J’ai installé Glances et j’ai cette erreur qui est apparu ce matin suite à un reboot. avez vous des idées pour investiguer… ?
Add-on: Glances
A cross-platform system monitoring tool
Add-on version: 0.21.0
You are running the latest version of this add-on.
System: Debian GNU/Linux 12 (bookworm) (amd64 / qemux86-64)
Home Assistant Core: 2024.3.0
Home Assistant Supervisor: 2024.02.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
INFO: Starting Glances...
INFO: Starting NGinx...
2024-03-07 10:22:54,882 -- INFO -- Start Glances 3.4.0.3
2024-03-07 10:22:54,882 -- INFO -- CPython 3.11.6 (/usr/bin/python3) and psutil 5.9.7 detected
2024-03-07 10:22:54,892 -- INFO -- Read configuration file '/etc/glances.conf'
2024-03-07 10:22:54,995 -- INFO -- Start GlancesWebServer mode
2024-03-07 10:22:56,475 -- WARNING -- Error loading Podman deps Lib. Podman feature in the Containers plugin is disabled (No module named 'podman')
2024-03-07 10:22:56,494 -- WARNING -- Missing Python Lib (No module named 'pySMART'), HDD Smart plugin is disabled
2024-03-07 10:22:56,531 -- WARNING -- Sparklines module not found (No module named 'sparklines')
2024-03-07 10:22:56,538 -- WARNING -- Missing Python Lib (No module named 'pymdstat'), Raid plugin is disabled
2024-03-07 10:22:56,565 -- WARNING -- Missing Python Lib (No module named 'wifi'), Wifi plugin is disabled
2024-03-07 10:22:56,566 -- WARNING -- Wifi lib is not compliant with Python 3, Wifi plugin is disabled
2024-03-07 10:22:56,568 -- WARNING -- Missing Python Lib (No module named 'py3nvml'), Nvidia GPU plugin is disabled
2024-03-07 10:22:58,223 -- INFO -- Glances RESTful API Server started on http://127.0.0.1:61209/api/3/
2024-03-07 10:22:58,227 -- INFO -- Glances Web User Interface started on http://127.0.0.1:61209/
Error: Can not ran Glances Web server ([Errno 98] Address in use)
2024-03-07 10:22:58,268 -- CRITICAL -- Error: Can not ran Glances Web server ([Errno 98] Address in use)
[center]## System Information
version |
core-2024.3.0 |
installation_type |
Home Assistant Supervised |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.12.2 |
os_name |
Linux |
os_version |
6.1.0-13-amd64 |
arch |
x86_64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
4999 |
Installed Version |
1.34.0 |
Stage |
running |
Available Repositories |
1401 |
Downloaded Repositories |
17 |
logged_in |
false |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Debian GNU/Linux 12 (bookworm) |
update_channel |
stable |
supervisor_version |
supervisor-2024.02.1 |
agent_version |
1.6.0 |
docker_version |
24.0.7 |
disk_total |
456.4 GB |
disk_used |
27.0 GB |
healthy |
true |
supported |
failed to load: Unsupported |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
File editor (5.8.0), Duck DNS (1.15.0), ESPHome (2024.2.2), Home Assistant Google Drive Backup (0.112.1), Let’s Encrypt (5.0.15), Log Viewer (0.17.0), Mosquitto broker (6.4.0), NGINX Home Assistant SSL proxy (3.8.0), Samba share (12.3.0), Studio Code Server (5.15.0), TasmoAdmin (0.29.1), Glances (0.21.0), InfluxDB (5.0.0), Advanced SSH & Web Terminal (17.1.1), Z-Wave JS (0.4.5), Grafana (9.1.3), Zigbee2MQTT (1.36.0-1), Whisper (1.0.2) |
dashboards |
6 |
resources |
7 |
views |
11 |
mode |
storage |
MiWifi
version |
3.0.0 |
192.168.1.10 (xiaomi.router.rm2100) |
ok |
oldest_recorder_run |
February 27, 2024 at 16:08 |
current_recorder_run |
March 7, 2024 at 09:13 |
estimated_db_size |
446.95 MiB |
database_engine |
sqlite |
database_version |
3.44.2 |
[/center]
Salut à tous,
Bon j’ai trouvé j’avais bien un conflit de port. Tout est rentré dans l’ordre
