Je m’étonne, que depuis que j’ai installé le module complémentaire, j’ai toujours le même index depuis trois jours ? Je ne sais pas si c’est normal ?
voici le log:
2024-05-10 15:00:27,185 INFO 1 PCE found !
2024-05-10 15:00:27,195 INFO ---------------------------------
2024-05-10 15:00:27,195 INFO Get measures of PCE xxxxxxxxxxxxxxxx alias xxxxxxxxxxxxxxxx
2024-05-10 15:00:27,196 INFO Range period : from 2021-05-10 (3 years ago) to 2024-05-10 (today) ...
2024-05-10 15:00:27,196 INFO Range period : from 2021-05-10 (self defined) to 2024-05-10 (today) ...
2024-05-10 15:00:27,196 INFO ---------------
2024-05-10 15:00:27,196 INFO Retrieve informative measures...
2024-05-10 15:00:28,072 INFO Informative measures found !
2024-05-10 15:00:28,072 INFO Analysis of informative measures provided by GRDF...
2024-05-10 15:00:28,072 INFO 1082 informative measures provided by Grdf
2024-05-10 15:00:28,073 INFO 1078 informative measures are ok
2024-05-10 15:00:28,073 INFO Accuracy is 100 percent
2024-05-10 15:00:28,073 INFO Last valid informative measure provided by GRDF :
2024-05-10 15:00:28,073 INFO Date = 2024-04-24
2024-05-10 15:00:28,073 INFO Start index = 5469, End index = 5474
2024-05-10 15:00:28,073 INFO Volume = 5 m3, Energy = 56 kWh, Factor = 11.27482
2024-05-10 15:00:28,073 WARNING Inconsistencies detected on the measure :
2024-05-10 15:00:28,073 WARNING Volume provided by Grdf (None m3) has been replaced by the volume between start index and end index (5 m3)
2024-05-10 15:00:28,073 INFO ---------------
2024-05-10 15:00:28,073 INFO Retrieve published measures...
2024-05-10 15:00:28,269 INFO Published measures found !
2024-05-10 15:00:28,270 INFO Analysis of published measures provided by GRDF...
2024-05-10 15:00:28,270 INFO 70 published measures provided by Grdf
2024-05-10 15:00:28,270 INFO 70 published measures are ok
2024-05-10 15:00:28,270 INFO Accuracy is 100 percent
2024-05-10 15:00:28,270 INFO Last valid published measure provided by GRDF :
2024-05-10 15:00:28,270 INFO Start date = 2024-04-01 06:00:00, End date = 2024-04-09 06:00:00
2024-05-10 15:00:28,270 INFO Start index = 5417, End index = 5434
2024-05-10 15:00:28,270 INFO Volume = 17 m3, Energy = 187 kWh, Factor = 11.01
2024-05-10 15:00:28,270 WARNING Inconsistencies detected on the measure :
2024-05-10 15:00:28,270 WARNING Volume provided by Grdf (None m3) has been replaced by the volume between start index and end index (17 m3)
2024-05-10 15:00:28,270 INFO ---------------
2024-05-10 15:00:28,270 INFO Update of database with retrieved measures...
2024-05-10 15:00:28,290 INFO Database updated !
2024-05-10 15:00:28,290 INFO ---------------
2024-05-10 15:00:28,290 INFO Retrieve PCE's thresholds from GRDF...
2024-05-10 15:00:28,639 INFO 0 thresholds found !
2024-05-10 15:00:28,648 INFO -----------------------------------------------------------
2024-05-10 15:00:28,649 INFO # Load prices #
2024-05-10 15:00:28,649 INFO -----------------------------------------------------------
2024-05-10 15:00:28,649 INFO Loading prices from file prices.csv of directory /data
2024-05-10 15:00:28,649 WARNING Unable to find price file prices.csv in directory /data
2024-05-10 15:00:28,649 INFO # Home assistant publication mode #
2024-05-10 15:00:28,650 INFO Publishing values of PCE xxxxxxxxxxxxxxxx alias xxxxxxxxxxxxxxxx...
2024-05-10 15:00:28,650 INFO ---------------------------------
2024-05-10 15:00:28,652 INFO Publishing devices...
2024-05-10 15:00:28,652 INFO You can retrieve published values subscribing topic homeassistant/+/gazpar_xxxxxxxxxxxxxxxx/#
2024-05-10 15:00:46,494 INFO Devices published !
2024-05-10 15:00:46,494 INFO -----------------------------------------------------------
2024-05-10 15:00:46,495 INFO # Disconnexion from MQTT #
2024-05-10 15:00:46,495 INFO -----------------------------------------------------------
2024-05-10 15:00:47,303 INFO Mqtt broker disconnected
2024-05-10 15:00:47,353 INFO -----------------------------------------------------------
2024-05-10 15:00:47,354 INFO # Disconnexion from SQLite database #
2024-05-10 15:00:47,354 INFO -----------------------------------------------------------
2024-05-10 15:00:47,354 INFO SQLite database disconnected
2024-05-10 15:00:47,354 INFO # Next run #
2024-05-10 15:00:47,354 INFO gazpar2mqtt next run scheduled at 06:30
2024-05-10 15:00:47,354 INFO # End of program #
