J’utilise le module complémentaire HA Linky de Bokub pour le suivi de ma consommation journalière.
Étant novice j’aimerai pouvoir avoir une estimation mensuelle de ma facture d’électricité.
Est ce possible ? Si oui, j’aurai bien besoin d’aide
Merci d’avance !
version |
core-2025.4.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.2 |
os_name |
Linux |
os_version |
6.12.20-haos |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.5 |
Stage |
running |
Available Repositories |
1635 |
Downloaded Repositories |
10 |
logged_in |
true |
subscription_expiration |
1 janvier 2018 à 01:00 |
relayer_connected |
false |
relayer_region |
null |
remote_enabled |
true |
remote_connected |
false |
alexa_enabled |
false |
google_enabled |
true |
cloud_ice_servers_enabled |
true |
remote_server |
null |
certificate_status |
null |
instance_id |
e182cace7a684687b26abf5277e5d351 |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 15.1 |
update_channel |
stable |
supervisor_version |
supervisor-2025.03.4 |
agent_version |
1.7.2 |
docker_version |
28.0.4 |
disk_total |
116.7 GB |
disk_used |
12.6 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
generic-x86-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
go2rtc (1.9.9), Terminal & SSH (9.16.0), Frigate (0.15.0), Studio Code Server (5.18.4), Grocy (0.24.0), Mosquitto broker (6.5.0), Linky (1.5.0), Zigbee2MQTT (2.2.1-1), File editor (5.8.0), Duck DNS (1.18.0), Cloudflared (5.2.12) |
dashboards |
3 |
resources |
6 |
views |
3 |
mode |
storage |
Network Configuration
adapters |
lo (disabled), enp0s31f6 (enabled, default, auto), docker0 (disabled), hassio (disabled), vetha26137a (disabled), vethf344d31 (disabled), veth8ea09e0 (disabled), veth58a0389 (disabled), vethd7ddae0 (disabled), vethf863251 (disabled), vethc411397 (disabled), veth985e17e (disabled), vethff362b0 (disabled), veth9e30f08 (disabled), veth48518f5 (disabled), veth5174962 (disabled), veth5c15480 (disabled), veth32c4af4 (disabled), veth6ff87dc (disabled), vethd0eb36a (disabled) |
ipv4_addresses |
lo (127.0.0.1/8), enp0s31f6 (192.168.1.198/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vetha26137a (), vethf344d31 (), veth8ea09e0 (), veth58a0389 (), vethd7ddae0 (), vethf863251 (), vethc411397 (), veth985e17e (), vethff362b0 (), veth9e30f08 (), veth48518f5 (), veth5174962 (), veth5c15480 (), veth32c4af4 (), veth6ff87dc (), vethd0eb36a () |
ipv6_addresses |
lo (::1/128), enp0s31f6 (2a01:e0a:2d7:52f0:208:4c8f:2e3c:a071/64, fe80::f443:f435:8069:13b9/64), docker0 (fe80::ec3b:4eff:fe5d:7e50/64), hassio (fe80::c8ba:2eff:fed8:de75/64), vetha26137a (fe80::e4a2:61ff:fe6e:6dc9/64), vethf344d31 (fe80::9c72:c6ff:fe14:21f/64), veth8ea09e0 (fe80::6830:8cff:fed5:87e/64), veth58a0389 (fe80::e42e:d6ff:feac:86c1/64), vethd7ddae0 (fe80::90dc:32ff:fe9a:8f61/64), vethf863251 (fe80::fc23:90ff:fe11:cdff/64), vethc411397 (fe80::9430:f3ff:fe56:c5de/64), veth985e17e (fe80::20d6:10ff:fe22:4347/64), vethff362b0 (fe80::f4bc:8dff:fe9a:463a/64), veth9e30f08 (fe80::dcb6:c6ff:fe24:cfed/64), veth48518f5 (fe80::d0b0:2fff:fe85:3e4/64), veth5174962 (fe80::c0b7:b6ff:fe44:8225/64), veth5c15480 (fe80::8f3:4aff:fe2b:3d/64), veth32c4af4 (fe80::78d8:acff:fe72:75fb/64), veth6ff87dc (fe80::6029:83ff:fe26:795a/64), vethd0eb36a (fe80::a426:99ff:fea3:e0a8/64) |
announce_addresses |
192.168.1.198, 2a01:e0a:2d7:52f0:208:4c8f:2e3c:a071, fe80::f443:f435:8069:13b9 |
oldest_recorder_run |
24 mars 2025 à 08:32 |
current_recorder_run |
9 avril 2025 à 14:58 |
estimated_db_size |
44.20 MiB |
database_engine |
sqlite |
database_version |
3.48.0 |
Nissa
2
J’ai publié ceci
qui devrait répondre à ton besoin.
A+
