J’aimerai gérer le volume de mes anciennes enceintes qui sont en jack. Enfaite j’aimerai pouvoir contrôler le volume manuellement via un bouton rotatif et bien sur par HA. Si vous avez un boitier qui fait ça je suis preneur et j’aimerai qu’il soit en zigbee.
version |
core-2025.5.3 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.13.3 |
os_name |
Linux |
os_version |
6.6.74-haos-raspi |
arch |
aarch64 |
timezone |
Europe/Brussels |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
HACS Data |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
2.0.5 |
Stage |
running |
Available Repositories |
1996 |
Downloaded Repositories |
3 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 15.2 |
update_channel |
stable |
supervisor_version |
supervisor-2025.05.3 |
agent_version |
1.7.2 |
docker_version |
28.0.4 |
disk_total |
28.5 GB |
disk_used |
6.4 GB |
healthy |
true |
supported |
true |
host_connectivity |
true |
supervisor_connectivity |
true |
ntp_synchronized |
true |
virtualization |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Studio Code Server (5.19.3), Mosquitto broker (6.5.1), Zigbee2MQTT (2.3.0-1), File editor (5.8.0), Cloudflared (5.3.2), Advanced SSH & Web Terminal (20.0.2) |
dashboards |
3 |
resources |
1 |
views |
5 |
mode |
storage |
Network Configuration
adapters |
lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), veth2f1ecb4 (disabled), vethe3593ef (disabled), veth418038b (disabled), vethc09f4ab (disabled), vethab97dfe (disabled), vethab6ab91 (disabled), vethc45797e (disabled), veth3bb7c83 (disabled), veth6c66911 (disabled), veth52af07b (disabled), veth8c962aa (disabled) |
ipv4_addresses |
lo (127.0.0.1/8), end0 (192.168.129.136/23), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), veth2f1ecb4 (), vethe3593ef (), veth418038b (), vethc09f4ab (), vethab97dfe (), vethab6ab91 (), vethc45797e (), veth3bb7c83 (), veth6c66911 (), veth52af07b (), veth8c962aa () |
ipv6_addresses |
lo (::1/128), end0 (2a02:a03f:c1cc:c701:b62c:fe9a:c18d:d6ca/64, fe80::d3e2:15c0:8084:cce2/64), hassio (fe80::a8d4:3fff:fe71:2467/64), docker0 (fe80::68dd:14ff:fe82:2e62/64), veth2f1ecb4 (fe80::9c61:3cff:fecc:f872/64), vethe3593ef (fe80::6852:43ff:feb2:5d70/64), veth418038b (fe80::1434:f0ff:feba:266f/64), vethc09f4ab (fe80::acbf:9fff:fe55:6d0b/64), vethab97dfe (fe80::4f8:a7ff:feba:3f5a/64), vethab6ab91 (fe80::e41e:4ff:fed4:fe25/64), vethc45797e (fe80::b4e7:10ff:fe93:486c/64), veth3bb7c83 (fe80::34b3:7fff:fe89:b22b/64), veth6c66911 (fe80::f0fe:aff:fe21:b692/64), veth52af07b (fe80::d085:2eff:fe14:8ef7/64), veth8c962aa (fe80::70a6:14ff:fe0f:728f/64) |
announce_addresses |
192.168.129.136, 2a02:a03f:c1cc:c701:b62c:fe9a:c18d:d6ca, fe80::d3e2:15c0:8084:cce2 |
oldest_recorder_run |
21 mai 2025 à 16:00 |
current_recorder_run |
30 mai 2025 à 14:52 |
estimated_db_size |
6.70 MiB |
database_engine |
sqlite |
database_version |
3.48.0 |
