2023-01-25 07:37:51.519 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-25 07:37:51.520 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-25 07:37:51.521 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration daikin_residential which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-25 07:37:53.568 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-01-25 07:37:53.616 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=48 from 2023-01-24 20:07:43.144317)
2023-01-25 07:37:55.159 WARNING (MainThread) [homeassistant.components.ssdp] Could not set up UPnP/SSDP server, as a presentation URL could not be determined; Please configure your internal URL in the Home Assistant general configuration
2023-01-25 07:38:03.279 WARNING (MainThread) [custom_components.govee] API is back online.
2023-01-25 07:38:03.363 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Split Séjour' for daikin integration not ready yet: Server disconnected; Retrying in background
2023-01-25 07:38:13.299 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Portail' for homekit_controller integration not ready yet: Timeout while waiting for connection to device 192.168.1.48:80; Retrying in background
2023-01-25 07:38:14.520 ERROR (MainThread) [pyhap.characteristic] SecuritySystemCurrentState: value=0 is an invalid value.
2023-01-25 07:38:14.527 ERROR (MainThread) [pyhap.characteristic] SecuritySystemTargetState: value=0 is an invalid value.
2023-01-25 07:38:14.528 ERROR (MainThread) [pyhap.characteristic] SecuritySystemCurrentState: value=0 is an invalid value.
2023-01-25 07:38:14.529 ERROR (MainThread) [pyhap.characteristic] SecuritySystemTargetState: value=0 is an invalid value.
2023-01-24 21:07:41.262 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-24 21:07:41.265 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-24 21:07:41.266 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration daikin_residential which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-01-24 21:07:43.412 WARNING (MainThread) [zeroconf] Address not available when binding to ('fe80::9eaf:5e84:4a3d:34d3', 5353, 0, 2), it is expected to happen on some systems
2023-01-24 21:07:43.821 WARNING (MainThread) [homeassistant.components.ssdp] Could not set up UPnP/SSDP server, as a presentation URL could not be determined; Please configure your internal URL in the Home Assistant general configuration
2023-01-24 21:07:55.748 WARNING (zeroconf-ServiceBrowser-_googlecast._tcp-101) [pychromecast.dial] Failed to determine cast type for host <unknown> (HTTP Error 403: Forbidden) (services:{ServiceInfo(type='mdns', data='Freebox-Player-POP-075cf0510e1cdff300dba8fa715c4dd7._googlecast._tcp.local.')})
2023-01-24 21:07:55.786 ERROR (Thread-7) [pychromecast.socket_client] [Salon(075cf051-0e1c-dff3-00db-a8fa715c4dd7.local.):8009] Failed to connect to service ServiceInfo(type='mdns', data='Freebox-Player-POP-075cf0510e1cdff300dba8fa715c4dd7._googlecast._tcp.local.'), retrying in 5.0s
2023-01-24 21:07:59.106 ERROR (MainThread) [pyhap.characteristic] SecuritySystemCurrentState: value=0 is an invalid value.
2023-01-24 21:07:59.124 ERROR (MainThread) [pyhap.characteristic] SecuritySystemTargetState: value=0 is an invalid value.
2023-01-24 21:07:59.124 ERROR (MainThread) [pyhap.characteristic] SecuritySystemCurrentState: value=0 is an invalid value.
2023-01-24 21:07:59.131 ERROR (MainThread) [pyhap.characteristic] SecuritySystemTargetState: value=0 is an invalid value.
2023-01-24 21:14:17.228 ERROR (MainThread) [frontend.js.latest.202301100] :0:0 ResizeObserver loop completed with undelivered notifications.
2023-01-24 21:16:01.119 WARNING (MainThread) [custom_components.govee] API is back online.
2023-01-24 21:18:03.405 ERROR (MainThread) [frontend.js.latest.202301100] :0:0 ResizeObserver loop completed with undelivered notifications.
2023-01-24 21:24:56.553 ERROR (MainThread) [frontend.js.latest.202301100] :0:0 Script error.```
ta bande lumineuse n’est pas connectee au wifi…
Connectes ton tel au wifi de la maison ensuite va dans govee > ta lampe > propriete (la roue crantée en haut) et connectes la au wifi.
Normalement tu devrais la retrouver
Je pense que la réponse de @Pulpy-Luke est clair: l’intégration Govee ne supporte pas les appareils H613A. Il faut faire une demande sur le git de l’intégration.
