Les catégories à « tracker » ne remontent pas
Contrairement à l’image ci-dessous, les catégories n’apparaissent pas alors qu’elles sont renseignées dans frigate.yml
http://]https://community-assets.home-assistant.io/original/3X/e/b/ebf6dfcdeb2e418e0b4915388582d76ebab55a5a.jpeg
Voici mon fichier de config :
mqtt:
enabled: False
cameras:
Front:
ffmpeg:
inputs:
- path: rtsp://admin:***@192.168.1.13:554/stream1
roles:
- detect
- record
detect:
enabled: False
width: 1280
height: 720
objects:
track:
- person
- car
filters:
person:
min_score: 0.65
car:
min_score: 0.65
snapshots:
enabled: True
record:
enabled: True
retain:
days: 7
events:
retain:
default: 14
motion:
mask:
- 171,231,0,113,0,720,0,720
Est ce que quelqu’un verrait d’ou le problème pourrait venir ?
merci d’avance
version |
core-2024.3.1 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.6.20-haos |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1406 |
Downloaded Repositories |
10 |
HACS Data |
ok |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 12.1 |
update_channel |
stable |
supervisor_version |
supervisor-2024.03.0 |
agent_version |
1.6.0 |
docker_version |
24.0.7 |
disk_total |
30.8 GB |
disk_used |
7.6 GB |
healthy |
true |
supported |
true |
board |
ova |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.8.0), Terminal & SSH (9.10.0), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.0-1), Samba share (12.3.1), Frigate (0.13.2) |
dashboards |
1 |
resources |
2 |
views |
5 |
mode |
storage |
oldest_recorder_run |
13 mars 2024 à 13:44 |
current_recorder_run |
15 mars 2024 à 17:52 |
estimated_db_size |
5.18 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
Il faut renseigner la partie mqtt.
Édit : c’est quoi cette ligne enabled:false sous detect , elle serait plus utile à true ?
merci !
j’avais recopié une config avec ces paramètres
effectivement, ca s’est mis a bosser en changeant False à True
