HA docker et HACS
merci pour le tuto. En revanche j’obtiens pas mal d’erreurs (quelque soit la méthode). J’utilise HACS et je me demande s’il n’est pas en cause. Qu’en pensez-vous ?
Quel type d’erreur ?
La sauvegarde avait bien été faite avec un HA docker ?
oui c’est bien une sauvegarde en docker.
Voici le type d’erreurs que j’obtiens :
2023-11-15 15:42:56.649 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2023-11-15 15:42:56.650 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2023-11-15 15:43:04.005 WARNING (MainThread) [androidtv.adb_manager.adb_manager_async] Couldn't connect to 192.168.50.19:5555.  TcpTimeoutException: Connecting to 192.168.50.19:5555 timed out (1.0 seconds)
2023-11-15 15:43:06.385 ERROR (MainThread) [homeassistant.components.climate] Error adding entities for domain climate with platform qubino_wire_pilot
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 507, in async_add_entities
    await asyncio.gather(*tasks)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 752, in _async_add_entity
    await entity.add_to_platform_finish()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in add_to_platform_finish
    self.async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 743, in async_write_ha_state
    self._async_write_ha_state()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 843, in _async_write_ha_state
    state, attr = self._async_generate_attributes()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 784, in _async_generate_attributes
    state = self._stringify_state(available)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 749, in _stringify_state
    if (state := self.state) is None:
  File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 261, in state
    return HVACMode(hvac_mode).value  # type: ignore[unreachable]
  File "/usr/local/lib/python3.11/enum.py", line 712, in __call__
    return cls.__new__(cls, value)
  File "/usr/local/lib/python3.11/enum.py", line 1135, in __new__
    raise ve_exc
ValueError: 'unknown' is not a valid HVACMode
2023-11-15 15:43:07.681 ERROR (MainThread) [homeassistant.components.climate] Error while setting up qubino_wire_pilot platform for climate
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 367, in _async_setup_platform
    await asyncio.gather(*pending)
    raise ve_exc
Les erreur Semblent lié au composant Climate mais la je ne sais pas trop :neutral_face:
HACS dans une installation docker ??!!
Parce que si c’est pas le cas, on est loin du sujet du début
Oui j’utilise HACS car je le trouve pratique pour l’ajout d’éléments lovelace. Effectivement, ce n’est pas le sujet mais je me suis demandé s’il pouvait être la cause de mes erreurs.
Ok, donc un nouveau sujet tout propre :wink:
Finalement ces erreur sont liées à un élément de mon installation mais en aucun cas à la restauration de la sauvegarde.
