ma config ESP32 CAM fonctionne
ma config ssd1306_i2c fonctionne
ma config ESP32 CAM+ ssd1306_i2c seule ssd1306_i2c écran fonctionne!!!
Je n’arrive pas, j’ai essayé plein de technique différente .
toujours le même résultat [16:20:15][E][esp32_camera:123]: Setup Failed: ESP_FAIL
[16:20:16][E][esp32_camera_web_server:097]: Setup Failed
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image/Video settings, https://esphome.io/components/esp32_camera.html
max_framerate: 25 fps # default: 10 fps, max 60
idle_framerate: 0.2 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
resolution: 1024x768
jpeg_quality: 10
vertical_flip: False
contrast: 0 # default: 0, variable -2 to 2
brightness: 0 # default: 0, variable -2 to 2
saturation: 0 # default: 0, variable -2 to 2
# Server video/pictures, https://esphome.io/components/esp32_camera_web_server.html
- port: 8080
mode: stream
- port: 8081
mode: snapshot
i2c:
- id: bus_b
sda: GPIO1
scl: GPIO16
scan: true
font:
- file: "gfonts://Roboto"
# gfonts://family[@weight]
- file:
type: gfonts
family: Roboto
weight: 900
# mini ecran
display:
- platform: ssd1306_i2c
i2c_id: bus_b
model: "SSD1306 128x64"
address: 0x3C
update_interval: 15s
lambda: |-
const char * text = "billou";
const char * textprod = "billou";
const char * textlixee = "billou";
const char * textdimmer = "billou";
it.printf(0, 0, id(my_font), "uptime: %.1f", id(uptime_seconds).state);
it.printf(0, 16, id(my_font), "wifi: %.1f", id(wifi_niveau).state);
it.printf(0, 32, id(my_font), "gaspar: %f", id(wifi_niveau).state);
it.printf(0, 48, id(my_font), "Dim: %.2f", id(wifi_niveau).state);
log
16:20:15][I][app:102]: ESPHome version 2023.4.4 compiled on May 15 2023, 16:19:14
[16:20:15][C][wifi:505]: WiFi:
[16:20:15][C][wifi:363]: Local MAC: 7C:87:CE:32:21:B0
[16:20:15][C][wifi:364]: SSID: [redacted]
[16:20:15][C][wifi:365]: IP Address: 192.168.18.116
[16:20:15][C][wifi:367]: BSSID: [redacted]
[16:20:15][C][wifi:368]: Hostname: 'esphome-cam1'
[16:20:15][C][wifi:370]: Signal strength: -74 dB ▂▄▆█
[16:20:15][C][wifi:374]: Channel: 4
[16:20:15][C][wifi:375]: Subnet: 255.255.255.0
[16:20:15][C][wifi:376]: Gateway: 192.168.18.1
[16:20:15][C][wifi:377]: DNS1: 192.168.18.1
[16:20:15][C][wifi:378]: DNS2: 0.0.0.0
[16:20:15][C][logger:294]: Logger:
[16:20:15][C][logger:295]: Level: DEBUG
[16:20:15][C][logger:296]: Log Baud Rate: 115200
[16:20:15][C][logger:297]: Hardware UART: UART0
[16:20:15][C][i2c.arduino:053]: I2C Bus:
[16:20:15][C][i2c.arduino:054]: SDA Pin: GPIO1
[16:20:15][C][i2c.arduino:055]: SCL Pin: GPIO16
[16:20:15][C][i2c.arduino:056]: Frequency: 50000 Hz
[16:20:15][C][i2c.arduino:059]: Recovery: bus successfully recovered
[16:20:15][I][i2c.arduino:069]: Results from i2c bus scan:
[16:20:15][I][i2c.arduino:075]: Found i2c device at address 0x3C
[16:20:15][C][uptime.sensor:031]: Uptime Sensor 'esphome-cam1 Uptime'
[16:20:15][C][uptime.sensor:031]: Device Class: 'duration'
[16:20:15][C][uptime.sensor:031]: State Class: 'total_increasing'
[16:20:15][C][uptime.sensor:031]: Unit of Measurement: 's'
[16:20:15][C][uptime.sensor:031]: Accuracy Decimals: 0
[16:20:15][C][uptime.sensor:031]: Icon: 'mdi:timer'
[16:20:15][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'esphome-cam1 Doorbell'
[16:20:15][C][gpio.binary_sensor:016]: Pin: GPIO12
[16:20:15][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'esphome-cam1 lettre'
[16:20:15][C][gpio.binary_sensor:016]: Pin: GPIO13
[16:20:15][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'esphome-cam1 colis'
[16:20:15][C][gpio.binary_sensor:016]: Pin: GPIO15
[16:20:15][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'esphome-cam1 PIR'
[16:20:15][C][gpio.binary_sensor:015]: Device Class: 'motion'
[16:20:15][C][gpio.binary_sensor:016]: Pin: GPIO2
[16:20:15][C][template.text_sensor:021]: Template Sensor 'esphome-cam1 Uptime H'
[16:20:15][C][template.text_sensor:021]: Icon: 'mdi:clock-start'
[16:20:15][C][gpio.output:010]: GPIO Binary Output:
[16:20:15][C][gpio.output:011]: Pin: GPIO4
[16:20:15][C][gpio.output:011]: Pin: GPIO33
[16:20:15][C][light:103]: Light 'esphome-cam1 light'
[16:20:15][C][light:103]: Light 'esphome-cam1 wifi light state'
[16:20:15][C][homeassistant.time:010]: Home Assistant Time:
[16:20:15][C][homeassistant.time:011]: Timezone: 'CET-1CEST,M3.5.0,M10.5.0/3'
[16:20:15][C][status:034]: Status Binary Sensor 'esphome-cam1 status'
[16:20:15][C][status:034]: Device Class: 'connectivity'
[16:20:15][C][restart.button:017]: Restart Button 'esphome-cam1 restart'
[16:20:15][C][version.text_sensor:021]: Version Text Sensor 'esphome-cam1 ESPHome Version'
[16:20:15][C][version.text_sensor:021]: Icon: 'mdi:new-box'
[16:20:15][C][esp32_camera:048]: ESP32 Camera:
[16:20:15][C][esp32_camera:049]: Name: esphome-cam1
[16:20:15][C][esp32_camera:050]: Internal: NO
[16:20:15][C][esp32_camera:052]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[16:20:15][C][esp32_camera:053]: VSYNC Pin: 25
[16:20:15][C][esp32_camera:054]: HREF Pin: 23
[16:20:15][C][esp32_camera:055]: Pixel Clock Pin: 22
[16:20:15][C][esp32_camera:056]: External Clock: Pin:0 Frequency:20000000
[16:20:15][C][esp32_camera:060]: I2C Pins: SDA:26 SCL:27
[16:20:15][C][esp32_camera:062]: Reset Pin: -1
[16:20:15][C][esp32_camera:086]: Resolution: 1024x768 (XGA)
[16:20:15][C][psram:020]: PSRAM:
[16:20:15][C][psram:021]: Available: NO
[16:20:15][C][ssd1306_i2c:023]: I2C SSD1306
[16:20:16][C][ssd1306_i2c:023]: Rotations: 0 °
[16:20:16][C][ssd1306_i2c:023]: Dimensions: 128px x 64px
[16:20:16][C][ssd1306_i2c:024]: Address: 0x3C
[16:20:16][C][ssd1306_i2c:025]: Model: SSD1306 128x64
[16:20:16][C][ssd1306_i2c:027]: External VCC: NO
[16:20:16][C][ssd1306_i2c:028]: Flip X: YES
[16:20:16][C][ssd1306_i2c:029]: Flip Y: YES
[16:20:16][C][ssd1306_i2c:030]: Offset X: 0
[16:20:16][C][ssd1306_i2c:031]: Offset Y: 0
[16:20:16][C][ssd1306_i2c:032]: Inverted Color: NO
[16:20:16][C][ssd1306_i2c:033]: Update Interval: 15.0s
[16:20:16][C][captive_portal:088]: Captive Portal:
[16:20:16][C][web_server:151]: Web Server:
[16:20:16][C][web_server:152]: Address: esphome-cam1.local:80
[16:20:16][C][mdns:108]: mDNS:
[16:20:16][C][mdns:109]: Hostname: esphome-cam1
[16:20:16][C][ota:093]: Over-The-Air Updates:
[16:20:16][C][ota:094]: Address: esphome-cam1.local:3232
[16:20:16][C][ota:097]: Using Password.
[16:20:16][C][api:138]: API Server:
[16:20:16][C][api:139]: Address: esphome-cam1.local:6053
[16:20:16][C][api:141]: Using noise encryption: YES
[16:20:16][C][wifi_signal.sensor:009]: WiFi Signal 'esphome-cam1 Wifi signal'
[16:20:16][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[16:20:16][C][wifi_signal.sensor:009]: State Class: 'measurement'
[16:20:16][C][wifi_signal.sensor:009]: Unit of Measurement: 'dB'
[16:20:16][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[16:20:16][C][wifi_signal.sensor:009]: Icon: 'mdi:wifi'
[16:20:16][C][wifi_info:009]: WifiInfo IPAddress 'esphome-cam1 IP Address'
[16:20:16][C][esp32_camera_web_server:088]: ESP32 Camera Web Server:
[16:20:16][C][esp32_camera_web_server:089]: Port: 8080
[16:20:16][C][esp32_camera_web_server:091]: Mode: stream
[16:20:16][C][esp32_camera_web_server:089]: Port: 8081
[16:20:16][C][esp32_camera_web_server:093]: Mode: snapshot
[16:20:18][D][text_sensor:064]: 'esphome-cam1 Uptime H': Sending state '1s
[center]
| version |
core-2023.5.3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.10.11 |
| os_name |
Linux |
| os_version |
6.1.25 |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
5000 |
| Installed Version |
1.31.0 |
| Stage |
running |
| Available Repositories |
1283 |
| Downloaded Repositories |
7 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 10.1 |
| update_channel |
stable |
| supervisor_version |
supervisor-2023.04.1 |
| agent_version |
1.5.1 |
| docker_version |
23.0.3 |
| disk_total |
30.8 GB |
| disk_used |
12.2 GB |
| healthy |
true |
| supported |
true |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
File editor (5.6.0), Samba share (10.0.1), Terminal & SSH (9.7.0), ESPHome (2023.5.0), Mosquitto broker (6.2.1) |
| dashboards |
2 |
| resources |
1 |
| views |
1 |
| mode |
storage |
| oldest_recorder_run |
8 mai 2023 à 01:18 |
| current_recorder_run |
17 mai 2023 à 03:17 |
| estimated_db_size |
475.52 MiB |
| database_engine |
sqlite |
| database_version |
3.40.1 |
[/center]
