regarde mon sujet sur OpenHASP, je met le code pour le template et pour openhasp.yaml
tu dois créer un template, pour récupérer les forecasts des jours :
template:
- trigger:
- platform: time_pattern
hours: /1
- platform: homeassistant
event: start
- action: weather.get_forecasts
type: daily
entity_id: weather.xxxxx
response_variable: daily
- name: Weather Forecast Jour XXXX
unique_id: weather_forecast_jour_XXXXX
state: "{{ daily['weather.xxxxx'].forecast[0].condition }}"
attributes:
forecast: "{{ daily['weather.xxxxx'].forecast }}"
puis un template pour openhasp:
template:
- sensor:
- name: Météo xxxx J0
unique_id: meteo_xxxx_j0
state: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[0].condition | default(0) }}"
attributes:
temperature: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[0].temperature | float(0) }}"
templow: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[0].templow | float(0) }}"
humidite: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[0].humidity | int(0) }}"
precipitation: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[0].precipitation | float(0) }}"
availability: "{{ states('sensor.weather_forecast_jour_xxxx') not in ['unknown', 'unavailable', 'none'] }}"
- name: Météo xxxx J1
unique_id: meteo_xxxx_j1
state: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[1].condition | default(0) }}"
attributes:
temperature: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[1].temperature | float(0) }}"
templow: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[1].templow | float(0) }}"
humidite: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[1].humidity | int(0) }}"
precipitation: "{{ state_attr('sensor.weather_forecast_jour_xxxx','forecast')[1].precipitation | float(0) }}"
Les templates se mettent dans le configuration.yaml ( verifier la configuration de HA, avant de redémarrer dans outils de dev / verifier configuration ).
Tu dois déclaré une seule fois le template: , le - trigger: et - sensor: ce mettent a la suite.
Regarde la doc pour plus d’information:
