Frigate pas de flux
Dans le module complémentaire Frigate, je n’arrive pas a avoir le flux de la caméra. C’est une camera Ezviz, dont le flux est récupérable sur VLC sans problème avec comme url :
rtsp://admin:XXXX@192.168.0.XXX:554/ch1/sub. Pourriez vous me dire où se situe le problème.
Les logs sont les suivants
2025-03-23 18:16:36.296123530  [2025-03-23 19:16:36] watchdog.cam_salon             ERROR   : Ffmpeg process crashed unexpectedly for cam_salon.
2025-03-23 18:16:36.296456172  [2025-03-23 19:16:36] watchdog.cam_salon             ERROR   : The following ffmpeg logs include the last 100 lines prior to exit.
2025-03-23 18:16:36.296697458  [2025-03-23 19:16:36] ffmpeg.cam_salon.detect        ERROR   : [rtsp @ 0x55b2a7b43580] method DESCRIBE failed: 401 Unauthorized
2025-03-23 18:16:36.296937226  [2025-03-23 19:16:36] ffmpeg.cam_salon.detect        ERROR   : [in#0 @ 0x55b2a7b43240] Error opening input: Server returned 401 Unauthorized (authorization failed)
2025-03-23 18:16:36.297195235  [2025-03-23 19:16:36] ffmpeg.cam_salon.detect        ERROR   : Error opening input file rtsp://*:*@192.168.0.XXX:554/ch1/sub.
2025-03-23 18:16:36.297376252  [2025-03-23 19:16:36] ffmpeg.cam_salon.detect        ERROR   : Error opening input files: Server returned 401 Unauthorized (authorization failed)
2025-03-23 18:16:36.374486897  [2025-03-23 19:16:36] frigate.video                  ERROR   : cam_salon: Unable to read frames from ffmpeg process.
2025-03-23 18:16:36.374752751  [2025-03-23 19:16:36] frigate.video                  ERROR   : cam_salon: ffmpeg process is not running. exiting capture thread...
2025-03-23 18:16:46.317468218  [2025-03-23 19:16:46] watchdog.cam_salon             ERROR
Je joins le fichier de configuration ci dessous
mqtt:
  enabled: true
  host: mqtt://192.168.0.xx
  user: mqtt_adm
  password: 'xxxxxt'
  port: 1883
cameras:
  cam_salon:
    ffmpeg:
      inputs:
        - path: rtsp://admin:XXXX@192.168.0.XX:554/ch1/sub
          roles:
            - detect
            - record
    detect:
      enabled: true
      width: 640
      height: 480
record:
  enabled: true
  retain:
    days: 1
    mode: motion
  alerts:
    retain:
      days: 14
  detections:
    retain:
      days: 14
snapshots:
  enabled: true
  retain:
    default: 8
objects:
  track:
    - person
logger:
  default: info
  logs:
    frigate.detectors: debug
    frigate.video: debug
version: 0.15-1
camera_groups:
  Camera_RDC:
    order: 1
    icon: LuCamera
    cameras: cam_salon
