Coben
Mai 18, 2023, 2:05
1
J’ai créé un BLE Proxy sous ESP Home avec un petit modul ESP Wroom 32.
En configuration de base, tout se passe bien au niveau du flashage :
yaml de l’esp32 :
substitutions:
friendly_name: Bluetooth Proxy 4cb664
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/esp32-generic.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: XXXXXX
wifi:
ssid: !secret wifi_ssid
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
button:
- platform: safe_mode
name: Safe Mode Boot
entity_category: diagnostic
Mais dès que je tente de rajouter des sensor, binary_sensor, ou switch; le flash fail; alors que le yaml est bien validé avec le bouton « validate ».
yaml
substitutions:
packages:
esphome:
api:
encryption:
key: XXXXXX
wifi:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
button:
binary_sensor:
- platform: status
- platform: wifi_signal
update_interval: 60s
- platform: uptime
name: "Allumé depuis (s)"
switch:
- platform: restart
Le log d’erreur:
INFO Reading configuration /config/esphome/esp32-bluetooth-proxy-4cb664.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esp32-bluetooth-proxy-4cb664 (board: esp32dev; framework: espidf; platform: platformio/espressif32@5.3.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40404.0 (4.4.4)
- tool-cmake @ 3.16.9
- tool-ninja @ 1.10.2
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
|-- Improv @ 1.2.3
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_frame_helper.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_pb2.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_pb2_service.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_server.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/list_entities.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/proto.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/subscribe_state.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/user_services.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/bluetooth_proxy/bluetooth_connection.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/bluetooth_proxy/bluetooth_proxy.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/button/button.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32/gpio.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32/preferences.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble/ble.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble/ble_advertising.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble/ble_uuid.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble_client/ble_characteristic.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble_client/ble_client_base.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble_client/ble_service.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/esp32_ble_tracker/esp32_ble_tracker.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/improv_base/improv_base.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/improv_serial/improv_serial_component.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/logger/logger.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/md5/md5.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/mdns/mdns_component.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/mdns/mdns_esp32.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/mdns/mdns_esp8266.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/mdns/mdns_host.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/mdns/mdns_rp2040.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/network/util.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/ota/ota_backend_arduino_esp32.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/ota/ota_backend_arduino_esp8266.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/ota/ota_backend_arduino_rp2040.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/ota/ota_backend_esp_idf.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/ota/ota_component.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/safe_mode/button/safe_mode_button.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/socket/bsd_sockets_impl.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/socket/lwip_raw_tcp_impl.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/socket/socket.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/wifi/wifi_component.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/wifi/wifi_component_esp32_arduino.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/wifi/wifi_component_esp8266.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/wifi/wifi_component_esp_idf.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/wifi/wifi_component_pico_w.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/application.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/component.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/component_iterator.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/entity_base.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/helpers.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/log.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/scheduler.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/string_ref.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/util.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o
Linking /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection14switch_commandERKNS0_20SwitchCommandRequestE+0x8): undefined reference to `esphome::switch_::Switch::turn_on()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection14switch_commandERKNS0_20SwitchCommandRequestE+0xc): undefined reference to `esphome::switch_::Switch::turn_off()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection17send_sensor_stateEPNS_6sensor6SensorEf+0x8): undefined reference to `esphome::sensor::Sensor::has_state() const'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x4): undefined reference to `esphome::sensor::Sensor::get_accuracy_decimals()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o:(.literal._ZN7esphome3api13APIConnection16send_sensor_infoEPNS_6sensor6SensorE+0x8): undefined reference to `esphome::sensor::Sensor::get_state_class()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o: in function `esphome::api::APIConnection::switch_command(esphome::api::SwitchCommandRequest const&)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.cpp:477: undefined reference to `esphome::switch_::Switch::turn_on()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.cpp:479: undefined reference to `esphome::switch_::Switch::turn_off()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o: in function `esphome::api::APIConnection::send_sensor_state(esphome::sensor::Sensor*, float)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.cpp:423: undefined reference to `esphome::sensor::Sensor::has_state() const'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.o: in function `esphome::api::APIConnection::send_sensor_info(esphome::sensor::Sensor*)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.cpp:436: undefined reference to `esphome::sensor::Sensor::get_accuracy_decimals()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/components/api/api_connection.cpp:438: undefined reference to `esphome::sensor::Sensor::get_state_class()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0xb8): undefined reference to `vtable for esphome::status::StatusBinarySensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0xbc): undefined reference to `vtable for esphome::status::StatusBinarySensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0xd8): undefined reference to `vtable for esphome::wifi_signal::WiFiSignalSensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0xdc): undefined reference to `vtable for esphome::wifi_signal::WiFiSignalSensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0xfc): undefined reference to `vtable for esphome::uptime::UptimeSensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x100): undefined reference to `vtable for esphome::uptime::UptimeSensor'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x120): undefined reference to `vtable for esphome::restart::RestartSwitch'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x124): undefined reference to `vtable for esphome::restart::RestartSwitch'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x17c): undefined reference to `esphome::binary_sensor::BinarySensor::BinarySensor()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x180): undefined reference to `esphome::sensor::Sensor::Sensor()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x184): undefined reference to `esphome::sensor::Sensor::set_state_class(esphome::sensor::StateClass)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x18c): undefined reference to `esphome::sensor::Sensor::set_accuracy_decimals(signed char)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o:(.literal._Z5setupv+0x190): undefined reference to `esphome::switch_::Switch::Switch()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o: in function `setup()':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/main.cpp:228: undefined reference to `esphome::binary_sensor::BinarySensor::BinarySensor()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/main.cpp:247: undefined reference to `esphome::sensor::Sensor::Sensor()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o: in function `std::vector<esphome::binary_sensor::BinarySensor*, std::allocator<esphome::binary_sensor::BinarySensor*> >::push_back(esphome::binary_sensor::BinarySensor* const&)':
/data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/bits/stl_vector.h:1076: undefined reference to `esphome::sensor::Sensor::set_state_class(esphome::sensor::StateClass)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/cache/platformio/packages/toolchain-xtensa-esp32/xtensa-esp32-elf/include/c++/8.4.0/bits/stl_vector.h:1081: undefined reference to `esphome::sensor::Sensor::set_accuracy_decimals(signed char)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o: in function `esphome::status::StatusBinarySensor* esphome::Application::register_component<esphome::status::StatusBinarySensor>(esphome::status::StatusBinarySensor*)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/core/application.h:132: undefined reference to `esphome::sensor::Sensor::Sensor()'
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/main.cpp:283: undefined reference to `esphome::sensor::Sensor::set_state_class(esphome::sensor::StateClass)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/main.cpp:285: undefined reference to `esphome::sensor::Sensor::set_accuracy_decimals(signed char)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o: in function `esphome::wifi_signal::WiFiSignalSensor* esphome::Application::register_component<esphome::wifi_signal::WiFiSignalSensor>(esphome::wifi_signal::WiFiSignalSensor*)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/core/application.h:132: undefined reference to `esphome::switch_::Switch::Switch()'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.o:(.literal._ZN7esphome10Controller16setup_controllerEb+0x18): undefined reference to `esphome::binary_sensor::BinarySensor::add_on_state_callback(std::function<void (bool)>&&)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.o:(.literal._ZN7esphome10Controller16setup_controllerEb+0x1c): undefined reference to `esphome::sensor::Sensor::add_on_state_callback(std::function<void (float)>&&)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.o:(.literal._ZN7esphome10Controller16setup_controllerEb+0x20): undefined reference to `esphome::switch_::Switch::add_on_state_callback(std::function<void (bool)>&&)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.o: in function `esphome::Controller::setup_controller(bool)':
/config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.cpp:11: undefined reference to `esphome::binary_sensor::BinarySensor::add_on_state_callback(std::function<void (bool)>&&)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.cpp:29: undefined reference to `esphome::sensor::Sensor::add_on_state_callback(std::function<void (float)>&&)'
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: /config/esphome/.esphome/build/esp32-bluetooth-proxy-4cb664/src/esphome/core/controller.cpp:35: undefined reference to `esphome::switch_::Switch::add_on_state_callback(std::function<void (bool)>&&)'
collect2: error: ld returned 1 exit status
*** [/data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/firmware.elf] Error 1
========================= [FAILED] Took 94.74 seconds =========================
Merci pour votre aide précieuse!
EDIT:
Je m’apercois aussi que meme avec la configuration qui fonctionne, aucun device n’est découvert…
[center]## System Information
version
core-2023.5.3
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.10.11
os_name
Linux
os_version
6.1.25
arch
aarch64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
4818
Installed Version
1.32.1
Stage
running
Available Repositories
1354
Downloaded Repositories
28
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 10.1
update_channel
stable
supervisor_version
supervisor-2023.04.1
agent_version
1.5.1
docker_version
23.0.3
disk_total
27.9 GB
disk_used
10.3 GB
healthy
true
supported
true
board
odroid-n2
supervisor_api
ok
version_api
ok
installed_addons
Terminal & SSH (9.7.0), File editor (5.6.0), TasmoAdmin (0.24.3), Studio Code Server (5.5.7), Mosquitto broker (6.2.1), Node-RED (14.2.0), InfluxDB (4.6.0), ESPHome (2023.5.1), Grafana (8.3.0), Samba Backup (5.2.0), Z-Wave JS (0.1.80), Z-Wave JS UI (1.13.0)
dashboards
3
resources
20
views
7
mode
storage
oldest_recorder_run
9 mai 2023 à 09:14
current_recorder_run
18 mai 2023 à 15:27
estimated_db_size
398.67 MiB
database_engine
sqlite
database_version
3.40.1
Sonoff
version
3.5.1 (122751c)
cloud_online
0 / 2
local_online
2 / 2
[/center]
j’avais eu des soucis pour reflasher un atom lite et j’ai fais clean build file avant de refaire un flash avec mon config.yaml modifier avec des sensors et binary_sensor.
name: "WiFi Signal dB"
entity_category: "diagnostic"
- platform: copy
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
- platform: uptime
name: "BLE Proxy Uptime"
- platform: internal_temperature
name: "Internal Temperature"
switch:
- platform: restart
name: "BLE Proxy Restart"
binary_sensor:
- platform: status
name: "BLE Proxy Statut"
Pas besoin d’ajouter:
button:
c’est déja inclus dans le packages bluetooth-proxies/esp32-generic.yaml at main · esphome/bluetooth-proxies · GitHub
Coben
Mai 18, 2023, 5:27
3
Super merci, on avance un peu.
J’ai reussi a rajouter les boutons
binary_sensor:
- platform: status
- platform: uptime
switch:
- platform: restart
Mais si je rajoute ca , ca fail :
text_sensor:
name: "Allumé depuis (j)"
lambda: |-
int seconds = (id(uptime_sec).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
icon: mdi:clock-start
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bootloader_support/src/bootloader_efuse.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bootloader_support/src/idf/bootloader_sha.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/controller/esp32/bt.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/controller/esp32/hli_api.o
Archiving /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/esp-idf/bootloader_support/libbootloader_support.a
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/controller/esp32/hli_vectors.o
/config/esphome/esp32-bluetooth-proxy-4cb664.yaml: In lambda function:
/config/esphome/esp32-bluetooth-proxy-4cb664.yaml:55:17: error: 'String' was not declared in this scope
/config/esphome/esp32-bluetooth-proxy-4cb664.yaml:55:17: note: suggested alternative: 'trunc'
trunc
/config/esphome/esp32-bluetooth-proxy-4cb664.yaml:55:113: error: could not convert '{<expression error>}' from '<brace-enclosed initializer list>' to 'esphome::optional<std::__cxx11::basic_string<char> >'
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/btc/core/btc_alarm.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/api/esp_blufi_api.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/btc/core/btc_manage.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/btc/core/btc_task.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/btc/profile/esp/blufi/blufi_prf.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/btc/profile/esp/blufi/blufi_protocol.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/osi/alarm.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/osi/allocator.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/osi/buffer.o
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/osi/config.o
*** [/data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/src/main.o] Error 1
Compiling /data/esp32-bluetooth-proxy-4cb664/.pioenvs/esp32-bluetooth-proxy-4cb664/bt/common/osi/fixed_queue.o
========================= [FAILED] Took 98.94 seconds =========================
De plus, je n’ai strictement aucune remontée de device…
A noter que j’ai un clé bluetooth brancher physiquement en USB sur mon odroïd qui ne remonte rien non plus…
J’ai mis ca dans configuration.yaml
bluetooth:
device_tracker:
- platform: bluetooth_tracker
new_device_defaults:
track_new_devices: true
- platform: bluetooth_le_tracker
J’avais un soucis identique pour le template, n’ayant pas réussi a le faire fonctionner je suis passer par un template sur HA.
template.yaml:
- sensor:
- name: Bluetooth Proxy Uptime Readable
state: >-
{% set uptime = states.sensor.bluetooth_proxy_uptime.state | int(0) %}
{% set jours = (uptime / 86400) | int(0) %}
{%- if jours > 0 -%}
{{ jours }} jours, {{ (uptime - (jours * 86400)) | int(0) | timestamp_custom('%H:%M:%S', false) }}
{%- else -%}
{{ uptime | int(0) | timestamp_custom('%H:%M:%S', false) }}
{%- endif -%}
unique_id: bluetooth_proxy_uptime_readable
Coben
Mai 18, 2023, 7:15
5
Ok.
Comment fais tu pour inclure ce template dans le .yaml de l’esp?
Des idees sur le fait qu’aucune donnée ne remonte?
Le fait d’avoir une cle usb physique + ble proxy peut poser probleme? Les 2 peuvent cohabiter?
C’est pas par esp mais par HA que j’ai fait le template.
Non, pas de soucis. J’ai une clé ble et 2 ble proxy.
Coben
Mai 18, 2023, 9:23
7
Et concernant le fait de n’avoir aucune remontée? Une idée?
Aucune remonté de quoi ?
il découvre pas t’es appareil BLE ?
Ton BLE Proxy est pas découvert ?
Coben
Mai 19, 2023, 9:07
9
Mes appareils. J’ai rien.
Le proxy est bien decouvert.
Quels sont les appareils et marque ?
Ta clé bluetooth est installer dans HA avec l’intégration Bluetooth ?
Du moment que ta clé bluetooth est installer dans HA et que t’es BLE proxy sont installer dans HA, ca va te découvrir automatiquement les appareils bluetooth. Au pire tu peu les ajouter manuellement.
Tous les appareils Bluetooth ne sont pas forcement détectés.
quels sont les appareils Bluetooth que tu cherches a détecter.
Coben
Mai 19, 2023, 1:26
12
oui
Des thermomètres Xiaomi ( CGG1 et MJ_HT_V1) ainsi que de Mi Flora
Effectivement les Miflora et les MJ_HT_V1 ça devrait remonter
juste un truc qui me titille dans ton code
je ne comprends pas pourquoi tu utilises
packages:
Normalement tu n’as rien d’autre a rajouter que
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
en utilisant le firmware dédié ça donne quoi ?
ESPHome Bluetooth Proxy
Coben
Mai 19, 2023, 1:47
14
c’est la configuration trouvée dans le lien github donné par @WarC0zes dans sa 1ere réponse.
Je viens de reflasher en rentrant manuellement les paramètres
- platform: xiaomi_lywsdcgq
mac_address: "4C:65:A8:XX:XX"
temperature:
name: "LYWSDCGQ Temperature"
humidity:
name: "LYWSDCGQ Humidity"
battery_level:
name: "LYWSDCGQ Battery Level"
et la ca remonte bien.
J’ai l’impression que je ne comprends pas bien le fonctionnement de ESPHome… ca n’est pas sensé sniffer automatiquement les trames qui passent à proximité?
Et maintenant les infos du device rentré manuellement remontent toutes les 4 secondes. C’est normal des remontées aussi fréquentes? y’a pas un risque de « surcharge » de HA si j’ai une dizaines de device?
[15:42:32][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:32][D][xiaomi_ble:331]: Temperature: 18.7°C
[15:42:32][D][xiaomi_ble:334]: Humidity: 54.6%
[15:42:32][D][sensor:094]: 'LYWSDCGQ Temperature': Sending state 18.70000 °C with 1 decimals of accuracy
[15:42:32][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.60000 % with 1 decimals of accuracy
[15:42:36][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:36][D][xiaomi_ble:331]: Temperature: 18.6°C
[15:42:36][D][xiaomi_ble:334]: Humidity: 54.6%
[15:42:36][D][sensor:094]: 'LYWSDCGQ Temperature': Sending state 18.60000 °C with 1 decimals of accuracy
[15:42:36][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.60000 % with 1 decimals of accuracy
[15:42:42][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:42][D][xiaomi_ble:331]: Temperature: 18.6°C
[15:42:42][D][xiaomi_ble:334]: Humidity: 54.4%
[15:42:42][D][sensor:094]: 'LYWSDCGQ Temperature': Sending state 18.60000 °C with 1 decimals of accuracy
[15:42:42][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.40000 % with 1 decimals of accuracy
[15:42:46][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:46][D][xiaomi_ble:337]: Battery Level: 72%
[15:42:46][D][sensor:094]: 'LYWSDCGQ Battery Level': Sending state 72.00000 % with 0 decimals of accuracy
[15:42:48][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:48][D][xiaomi_ble:331]: Temperature: 18.6°C
[15:42:48][D][xiaomi_ble:334]: Humidity: 54.4%
[15:42:48][D][sensor:094]: 'LYWSDCGQ Temperature': Sending state 18.60000 °C with 1 decimals of accuracy
[15:42:48][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.40000 % with 1 decimals of accuracy
[15:42:50][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:50][D][xiaomi_ble:334]: Humidity: 54.3%
[15:42:50][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.30000 % with 1 decimals of accuracy
[15:42:56][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
[15:42:56][D][xiaomi_ble:331]: Temperature: 18.6°C
[15:42:56][D][xiaomi_ble:334]: Humidity: 54.3%
[15:42:56][D][sensor:094]: 'LYWSDCGQ Temperature': Sending state 18.60000 °C with 1 decimals of accuracy
[15:42:56][D][sensor:094]: 'LYWSDCGQ Humidity': Sending state 54.30000 % with 1 decimals of accuracy
[15:43:00][D][xiaomi_ble:328]: Got Xiaomi LYWSDCGQ (4C:65:A8:XX:XX):
avant de mettre a genoux ton HA a moins d’être du PI 3, tu devrais avoir quand même pas mal de ressources sous le pied
par contre c’est potentiellement les piles des capteurs qui risque de trinquer
Coben
Mai 19, 2023, 2:11
16
Ok. On peut réduire la fréquence de scan?
Autre question : les infos remontent dans ESPHome comme des entités. Est il possible de regrouper par appareil?
J’ai essyé de mettre un « name » dans le .yaml et ca ne passe pas…
mac_address: "4C:65:A8:DC:B6:E2"
temperature:
name: "Mija SdJ Temperature"
humidity:
name: "Mija SdJ Humidity"
battery_level:
name: "Mija SdJ Battery Level"
- platform: xiaomi_cgg1
mac_address: "58:2D:34:10:52:6B"
temperature:
name: "Cleargrass Gde SdB Temperature"
humidity:
name: "Cleargrass Gde SdB Humidity"
battery_level:
name: "Cleargrass Gde SdB Battery Level"
Coben
Mai 19, 2023, 2:27
17
suis pas sur de ca.
j’ai cru comprendre que le proxy BLE était « sniffeur » et capte les trames qui passent a coté. A priori il n’interroge pas activement les appareils; ce sont eux qui envoient leurs trames?
oui effectivement le principe c’est sniffer les trames
mais de mémoire les mi flora ont tendance a bouffer plus de piles que de raison je ne sais pas si c’est la faute a leur foutu firmware
mais cela a été reporté a plusieurs reprises d’où ma remarque.
pour les miflora il existe une carte native et d’autres customisées
c’est la configuration automatique que esphome met pour les bluetooh proxy.
mon config.yaml pour un atom lite:
substitutions:
friendly_name: Bluetooth Proxy 854638
packages:
esphome.bluetooth-proxy: github://esphome/bluetooth-proxies/m5stack-atom-lite.yaml@main
esphome:
api:
encryption:
key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
wifi:
- platform: copy
filters:
- platform: uptime
switch:
- platform: restart
binary_sensor:
- platform: status
Comme tu peu le voir , je n’est pas ces lignes, car ca les récupent dans le package ( bluetooth-proxies/m5stack-atom-lite.yaml at main · esphome/bluetooth-proxies · GitHub ).
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
Le interval et window a 1100ms a été changer aussi.
committed 11:24PM - 05 Apr 23 UTC
[17:04:48][C][esp32_ble_tracker:591]: BLE Tracker:
[17:04:48][C][esp32_ble_tracker:592]: Scan Duration: 300 s
[17:04:48][C][esp32_ble_tracker:593]: Scan Interval: 320.0 ms
[17:04:48][C][esp32_ble_tracker:594]: Scan Window: 30.0 ms
[17:04:48][C][esp32_ble_tracker:595]: Scan Type: ACTIVE
[17:04:48][C][esp32_ble_tracker:596]: Continuous Scanning: True
Coben
Mai 19, 2023, 6:55
20
Merci pour toute ces infos et votre aide
