Frigate a cessé de fonctionner
Mon frigate full accès 0.14.1 a cessé de fonctionner depuis qq jour
Je n’ai pas touché à sa configuration
Par contre mis à jour HA core (sans pour autant pouvoir affirmer que le problème est survenu depuis)
Dans les log j’ai ceci (voir ci dessous)
Une idée ?
Merci à tous
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2025-01-27 21:50:08.193408911  [INFO] Preparing Frigate...
2025-01-27 21:50:08.237274261  [INFO] Starting NGINX...
2025-01-27 21:50:08.325428458  [INFO] No TLS certificate found. Generating a self signed certificate...
2025-01-27 21:50:09.433128286  [INFO] Preparing new go2rtc config...
2025-01-27 21:50:09.599909960  [INFO] Starting Frigate...
2025-01-27 21:50:09.905058425  [INFO] Got IP address from supervisor: 192.168.1.87
2025-01-27 21:50:10.623557540  [INFO] Got WebRTC port from supervisor: 8556
2025-01-27 21:50:18.198162618  [INFO] Starting go2rtc healthcheck service...
2025-01-27 21:50:19.615040968  [INFO] Starting go2rtc...
2025-01-27 21:50:20.317619924  22:50:20.301 INF go2rtc platform=linux/arm64 revision=b2399f3 version=1.9.2
2025-01-27 21:50:20.317639387  22:50:20.311 INF config path=/dev/shm/go2rtc.yaml
2025-01-27 21:50:20.324343293  22:50:20.324 INF [rtsp] listen addr=:8554
2025-01-27 21:50:20.325051121  22:50:20.324 INF [api] listen addr=:1984
2025-01-27 21:50:20.336553746  22:50:20.335 INF [webrtc] listen addr=:8555/tcp
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
s6-rc: info: service certsync successfully started
2025-01-27 21:50:20.715889294  [INFO] Starting certsync...
2025-01-27 21:50:22.893186077  127.0.0.1 - - [27/Jan/2025:22:50:22 +0100] "" 400 0 "-" "-" "-"
2025-01-27 21:50:24.494731116  2025/01/27 22:50:24 [error] 193#193: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:24.497396112  2025/01/27 22:50:24 [error] 193#193: *2 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:25.803375787  2025/01/27 22:50:25 [error] 198#198: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-01-27 21:50:25.803433379  2025/01/27 22:50:25 [error] 198#198: *4 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-01-27 21:50:29.506906415  2025/01/27 22:50:29 [error] 192#192: *6 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:29.509592337  2025/01/27 22:50:29 [error] 192#192: *6 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:32.623785873  2025/01/27 22:50:32 [error] 199#199: *8 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-01-27 21:50:32.624007575  2025/01/27 22:50:32 [error] 199#199: *8 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-01-27 21:50:34.474607226  2025/01/27 22:50:34 [error] 193#193: *10 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:34.475250813  2025/01/27 22:50:34 [error] 193#193: *10 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:37.713784956  [2025-01-27 22:50:37] frigate.app                    INFO    : Starting Frigate (0.14.1-f4f3cfa)
2025-01-27 21:50:37.714589041  [2025-01-27 22:50:37] frigate.app                    INFO    : Creating directory: /tmp/cache
2025-01-27 21:50:37.714600430  [2025-01-27 22:50:37] frigate.util.config            INFO    : Checking if frigate config needs migration...
2025-01-27 21:50:37.961440613  [2025-01-27 22:50:37] frigate.util.config            INFO    : frigate config does not need migration...
2025-01-27 21:50:39.725116443  2025/01/27 22:50:39 [error] 193#193: *12 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:39.725892029  2025/01/27 22:50:39 [error] 193#193: *12 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:41.162576981  [2025-01-27 22:50:41] frigate.util.services          WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2025-01-27 21:50:41.604819168  [2025-01-27 22:50:41] peewee_migrate.logs            INFO    : Starting migrations
2025-01-27 21:50:41.607174649  [2025-01-27 22:50:41] peewee_migrate.logs            INFO    : There is nothing to migrate
2025-01-27 21:50:41.727609765  [2025-01-27 22:50:41] frigate.app                    INFO    : Recording process started: 391
2025-01-27 21:50:41.746293608  [2025-01-27 22:50:41] frigate.app                    INFO    : Recording process started: 393
2025-01-27 21:50:41.791580783  [2025-01-27 22:50:41] frigate.app                    INFO    : go2rtc process pid: 99
2025-01-27 21:50:42.226688771  [2025-01-27 22:50:42] detector.cpu                   INFO    : Starting detection process: 421
2025-01-27 21:50:42.442021867  [2025-01-27 22:50:42] frigate.app                    INFO    : Output process started: 423
2025-01-27 21:50:42.470538738  [2025-01-27 22:50:42] frigate.detectors              WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
2025-01-27 21:50:43.399834533  [2025-01-27 22:50:42] frigate.app                    INFO    : Camera processor not started for disabled camera TapoC210
2025-01-27 21:50:43.403470632  [2025-01-27 22:50:42] frigate.app                    INFO    : Camera processor started for Piscine: 445
2025-01-27 21:50:43.403480928  [2025-01-27 22:50:42] frigate.app                    INFO    : Camera processor not started for disabled camera Spare173
2025-01-27 21:50:43.403484965  [2025-01-27 22:50:42] frigate.app                    INFO    : Camera processor not started for disabled camera Spare162
2025-01-27 21:50:43.403499835  [2025-01-27 22:50:43] frigate.app                    INFO    : Camera processor started for Garage: 446
2025-01-27 21:50:43.403504095  [2025-01-27 22:50:43] frigate.app                    INFO    : Capture process not started for disabled camera TapoC210
2025-01-27 21:50:43.483996010  [2025-01-27 22:50:43] frigate.app                    INFO    : Capture process started for Piscine: 457
2025-01-27 21:50:43.488435269  [2025-01-27 22:50:43] frigate.app                    INFO    : Capture process not started for disabled camera Spare173
2025-01-27 21:50:43.488451251  [2025-01-27 22:50:43] frigate.app                    INFO    : Capture process not started for disabled camera Spare162
2025-01-27 21:50:43.500017542  [2025-01-27 22:50:43] frigate.app                    INFO    : Capture process started for Garage: 463
2025-01-27 21:50:45.324220014  2025/01/27 22:50:45 [error] 193#193: *14 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-01-27 21:50:45.325802723  2025/01/27 22:50:45 [error] 193#193: *14 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-01-27 21:50:46.740805008  2025/01/27 22:50:46 [error] 193#193: *16 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:46.744478310  2025/01/27 22:50:46 [error] 193#193: *16 auth request unexpected status: 502 while sending to client, client: 172.30.32.1, server: , request: "GET /api/stats HTTP/1.1", host: "ccab4aaf-frigate-fa:5000"
2025-01-27 21:50:53.864591271  172.30.32.2 - - [27/Jan/2025:22:50:53 +0100] "GET // HTTP/1.1" 200 2722 "http://192.168.1.87:8123/ccab4aaf_frigate-fa" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:54.258814623  172.30.32.2 - - [27/Jan/2025:22:50:54 +0100] "GET /fonts/Inter-Regular.woff2 HTTP/1.1" 200 108488 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns/assets/index-BsqM9WWT.css" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:54.262023078  172.30.32.2 - - [27/Jan/2025:22:50:54 +0100] "GET /api/config HTTP/1.1" 200 20040 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns//" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:54.610066929  172.30.32.2 - - [27/Jan/2025:22:50:54 +0100] "GET /api/profile HTTP/1.1" 200 18 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns//" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:54.808122412  172.30.32.2 - - [27/Jan/2025:22:50:54 +0100] "GET /api/review?limit=10&severity=alert HTTP/1.1" 200 3 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns//" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:55.060217144  172.30.32.2 - - [27/Jan/2025:22:50:55 +0100] "GET /api/Garage/latest.webp?h=290&cache=1738014654229 HTTP/1.1" 200 14430 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns//" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36" "192.168.1.54, 172.30.32.1"
2025-01-27 21:50:55.339383427  172.30.32.2 - - [27/Jan/2025:22:50:55 +0100] "GET /api/Garage/latest.webp?h=290&cache=1738014654618 HTTP/1.1" 200 14364 "http://192.168.1.87:8123/api/hassio_ingress/xPLu2BoVFnFTY3EH4hahhvxarDPqQLhfbhF6aySYhns//" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0
Je me reponds à moi meme, apres un arret electrique complet frigate refonctionne correctement.
Je n’ai pas compris mais l’essentiel est le résultat
