J’essaye d’implanter le NVR Frigate sur mon application et malheureusement j’obtiens le message suivant montrant que la configuration n’est pas correcte. Quelqu’un peut-il me dire s’il a eu ce problème d’unicode et comment il a résolu ce dernier.
Mille mercis
LOG FRIGATE
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[2022-07-12 16:26:04] frigate.app INFO : Starting Frigate (0.10.1-83481af)
*** [color=#]Your config file is not valid![/color] ***
*** Please check the docs at ***
*** https://docs.frigate.video/configuration/index ***
*** Config Validation Errors ***
mapping values are not allowed here
in "<unicode string>", line 5, column 11:
ffmpeg:
File "/opt/frigate/frigate/app.py", line 312, in start
self.init_config()
File "/opt/frigate/frigate/app.py", line 77, in init_config
user_config = FrigateConfig.parse_file(config_file)
File "/opt/frigate/frigate/config.py", line 900, in parse_file
config = yaml.safe_load(raw_config)
File "/usr/local/lib/python3.8/dist-packages/yaml/__init__.py", line 162, in safe_load
return load(stream, SafeLoader)
File "/usr/local/lib/python3.8/dist-packages/yaml/__init__.py", line 114, in load
return loader.get_single_data()
File "/usr/local/lib/python3.8/dist-packages/yaml/constructor.py", line 49, in get_single_data
node = self.get_single_node()
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 36, in get_single_node
document = self.compose_document()
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 55, in compose_document
node = self.compose_node(None, None)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 84, in compose_node
node = self.compose_mapping_node(anchor)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 133, in compose_mapping_node
item_value = self.compose_node(node, item_key)
File "/usr/local/lib/python3.8/dist-packages/yaml/composer.py", line 127, in compose_mapping_node
while not self.check_event(MappingEndEvent):
File "/usr/local/lib/python3.8/dist-packages/yaml/parser.py", line 98, in check_event
self.current_event = self.state()
File "/usr/local/lib/python3.8/dist-packages/yaml/parser.py", line 428, in parse_block_mapping_key
if self.check_token(KeyToken):
File "/usr/local/lib/python3.8/dist-packages/yaml/scanner.py", line 116, in check_token
self.fetch_more_tokens()
File "/usr/local/lib/python3.8/dist-packages/yaml/scanner.py", line 223, in fetch_more_tokens
return self.fetch_value()
File "/usr/local/lib/python3.8/dist-packages/yaml/scanner.py", line 577, in fetch_value
raise ScannerError(None, None,
yaml.scanner.ScannerError: mapping values are not allowed here
ffmpeg:
*** End Config Validation Errors ***
[cmd] python3 exited 1
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
