mis à jour le sketch et rechargé l’esp Hein
Essaye en commentant pour le moment le Lambda pour être sur que cela ne soit pas la source du problème mais je pencherais plutot pour un soucis mécanique. On est d’accord que tu captes le switch de tes coupelles entre le GPIO14 et soit GND soit le 3.3V ?
tu récupères bien un contact sec inerte ? pas d’alimentation dessus ?
INFO Successfully connected to station-meteo @ 192.168.1.41 in 0.005s
INFO Successful handshake with station-meteo @ 192.168.1.41 in 0.085s
[22:46:30][I][app:100]: ESPHome version 2024.9.2 compiled on Oct 3 2024, 17:54:33
[22:46:30][C][wifi:600]: WiFi:
[22:46:30][C][wifi:428]: Local MAC: E4:65:B8:E7:28:50
[22:46:30][C][wifi:433]: SSID: [redacted]
[22:46:30][C][wifi:436]: IP Address: 192.168.1.41
[22:46:30][C][wifi:440]: BSSID: [redacted]
[22:46:30][C][wifi:441]: Hostname: 'station-meteo'
[22:46:30][C][wifi:443]: Signal strength: -65 dB ▂▄▆█
[22:46:30][C][wifi:447]: Channel: 1
[22:46:30][C][wifi:448]: Subnet: 255.255.255.0
[22:46:30][C][wifi:449]: Gateway: 192.168.1.254
[22:46:30][C][wifi:450]: DNS1: 0.0.0.0
[22:46:30][C][wifi:451]: DNS2: 0.0.0.0
[22:46:30][C][logger:185]: Logger:
[22:46:31][C][logger:186]: Level: DEBUG
[22:46:31][C][logger:188]: Log Baud Rate: 115200
[22:46:31][C][logger:189]: Hardware UART: UART0
[22:46:31][C][i2c.arduino:071]: I2C Bus:
[22:46:31][C][i2c.arduino:072]: SDA Pin: GPIO21
[22:46:31][C][i2c.arduino:073]: SCL Pin: GPIO22
[22:46:31][C][i2c.arduino:074]: Frequency: 50000 Hz
[22:46:31][C][i2c.arduino:086]: Recovery: bus successfully recovered
[22:46:31][I][i2c.arduino:096]: Results from i2c bus scan:
[22:46:31][I][i2c.arduino:102]: Found i2c device at address 0x77
[22:46:31][C][i2c.arduino:072]: SDA Pin: GPIO18
[22:46:31][C][i2c.arduino:073]: SCL Pin: GPIO19
[22:46:31][I][i2c.arduino:102]: Found i2c device at address 0x5C
[22:46:31][C][uptime.sensor:033]: Uptime Sensor 'Station_meteo_Allumé depuis (s)'
[22:46:31][C][uptime.sensor:033]: Device Class: 'duration'
[22:46:31][C][uptime.sensor:033]: State Class: 'total_increasing'
[22:46:31][C][uptime.sensor:033]: Unit of Measurement: 's'
[22:46:31][C][uptime.sensor:033]: Accuracy Decimals: 0
[22:46:31][C][uptime.sensor:033]: Icon: 'mdi:timer-outline'
[22:46:31][C][uptime.sensor:034]: Type: Seconds
[22:46:31][C][template.sensor:022]: Template Sensor 'Station_meteo_UV index'
[22:46:31][C][template.sensor:022]: State Class: ''
[22:46:31][C][template.sensor:022]: Unit of Measurement: ''
[22:46:31][C][template.sensor:022]: Accuracy Decimals: 0
[22:46:31][C][template.sensor:022]: Icon: 'mdi:sun-wireless'
[22:46:31][C][template.sensor:023]: Update Interval: 60.0s
[22:46:31][C][template.sensor:022]: Template Sensor 'station_meteo_compteur_pluviometre'
[22:46:31][C][template.sensor:022]: Unit of Measurement: 'bascules'
[22:46:31][C][template.sensor:023]: Update Interval: 2.0s
[22:46:31][C][template.sensor:022]: Template Sensor 'station_meteo_pluie_du_jour'
[22:46:31][C][template.sensor:022]: Device Class: 'precipitation'
[22:46:31][C][template.sensor:022]: State Class: 'total_increasing'
[22:46:31][C][template.sensor:022]: Unit of Measurement: 'mm'
[22:46:31][C][template.sensor:022]: Accuracy Decimals: 3
[22:46:31][C][template.sensor:022]: Icon: 'mdi:water'
[22:46:31][C][template.sensor:023]: Update Interval: 10.0s
[22:46:31][C][template.sensor:022]: Template Sensor 'station_meteo_pluie_veille'
[22:46:31][C][template.sensor:022]: State Class: 'total'
[22:46:31][C][template.sensor:022]: Icon: 'mdi:water-clock'
[22:46:31][C][template.sensor:023]: Update Interval: never
[22:46:31][C][template.text_sensor:020]: Template Sensor 'Station_meteo_Allumé depuis (j)'
[22:46:31][C][template.text_sensor:020]: Icon: 'mdi:clock-start'
[22:46:31][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'station_meteo_pluviometre_Trigger'
[22:46:31][C][gpio.binary_sensor:016]: Pin: GPIO14
[22:46:31][C][status:034]: Status Binary Sensor 'Station_meteo_Statut'
[22:46:31][C][status:034]: Device Class: 'connectivity'
[22:46:31][C][bme280_i2c.sensor:025]: Address: 0x77
[22:46:31][C][bme280.sensor:182]: BME280:
[22:46:31][C][bme280.sensor:194]: IIR Filter: OFF
[22:46:31][C][bme280.sensor:195]: Update Interval: 10.0s
[22:46:31][C][bme280.sensor:197]: Temperature 'station_meteo_temperature_extérieure'
[22:46:31][C][bme280.sensor:197]: Device Class: 'temperature'
[22:46:31][C][bme280.sensor:197]: State Class: 'measurement'
[22:46:31][C][bme280.sensor:197]: Unit of Measurement: '°C'
[22:46:31][C][bme280.sensor:197]: Accuracy Decimals: 2
[22:46:31][C][bme280.sensor:197]: Icon: 'mdi:water-percent'
[22:46:31][C][bme280.sensor:198]: Oversampling: 16x
[22:46:31][C][bme280.sensor:199]: Pressure 'station_meteo_pression'
[22:46:31][C][bme280.sensor:199]: Device Class: 'atmospheric_pressure'
[22:46:31][C][bme280.sensor:199]: State Class: 'measurement'
[22:46:31][C][bme280.sensor:199]: Unit of Measurement: 'hPa'
[22:46:31][C][bme280.sensor:199]: Accuracy Decimals: 0
[22:46:31][C][bme280.sensor:200]: Oversampling: 16x
[22:46:31][C][bme280.sensor:201]: Humidity 'station_meteo_humidite_exterieure'
[22:46:31][C][bme280.sensor:201]: Device Class: 'humidity'
[22:46:31][C][bme280.sensor:201]: State Class: 'measurement'
[22:46:31][C][bme280.sensor:201]: Unit of Measurement: '%'
[22:46:31][C][bme280.sensor:201]: Accuracy Decimals: 0
[22:46:31][C][bme280.sensor:202]: Oversampling: 16x
[22:46:31][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:46:31][C][bh1750.sensor:118]: BH1750 'station_meteo_luminosite'
[22:46:31][C][bh1750.sensor:118]: Device Class: 'illuminance'
[22:46:31][C][bh1750.sensor:118]: State Class: 'measurement'
[22:46:31][C][bh1750.sensor:118]: Unit of Measurement: 'lux'
[22:46:31][C][bh1750.sensor:118]: Accuracy Decimals: 1
[22:46:31][C][bh1750.sensor:119]: Address: 0x5C
[22:46:31][C][bh1750.sensor:124]: Update Interval: 10.0s
[22:46:31][C][adc:097]: ADC Sensor 'Station_meteo_UV'
[22:46:31][C][adc:097]: Device Class: 'voltage'
[22:46:31][C][adc:097]: State Class: 'measurement'
[22:46:31][C][adc:097]: Unit of Measurement: 'V'
[22:46:31][C][adc:097]: Accuracy Decimals: 3
[22:46:31][C][adc:107]: Pin: GPIO33
[22:46:31][C][adc:113]: Attenuation: 0db
[22:46:31][C][adc:141]: Samples: 1
[22:46:31][C][adc:142]: Update Interval: 60.0s
[22:46:31][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:31][C][restart:068]: Restart Switch 'Station_meteo_Redémarrage'
[22:46:31][C][restart:070]: Icon: 'mdi:restart'
[22:46:31][C][restart:091]: Restore Mode: always OFF
[22:46:31][C][homeassistant.time:010]: Home Assistant Time:
[22:46:31][C][homeassistant.time:011]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[22:46:31][C][captive_portal:089]: Captive Portal:
[22:46:31][C][web_server:145]: Web Server:
[22:46:31][C][web_server:146]: Address: 192.168.1.41:80
[22:46:31][C][mdns:116]: mDNS:
[22:46:31][C][mdns:117]: Hostname: station-meteo
[22:46:31][C][esphome.ota:073]: Over-The-Air updates:
[22:46:31][C][esphome.ota:074]: Address: 192.168.1.41:3232
[22:46:31][C][esphome.ota:075]: Version: 2
[22:46:31][C][esphome.ota:078]: Password configured
[22:46:31][C][safe_mode:018]: Safe Mode:
[22:46:31][C][safe_mode:020]: Boot considered successful after 60 seconds
[22:46:31][C][safe_mode:021]: Invoke after 10 boot attempts
[22:46:31][C][safe_mode:023]: Remain in safe mode for 300 seconds
[22:46:31][C][api:139]: API Server:
[22:46:31][C][api:140]: Address: 192.168.1.41:6053
[22:46:31][C][api:142]: Using noise encryption: YES
[22:46:31][C][wifi_signal.sensor:010]: WiFi Signal 'Station_meteo_Signal Wifi'
[22:46:31][C][wifi_signal.sensor:010]: Device Class: 'signal_strength'
[22:46:31][C][wifi_signal.sensor:010]: State Class: 'measurement'
[22:46:31][C][wifi_signal.sensor:010]: Unit of Measurement: 'dBm'
[22:46:31][C][wifi_signal.sensor:010]: Accuracy Decimals: 0
[22:46:32][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20324 °C with 2 decimals of accuracy
[22:46:32][D][sensor:094]: 'station_meteo_pression': Sending state 1004.40033 hPa with 0 decimals of accuracy
[22:46:32][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.58789 % with 0 decimals of accuracy
[22:46:32][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:46:32][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:46:33][D][sensor:094]: 'Station_meteo_Allumé depuis (s)': Sending state 17498.85156 s with 0 decimals of accuracy
[22:46:33][D][text_sensor:064]: 'Station_meteo_Allumé depuis (j)': Sending state '0d 4h 51m 38s'
[22:46:33][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:35][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:37][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:39][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:41][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:46:41][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:42][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20832 °C with 2 decimals of accuracy
[22:46:42][D][sensor:094]: 'station_meteo_pression': Sending state 1004.38666 hPa with 0 decimals of accuracy
[22:46:42][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.50977 % with 0 decimals of accuracy
[22:46:42][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:46:42][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:46:43][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:45][D][sensor:094]: 'Station_meteo_UV': Sending state 0.07500 V with 3 decimals of accuracy
[22:46:45][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:47][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:49][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:51][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:46:51][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:52][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20324 °C with 2 decimals of accuracy
[22:46:52][D][sensor:094]: 'station_meteo_pression': Sending state 1004.39178 hPa with 0 decimals of accuracy
[22:46:52][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.46582 % with 0 decimals of accuracy
[22:46:52][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:46:52][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:46:53][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:54][D][sensor:094]: 'Station_meteo_Signal Wifi': Sending state -66.00000 dBm with 0 decimals of accuracy
[22:46:55][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:57][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:46:59][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:01][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:47:01][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:02][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20324 °C with 2 decimals of accuracy
[22:47:02][D][sensor:094]: 'station_meteo_pression': Sending state 1004.39178 hPa with 0 decimals of accuracy
[22:47:02][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.44336 % with 0 decimals of accuracy
[22:47:02][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:47:02][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:47:03][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:05][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:07][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:09][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:11][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:47:11][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:12][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20070 °C with 2 decimals of accuracy
[22:47:12][D][sensor:094]: 'station_meteo_pression': Sending state 1004.38928 hPa with 0 decimals of accuracy
[22:47:12][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.41016 % with 0 decimals of accuracy
[22:47:12][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:47:12][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:47:13][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:15][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:17][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:19][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:21][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:47:21][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:22][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.20578 °C with 2 decimals of accuracy
[22:47:22][D][sensor:094]: 'station_meteo_pression': Sending state 1004.36548 hPa with 0 decimals of accuracy
[22:47:22][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.32129 % with 0 decimals of accuracy
[22:47:22][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:47:22][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:47:23][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:25][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:25][D][sensor:094]: 'Station_meteo_UV index': Sending state 1.00000 with 0 decimals of accuracy
[22:47:27][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:29][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:31][D][sensor:094]: 'station_meteo_pluie_du_jour': Sending state nan mm with 3 decimals of accuracy
[22:47:31][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
[22:47:32][D][sensor:094]: 'station_meteo_temperature_extérieure': Sending state 10.21594 °C with 2 decimals of accuracy
[22:47:32][D][sensor:094]: 'station_meteo_pression': Sending state 1004.39081 hPa with 0 decimals of accuracy
[22:47:32][D][sensor:094]: 'station_meteo_humidite_exterieure': Sending state 80.29004 % with 0 decimals of accuracy
[22:47:32][D][bh1750.sensor:159]: 'station_meteo_luminosite': Got illuminance=0.0lx
[22:47:32][D][sensor:094]: 'station_meteo_luminosite': Sending state 0.00000 lux with 1 decimals of accuracy
[22:47:33][D][sensor:094]: 'Station_meteo_Allumé depuis (s)': Sending state 17558.85156 s with 0 decimals of accuracy
[22:47:33][D][text_sensor:064]: 'Station_meteo_Allumé depuis (j)': Sending state '0d 4h 52m 38s'
[22:47:33][D][sensor:094]: 'station_meteo_compteur_pluviometre': Sending state nan bascules with 0 decimals of accuracy
Quand je bascule, le trigger passe en on/off.
Concernant ce que tu me demandais :
Je ne comprends pas trop ce que tu me demandes.
Comment je pourrais le faire ? aujourd’hui le 2eme fils est branché en gnd.
Je viens m’incruster dans vos échanges, certes un peu vieux, mais peut etre avez vous trouvé la solution depuis ; mais j’ai d’autres questions annexes.
Perso j’ai aussi un (vieux) pluviometre à bascule, et un jour je l’ai branché sur une entrée logique d’un Shelly-Uni, pour compter tout ca, dans HA. Ca ne fonctionnait pas parce que l’impulsion de la bascule, etait trop rapide et HA n’avait pas le temps de réagir ; j’ai donc abandonné cette méthode.
Alors je me suis dit qu’un ESP serait ma solution, style ESPHOME.
Je suis novice en ESP, et ma question est la suivante :
Est ce qu’on ne déclare que les entrees/sorties dans l’ESP et HA fait tout le boulot ?
Ou bien, y a t’il un programme dans ESP, qui pourrait par exemple agrandir les impulsions, ce qui laisserait à HA le temps de compter. On pourrait aussi imaginer que l’ESP compte, et HA vienne lire le compteur.
Demandé autrement, est ce que le code est dans l’ESP ou reste dans HA ?
