e[33m2024-04-11 14:12:55.016 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Firefox to start, took more than 120 secondse[0m
e[33m2024-04-11 14:14:54.391 WARNING (MainThread) [supervisor.addons.addon] 49e24ccc_firefox is already running!e[0m
e[33m2024-04-11 14:16:54.396 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Firefox to start, took more than 120 secondse[0m
e[33m2024-04-11 14:19:44.619 WARNING (MainThread) [supervisor.addons.addon] 49e24ccc_firefox is already running!e[0m
e[33m2024-04-11 14:21:44.627 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Firefox to start, took more than 120 secondse[0m
e[32m2024-04-11 14:25:16.412 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_wireguarde[0m
e[32m2024-04-11 14:25:16.415 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package wireguard/aarch64 · GitHub with tag 0.10.2.e[0m
e[32m2024-04-11 14:25:26.519 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ a0d7b954_wireguard › successfully installede[0m
e[32m2024-04-11 14:25:33.215 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package wireguard/aarch64 · GitHub with version 0.10.2e[0m
e[32m2024-04-11 14:25:34.386 INFO (MainThread) [supervisor.api.middleware.security] /dns/info access from a0d7b954_wireguarde[0m
e[32m2024-04-11 14:26:42.607 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_a0d7b954_wireguard applicatione[0m
e[32m2024-04-11 14:26:46.275 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_wireguard applicatione[0m
e[32m2024-04-11 14:26:46.326 INFO (SyncWorker_7) [supervisor.docker.manager] Removing image Package wireguard/aarch64 · GitHub with lateste[0m
e[32m2024-04-11 14:26:46.338 INFO (SyncWorker_7) [supervisor.docker.manager] Removing image Package wireguard/aarch64 · GitHub with 0.10.2e[0m
e[32m2024-04-11 14:26:46.869 INFO (MainThread) [supervisor.addons.addon] Wait for addon startup task cancelled due to: Removing add-on WireGuard from systeme[0m
e[32m2024-04-11 14:26:46.871 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/a0d7b954_wireguarde[0m
e[32m2024-04-11 14:26:46.928 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ a0d7b954_wireguard › successfully removede[0m
e[32m2024-04-11 14:27:08.410 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping addon_49e24ccc_firefox applicatione[0m
e[32m2024-04-11 14:27:11.341 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_49e24ccc_firefox applicatione[0m
e[32m2024-04-11 14:27:11.375 INFO (SyncWorker_6) [supervisor.docker.manager] Removing image Package firefox-aarch64 · GitHub with lateste[0m
e[32m2024-04-11 14:27:11.388 INFO (SyncWorker_6) [supervisor.docker.manager] Removing image Package firefox-aarch64 · GitHub with 1.1.0e[0m
e[32m2024-04-11 14:27:12.204 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/49e24ccc_firefoxe[0m
e[32m2024-04-11 14:27:12.614 INFO (MainThread) [supervisor.host.apparmor] Removing AppArmor profile: 49e24ccc_firefoxe[0m
e[32m2024-04-11 14:27:12.631 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for 49e24ccc_firefoxe[0m
e[32m2024-04-11 14:27:12.701 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ 49e24ccc_firefox › successfully removede[0m
e[32m2024-04-11 14:27:26.242 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_cec_scane[0m
e[32m2024-04-11 14:27:26.245 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-cec_scan with tag 3.0.e[0m
e[32m2024-04-11 14:27:33.975 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_cec_scan › successfully installede[0m
e[32m2024-04-11 14:27:37.298 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-cec_scan with version 3.0e[0m
e[33m2024-04-11 14:29:37.315 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon CEC Scanner to start, took more than 120 secondse[0m
e[32m2024-04-11 14:34:31.983 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2024-04-11 14:34:31.983 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2024-04-11 14:34:32.000 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2024-04-11 14:34:32.000 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-04-11 14:34:32.001 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2024-04-11 14:34:32.057 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2024-04-11 14:34:32.058 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2024-04-11 14:34:32.059 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2024-04-11 14:34:32.060 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2024-04-11 14:34:32.062 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2024-04-11 14:34:32.062 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/systeme[0m
e[32m2024-04-11 14:34:32.063 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-04-11 14:34:32.063 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-04-11 14:34:32.376 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-04-11 14:34:32.377 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2024-04-11 14:34:32.378 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2024-04-11 14:36:58.357 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-04-11 14:39:04.771 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_cec_scan applicatione[0m
e[32m2024-04-11 14:39:05.617 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-cec_scan with version 3.0e[0m
e[32m2024-04-11 14:39:35.609 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_vlce[0m
e[32m2024-04-11 14:39:35.613 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-vlc with tag 0.3.0.e[0m
e[32m2024-04-11 14:39:54.826 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_vlc › successfully installede[0m
e[32m2024-04-11 14:40:07.321 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-vlc with version 0.3.0e[0m
e[32m2024-04-11 14:40:08.014 INFO (MainThread) [supervisor.discovery] Sending discovery to Home Assistant vlc_telnet from core_vlce[0m
e[32m2024-04-11 14:40:08.064 INFO (MainThread) [supervisor.discovery] Discovery 2eb5ec5d492546f1a0f6c76a42d008e0 message sende[0m
e[32m2024-04-11 14:40:56.633 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping addon_core_vlc applicatione[0m
e[32m2024-04-11 14:41:00.336 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_core_vlc applicatione[0m
e[32m2024-04-11 14:41:00.388 INFO (SyncWorker_3) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-vlc with lateste[0m
e[32m2024-04-11 14:41:00.400 INFO (SyncWorker_3) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-vlc with 0.3.0e[0m
e[32m2024-04-11 14:41:00.882 INFO (MainThread) [supervisor.addons.addon] Wait for addon startup task cancelled due to: Removing add-on VLC from systeme[0m
e[32m2024-04-11 14:41:00.883 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/core_vlce[0m
e[32m2024-04-11 14:41:00.921 INFO (MainThread) [supervisor.discovery] Delete discovery to Home Assistant vlc_telnet from core_vlce[0m
e[32m2024-04-11 14:41:00.940 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_vlc › successfully removede[0m
e[32m2024-04-11 14:41:00.980 INFO (MainThread) [supervisor.discovery] Discovery 2eb5ec5d492546f1a0f6c76a42d008e0 message sende[0m
e[33m2024-04-11 14:41:05.629 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon CEC Scanner to start, took more than 120 secondse[0m
e[32m2024-04-11 14:42:35.407 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_core_cec_scan applicatione[0m
e[32m2024-04-11 14:42:35.441 INFO (SyncWorker_4) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-cec_scan with lateste[0m
e[32m2024-04-11 14:42:35.453 INFO (SyncWorker_4) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-cec_scan with 3.0e[0m
e[32m2024-04-11 14:42:35.728 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/core_cec_scane[0m
e[32m2024-04-11 14:42:35.769 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_cec_scan › successfully removede[0m
e[32m2024-04-11 14:43:04.553 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_airsonose[0m
e[32m2024-04-11 14:43:04.556 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package airsonos/aarch64 · GitHub with tag 4.2.1.e[0m
e[32m2024-04-11 14:43:17.192 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ a0d7b954_airsonos › successfully installede[0m
e[32m2024-04-11 14:43:19.356 INFO (SyncWorker_6) [supervisor.addons.addon] Creating Home Assistant add-on config folder /data/addon_configs/a0d7b954_airsonose[0m
e[32m2024-04-11 14:43:21.098 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package airsonos/aarch64 · GitHub with version 4.2.1e[0m
e[32m2024-04-11 14:44:49.857 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping addon_a0d7b954_airsonos applicatione[0m
e[32m2024-04-11 14:44:53.833 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_a0d7b954_airsonos applicatione[0m
e[32m2024-04-11 14:44:53.882 INFO (SyncWorker_6) [supervisor.docker.manager] Removing image Package airsonos/aarch64 · GitHub with lateste[0m
e[32m2024-04-11 14:44:53.895 INFO (SyncWorker_6) [supervisor.docker.manager] Removing image Package airsonos/aarch64 · GitHub with 4.2.1e[0m
e[32m2024-04-11 14:44:54.475 INFO (MainThread) [supervisor.addons.addon] Wait for addon startup task cancelled due to: Removing add-on AirSonos from systeme[0m
e[32m2024-04-11 14:44:54.477 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/a0d7b954_airsonose[0m
e[32m2024-04-11 14:44:54.546 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ a0d7b954_airsonos › successfully removede[0m
e[32m2024-04-11 14:45:31.848 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:45:31.942 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:45:48.063 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:45:48.154 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:45:51.002 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:45:51.097 INFO (MainThread) [supervisor.backups.manager] Found 5 backup filese[0m
e[32m2024-04-11 14:49:41.450 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_duckdnse[0m
e[32m2024-04-11 14:49:41.453 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-duckdns with tag 1.16.0.e[0m
e[32m2024-04-11 14:49:43.349 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_duckdns › successfully installede[0m
e[32m2024-04-11 14:49:53.289 INFO (SyncWorker_4) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-duckdns with lateste[0m
e[32m2024-04-11 14:49:53.302 INFO (SyncWorker_4) [supervisor.docker.manager] Removing image homeassistant/aarch64-addon-duckdns with 1.16.0e[0m
e[32m2024-04-11 14:49:53.334 INFO (MainThread) [supervisor.addons.addon] Removing add-on data folder /data/addons/data/core_duckdnse[0m
e[32m2024-04-11 14:49:53.371 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_duckdns › successfully removede[0m
e[32m2024-04-11 14:49:57.956 INFO (MainThread) [supervisor.addons.addon] Creating Home Assistant add-on data folder /data/addons/data/core_cec_scane[0m
e[32m2024-04-11 14:49:57.958 INFO (MainThread) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-addon-cec_scan with tag 3.0.e[0m
e[32m2024-04-11 14:50:07.202 INFO (MainThread) [supervisor.addons.manager] Add-on ‹ core_cec_scan › successfully installede[0m
e[32m2024-04-11 14:50:10.533 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-cec_scan with version 3.0e[0m
e[33m2024-04-11 14:52:10.544 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon CEC Scanner to start, took more than 120 secondse[0m
