Bonjour a tous,
Mon problème est le suivant, j’ai créé un nom de domaine dans OVH
puis effectué les déclarations dans Cloudflared
puis installation du module complémentaire Cloudflared
et déclaration dans configuration.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
après cette configuration faite
j’accède avec http://xxxxxxxxx.ovh a mon HA
en revanche le problème est quand je veux configurer let’s Encrypt pour sécurisé mon accès, j’obtiens un message erreur dans la log.
Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these problems:
Domain: xxxxxxxx.ovh
Type: unauthorized
Detail: 2606:4700:3037::6815:4219: Invalid response from http://xxxxxxxx.ovh/.well-known/acme-challenge/dt0PDPZWkG5xefB0DfMeDVh2dFONV0adnG6AXkRu8lA: 404
Hint: The Certificate Authority failed to download the challenge files from the temporary standalone webserver started by Certbot on port 80. Ensure that the listed domains point to this machine and that it can accept inbound connections from the internet.
Some challenges have failed.
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
## System Information
version | core-2025.3.3
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.13.2
os_name | Linux
os_version | 6.12.18-haos
arch | aarch64
timezone | Europe/Paris
config_dir | /config
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
Installed Version | 2.0.5
Stage | running
Available Repositories | 1621
Downloaded Repositories | 1
</details>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
host_os | Home Assistant OS 15.0
update_channel | stable
supervisor_version | supervisor-2025.03.3
agent_version | 1.7.2
docker_version | 28.0.1
disk_total | 28.0 GB
disk_used | 12.8 GB
healthy | true
supported | true
host_connectivity | true
ntp_synchronized | true
virtualization |
board | green
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.8.0), Terminal & SSH (9.16.0), Get HACS (1.3.1), Node-RED (19.0.2), Samba share (12.5.0), ZeroTier One (0.20.0), ESPHome Device Builder (2025.3.2), Cloudflared (5.2.11), Let's Encrypt (5.4.4), Voltalis Bridge (1.4.1)
</details>
dashboards | 3
resources | 0
views | 8
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), end0 (enabled, default, auto), hassio (disabled), docker0 (disabled), ztfp6pjelb (disabled), vethb09ca67 (disabled), veth098c8f1 (disabled), vethfc28cd0 (disabled), veth60ce1f8 (disabled), veth4b352b1 (disabled), veth33d1b54 (disabled), vethcd81cf7 (disabled), veth7a9bc01 (disabled), vethfd265cc (disabled)
ipv4_addresses | lo (127.0.0.1/8), end0 (192.168.1.144/24), hassio (172.30.32.1/23), docker0 (172.30.232.1/23), ztfp6pjelb (192.168.192.147/24), vethb09ca67 (), veth098c8f1 (), vethfc28cd0 (), veth60ce1f8 (), veth4b352b1 (), veth33d1b54 (), vethcd81cf7 (), veth7a9bc01 (), vethfd265cc ()
ipv6_addresses | lo (::1/128), end0 (2001:861:110:1940:fec9:42b2:b451:fe8d/64, fe80::43c9:902c:c110:fa13/64), hassio (fe80::9c3a:7dff:fe15:6c72/64), docker0 (fe80::e4bd:c7ff:fe28:f1be/64), ztfp6pjelb (fe80::2c70:e2ff:fe7f:ace/64), vethb09ca67 (fe80::b8e9:5cff:fecf:63cd/64), veth098c8f1 (fe80::c004:67ff:fe55:6667/64), vethfc28cd0 (fe80::94d5:6cff:fe20:ba9d/64), veth60ce1f8 (fe80::30e4:68ff:feb3:56bf/64), veth4b352b1 (fe80::4c73:20ff:feff:d8fc/64), veth33d1b54 (fe80::b47e:7ff:fe81:e82d/64), vethcd81cf7 (fe80::6002:3eff:fe14:6296/64), veth7a9bc01 (fe80::60b8:21ff:fe2b:aa42/64), vethfd265cc (fe80::d860:5cff:fe00:47c4/64)
announce_addresses | 192.168.1.144, 2001:861:110:1940:fec9:42b2:b451:fe8d, fe80::43c9:902c:c110:fa13
</details>
oldest_recorder_run | 6 mars 2025 à 18:43
current_recorder_run | 28 mars 2025 à 12:21
estimated_db_size | 405.02 MiB
database_engine | sqlite
database_version | 3.48.0
</details>
