Frigate refuse de se lancer. Les logs sont simples
frigate | 2024-10-25 18:41:19.192470744 [INFO] Starting Frigate...
frigate | s6-rc: info: service go2rtc-healthcheck successfully started
frigate | s6-rc: info: service nginx successfully started
frigate | s6-rc: info: service certsync: starting
frigate | s6-rc: info: service certsync successfully started
frigate | s6-rc: info: service legacy-services: starting
frigate | 2024-10-25 18:41:19.273430530 [INFO] Starting certsync...
frigate | s6-rc: info: service legacy-services successfully started
frigate | 2024-10-25 18:41:19.419843096 127.0.0.1 - - [25/Oct/2024:18:41:19 +0200] "" 400 0 "-" "-" "-"
frigate | 2024-10-25 18:41:19.685952061 [INFO] Starting go2rtc...
frigate | 2024-10-25 18:41:19.811843640 18:41:19.811 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
frigate | 2024-10-25 18:41:19.811865335 18:41:19.811 INF config path=/dev/shm/go2rtc.yaml
frigate | 2024-10-25 18:41:19.812297855 18:41:19.812 INF [api] listen addr=:1984
frigate | 2024-10-25 18:41:19.812472113 18:41:19.812 INF [rtsp] listen addr=:8554
frigate | 2024-10-25 18:41:19.812667659 18:41:19.812 INF [webrtc] listen addr=:8555/tcp
frigate | 2024-10-25 18:41:20.648109146 [2024-10-25 18:41:20] frigate.app INFO : Starting Frigate (0.14.1-f4f3cfa)
frigate | 2024-10-25 18:41:20.648218676 [2024-10-25 18:41:20] frigate.util.config INFO : Checking if frigate config needs migration...
frigate | 2024-10-25 18:41:20.701196134 [2024-10-25 18:41:20] frigate.util.config INFO : frigate config does not need migration...
frigate | 2024-10-25 18:41:20.770564237 [2024-10-25 18:41:20] peewee_migrate.logs INFO : Starting migrations
frigate | 2024-10-25 18:41:20.771315592 [2024-10-25 18:41:20] peewee_migrate.logs INFO : There is nothing to migrate
frigate | 2024-10-25 18:41:20.776234281 [2024-10-25 18:41:20] frigate.app INFO : Recording process started: 341
frigate | 2024-10-25 18:41:20.781587196 [2024-10-25 18:41:20] frigate.app INFO : Recording process started: 343
frigate | 2024-10-25 18:41:20.785491589 [2024-10-25 18:41:20] frigate.app INFO : go2rtc process pid: 96
frigate | 2024-10-25 18:41:20.815580492 [2024-10-25 18:41:20] detector.coral INFO : Starting detection process: 370
frigate | s6-rc: info: service legacy-services: stopping
frigate | s6-rc: info: service legacy-services successfully stopped
frigate | s6-rc: info: service go2rtc-healthcheck: stopping
frigate | s6-rc: info: service certsync: stopping
frigate | 2024-10-25 18:41:20.846305924 [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
frigate | s6-rc: info: service go2rtc-healthcheck successfully stopped
frigate | 2024-10-25 18:41:20.849147288 [INFO] Service CERTSYNC exited with code 256 (by signal 15)
et cela continue en stoppant tous les services. De tous les logs, aucun problème n’est affiché. docker container ls montre qu’il redémarre toutes les 70 secondes environ. Au cas ou, j’ai réinstallé un fichier config.yml sauvegardé et connu fonctionnel, pas d’amélioration. J’ai retiré le dongle coral, toujours le même état. J’ai au final redémarré le serveur, pas mieux.
Comment débugger le problème? Si une idée surgit, je suis prêt à la tester ![]()
Daniel
[center]## System Information
| version | core-2024.9.2 |
| installation_type | Home Assistant Container |
| dev | false |
| hassio | false |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.12.4 |
| os_name | Linux |
| os_version | 6.1.0-26-amd64 |
| arch | x86_64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| Installed Version | 2.0.1 |
| Stage | running |
| Available Repositories | 1520 |
| Downloaded Repositories | 6 |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| dashboards | 4 |
| resources | 4 |
| views | 2 |
| mode | storage |
| oldest_recorder_run | 15 octobre 2024 à 14:41 |
| current_recorder_run | 25 octobre 2024 à 18:29 |
| estimated_db_size | 112.70 MiB |
| database_engine | sqlite |
| database_version | 3.45.3 |
