sur la base d’un esp8466 avec un ads1115, j’ai réalisé un module qui reprend les données du linky, d’un compteur annexe et de 3 pinces ampérométriques SCT0.13 30A/1V.
Home assistant me rapporte bien les infos (conso globale et celles des 4 postes ) donc c’est super sauf que lorsque je regarde les logs de mon esp, j’ai un message d’avertissement récurent et je ne vois pas trop comment solutionner la chose:
[13:22:07][D][ct_clamp:048]: 'Courant P1' - Raw AC Value: 0.003A after 458 different samples (458 SPS)
[13:22:07][D][sensor:093]: 'Courant P1': Sending state 0.08755 A with 2 decimals of accuracy
***[13:22:08][W][component:214]: Component ct_clamp.sensor took a long time for an operation (0.67 s).***
***[13:22:09][W][component:215]: Components should block for at most 20-30ms.***
[13:22:20][D][ct_clamp:048]: 'Courant P2' - Raw AC Value: 0.003A after 472 different samples (472 SPS)
[13:22:20][D][sensor:093]: 'Courant P2': Sending state 0.10274 A with 2 decimals of accuracy
***[13:22:21][W][component:214]: Component ct_clamp.sensor took a long time for an operation (0.61 s).***
***[13:22:22][W][component:215]: Components should block for at most 20-30ms.***
[13:22:23][D][ct_clamp:048]: 'Courant P3' - Raw AC Value: 0.003A after 478 different samples (478 SPS)
[13:22:24][D][sensor:093]: 'Courant P3': Sending state 0.09837 A with 2 decimals of accuracy
***[13:22:25][W][component:214]: Component ct_clamp.sensor took a long time for an operation (0.60 s).***
***[13:22:26][W][component:215]: Components should block for at most 20-30ms.***
[13:22:27][D][ct_clamp:048]: 'Courant P1' - Raw AC Value: 0.003A after 471 different samples (471 SPS)
[13:22:27][D][sensor:093]: 'Courant P1': Sending state 0.07020 A with 2 decimals of accuracy
***[13:22:28][W][component:214]: Component ct_clamp.sensor took a long time for an operation (0.67 s).***
***[13:22:29][W][component:215]: Components should block for at most 20-30ms.***
[13:22:29][D][ads1115:233]: 'adc_sensor3': Got Voltage=1.572625V
[13:22:30][D][sensor:093]: 'adc_sensor3': Sending state 1.57263 V with 3 decimals of accuracy
***[13:22:31][W][component:214]: Component ads1115.sensor took a long time for an operation (1.09 s).***
***[13:22:32][W][component:215]: Components should block for at most 20-30ms.***
Voici le code que j’utilise :
esphome:
friendly_name: Tableau Electrique général
esp8266:
board: nodemcu
external_components:
- source: github://ssieb/esphome@vsampler
components: [ voltage_sampler, ct_clamp, ads1115 ]
refresh: 1min
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: XXX
ota:
password: XXX
wifi:
ssid: !secret wifi_ssid
ap:
ssid: XXX
password: XXX
captive_portal:
# configuration du I2C
i2c:
sda: 4
scl: 5
scan: True
frequency: 200000
# configuration de l ADC
ads1115:
address: 0x48
continuous_mode: True
# configuration de l uart
uart:
rx_pin: 3
tx_pin: 1
baud_rate: 1200
parity: EVEN
data_bits: 7
# configuration du Linky
teleinfo:
update_interval: 60s
historical_mode: true
# configuration des capteurs de courant et pinces
# sensors source
- platform: ads1115
multiplexer: 'A1_GND'
gain: 4.096
- platform: ct_clamp
sensor: adc_sensor1
sample_duration : 1s
update_interval : 20s
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0 -> 0
# Known load: 4.0A
# Value shown in logs: 0.1333A
- 0.3 -> 8.3
- platform: ads1115
multiplexer: 'A2_GND'
gain: 4.096
sensor: adc_sensor2
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
- 0.27 -> 8.2
- platform: ads1115
multiplexer: 'A3_GND'
gain: 4.096
sensor: adc_sensor3
filters:
- calibrate_linear:
- 0 -> 0
# Known load: 4.0A
- 0.27 -> 8.2
# consommation prise voiture
- platform: pulse_meter
name: 'Puissance prise voiture'
pin:
number: 15
mode:
input: True
unit_of_measurement: 'kW'
device_class: power
state_class: measurement
internal_filter: 20ms # Assuming maximum load of 16 kW and 10000 impulses per kWh, any pulses faster than 22.5 ms would exceed load. -10% ~= 20 ms.
accuracy_decimals: 0
filters:
- multiply: 0.06 # (60s/1000 pulses per kWh)
total:
unit_of_measurement: 'kWh'
name: 'Consommation prise voiture'
filters:
- multiply: 0.001 # (1/1000 pulses per kWh)
# configuration des infos du linky
- platform: teleinfo
tag_name: "BBRHCJB"
name: "Heures Creuses Jours Bleus"
unit_of_measurement: "Wh"
icon: mdi:flash
teleinfo_id: myteleinfo
tag_name: "BBRHPJB"
name: "Heures Pleines Jours Bleus"
icon: mdi:flash
tag_name: "BBRHCJW"
name: "Heures Creuses Jours Blancs"
icon: mdi:flash
tag_name: "BBRHPJW"
name: "Heures Pleines Jours Blancs"
icon: mdi:flash
tag_name: "BBRHCJR"
name: "Heures Creuses Jours Rouges"
icon: mdi:flash
tag_name: "BBRHPJR"
name: "Heures Pleines Jours Rouges"
icon: mdi:flash
tag_name: "PAPP"
name: "Puissance apparente triphasée soutirée"
unit_of_measurement: "VA"
icon: mdi:flash
tag_name: "IINST1"
name: "Intensité Instantanée P1"
unit_of_measurement: "A"
icon: mdi:flash
tag_name: "IINST2"
name: "Intensité Instantanée P2"
icon: mdi:flash
tag_name: "IINST3"
name: "Intensité Instantanée P3"
icon: mdi:flash
# suite des informations du linky
text_sensor:
tag_name: "PTEC"
name: "Période Tarifaire en cours"
tag_name: "DEMAIN"
name: "Couleur du lendemain"
J’ai déjà pas mal cherché sur différents forums et mon code a l’air correct donc je ne sais pas ce qui peut causer cet avertissement ni même si je dois m’en soucier (j’aimerais au moins comprendre).
Est-ce que l’un d’entre vous aurait une idée, une piste?
merci d’avance et belle journée.
Manu
| version | core-2024.1.6 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.11.6 |
| os_name | Linux |
| os_version | 6.1.63-haos-raspi |
| arch | aarch64 |
| timezone | Europe/Brussels |
| config_dir | /config |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 11.4 |
| update_channel | stable |
| supervisor_version | supervisor-2023.12.1 |
| agent_version | 1.6.0 |
| docker_version | 24.0.7 |
| disk_total | 228.5 GB |
| disk_used | 9.0 GB |
| healthy | true |
| supported | true |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Mosquitto broker (6.4.0), File editor (5.7.0), ESPHome (2023.12.9), Grafana (9.1.3), Terminal & SSH (9.7.1), Studio Code Server (5.15.0), InfluxDB (5.0.0), Node-RED (15.0.0) |
| dashboards | 1 |
| resources | 0 |
| views | 3 |
| mode | storage |
| oldest_recorder_run | 19 janvier 2024 à 10:20 |
| current_recorder_run | 5 février 2024 à 09:44 |
| estimated_db_size | 198.67 MiB |
| database_engine | sqlite |
| database_version | 3.41.2 |
