GRDF: Gazpar_2_MQTT
Avec STANDANLONE mode à False, j’ai:
2024-05-06 19:54:25,050 INFO 1 PCE found !
2024-05-06 19:54:25,053 INFO ---------------------------------
2024-05-06 19:54:25,053 INFO Get measures of PCE ********** alias Maison
2024-05-06 19:54:25,053 INFO Range period : from 2021-05-06 (3 years ago) to 2024-05-06 (today) ...
2024-05-06 19:54:25,053 INFO Retrieve informative measures...
2024-05-06 19:54:25,626 INFO Informative measures found !
2024-05-06 19:54:25,626 INFO Analysis of informative measures provided by GRDF...
2024-05-06 19:54:25,626 INFO 919 informative measures provided by Grdf
2024-05-06 19:54:25,627 INFO 647 informative measures are ok
2024-05-06 19:54:25,627 INFO Accuracy is 70 percent
2024-05-06 19:54:25,627 INFO Last valid informative measure provided by GRDF :
2024-05-06 19:54:25,627 INFO Date = 2024-04-24
2024-05-06 19:54:25,627 INFO Start index = 4979, End index = 4983
2024-05-06 19:54:25,627 INFO Volume = 4 m3, Energy = 41 kWh, Factor = 11.06118
2024-05-06 19:54:25,627 INFO ---------------
2024-05-06 19:54:25,627 INFO Retrieve published measures...
2024-05-06 19:54:25,833 INFO Published measures found !
2024-05-06 19:54:25,834 INFO Analysis of published measures provided by GRDF...
2024-05-06 19:54:25,834 INFO 58 published measures provided by Grdf
2024-05-06 19:54:25,834 INFO 0 published measures are ok
2024-05-06 19:54:25,834 INFO Accuracy is 0 percent
2024-05-06 19:54:25,835 WARNING Unable to find the last published measure.
2024-05-06 19:54:25,835 INFO ---------------
2024-05-06 19:54:25,835 INFO Update of database with retrieved measures...
2024-05-06 19:54:25,849 INFO Database updated !
2024-05-06 19:54:25,849 INFO ---------------
2024-05-06 19:54:25,849 INFO Retrieve PCE's thresholds from GRDF...
2024-05-06 19:54:26,108 INFO 0 thresholds found !
2024-05-06 19:54:26,112 INFO -----------------------------------------------------------
2024-05-06 19:54:26,112 INFO #                    Load prices                           #
2024-05-06 19:54:26,112 INFO Loading prices from file prices.csv of directory /data
2024-05-06 19:54:26,112 WARNING Unable to find price file prices.csv in directory /data
2024-05-06 19:54:26,112 INFO #           Stand alone publication mode                  #
2024-05-06 19:54:26,113 INFO Publishing values of PCE *-************ alias Maison...
2024-05-06 19:54:26,113 INFO ---------------------------------
2024-05-06 19:54:26,113 INFO You can retrieve published values subscribing topic gazpar/05540376180642/#
2024-05-06 19:54:26,113 INFO Publishing to Mqtt...
2024-05-06 19:54:27,118 WARNING Unable to publish last measure infos.
presque la même chose.
Mais dans MQTT sous HA j’ai pleins de rolling qui arrivent en continue
trop compliqué pour moi. Je n’ai pas les noms de HASS_etc…
Je ne peux rien faire avec que une partie des logs. Ce que je voix : c’est bon
      HASS_DISCOVERY: 'True'
      HASS_PREFIX: 'homeassistant'
      HASS_DEVICE_NAME: 'gazpar'
J’ai revu l’erreur et c’est pas un erreur en realité … hérité de l’ancien gazpar2mqtt… je vais faire une solution prochainement.
De ma côté pour « standalone »…le docker-compose marche nickel…j’ai tout dans mon mqtt sans boucle ou sorte
un grand merci. Ca fonctionne. Par contre j’ai lu que la mise à jour se faisait une fois par jour alors que dans les log de mon docker ca boucle à l’infini. il y a une manipulation à faire?
Je ne comprends pas ce ‹ boucle ›. Si t’as défini p.e.
SCHEDULE_TIME: '06:30'
ça devrat terminer dans le log avec une ligne qui montre cette heure
Si pas défini, ça termine aussi sans indication de relancement vers une heure
"End of gazpar2mqtt. See u..."
je n’ai pas défini de SCHEDULE TIME/
j’ai bien le See u… et ca recommence!
2024-05-07 15:25:52,351 INFO -----------------------------------------------------------
2024-05-07 15:25:52,351 INFO No schedule defined.
2024-05-07 15:25:52,351 INFO #                  End of program                         #
2024-05-07 15:25:52,352 INFO -----------------------------------------------------------
2024-05-07 15:25:52,352 INFO End of gazpar2mqtt. See u...
Using '/app' as APP directory
Copying default app/*.py files to app (except param.py)...
2024-05-07 15:25:53,367 INFO -----------------------------------------------------------
2024-05-07 15:25:53,367 INFO #               Welcome to gazpar2mqtt                    #
2024-05-07 15:25:53,367 INFO Program version : 0.4.0
2024-05-07 15:25:53,367 INFO Database version : 0.2.0
2024-05-07 15:25:53,367 INFO Influxdb version : 0.1.0
2024-05-07 15:25:53,367 INFO Please note that the the tool is under development, various functions may disappear or be modified.
2024-05-07 15:25:53,367 INFO #                Program parameters                       #
2024-05-07 15:25:53,367 INFO GRDF config : username = ******@****.**, password = ******
Et cela en boucle tant que le docker tourne.
Jamais vu ça …curieux… je ne sais même pas ou commencer :roll_eyes:
Je te propose d’utiliser télécharger l’image 0.5.0 (crée aujourd’hui) et re-essayer.
Je viens de supprimer toutes mes images docker correspondantes et réinstaller. Ca marche. Merci beaucoup. Par contre, je ne sais pas quelle image est installée.
Petite question, dans energie de Home assistant, il faut mettre quelle sensor dans Configurer la consommation de gaz?
Merci.
Sentiments mélangés …heureux que ça marche mais bien moins heureux parceque je ne le comprends pas…à oublier :slight_smile:
Pour les maj je suis encore en mode d’apprendre. 0.5.0 est l’image ‹ latest › mais si on a déjà une autre ‹ latest › local et on a ‹ latest › dans docker-compose, le maj ne fonctionne pas, donc mieux d’utiliser le numero… je m’en ocuppe
Pour HA stats
Output fr FR · vingerha/gazpar_2_mqtt Wiki (github.com)
Bonsoir, je suis intéressé également pour installer cet add-on, mais sur mon compte GRDF je n’ai plus de remontées du gazpar depuis fin avril, est ce pareil chez vous ? Ce n’est pas la peine que j’essaie l’add-on tant que le soucis n’est pas résolu chez GRDF…
Voir ici pour GRrrrrrrrDF
GRDF/gazpar de nouveau sans captcha: gazpar_2_mqtt - Entraide Home Assistant - Home Assistant Communauté Francophone (hacf.fr)
Je n’y comprends rien: il y a tant de capteurs.
Il faut mettre quoi pour pouvoir suivre sa consommation journalière?
La plupart de mes capteurs ne passent pas et j’ai:
Dernière réinitialisation manquante
Les entités suivantes ont la classe d’état ‹ measurement › mais ‹ last_reset › est manquant
Merci.
C’est dans la doc si-dessus… long term statistics pour dashboard Energie
Oui et non…oui: pour l’installation et voir des données antérieur … j’attend que grdf va ressoudre ça prochainement…mais bon, je me rappelle qqc d’Enedis qui a pris app 2 mois.
Avec l’aide de chercheur / philippe : trouvé…je vais relancer une maj qui va aussi adresser le nom des sensors (doubleeurs maintenant) et les device_class erreurs…dans la journée j’espère
J’ai essayé les trois lignes
HASS_LTS: « True »
HASS_LTS_TOKEN: 98724kjhawelkj…etc.
HASS_LTS_HOST: http://192.168.x.y:8123
avec et sans «  » pour le Token avec l’adresse locale avec l’adresse https de mon serveur et à chaque fois j’ai:
INFO Connection to WebSocket Home Assistant ws://192.168.1.76:8123/api/websocket
gazpar_2_mqtt | 2024-05-08 10:33:39,648 ERROR Connection to remote host was lost.
gazpar_2_mqtt | 2024-05-08 10:33:39,648 CRITICAL Connection to Websocket Home Assistant failed
gazpar_2_mqtt | 2024-05-08 10:33:39,648 WARNING => WARNING, the WebSocket will be banned after multiple unsuccesful login attempts.
J’attend que t’as utilisé ton propre Long Term Access token?
