Bonjour a tous,
Après avoir config DuckDNS pour un accès en htpps, je me suis lancé dans la config pour utilisé Alexa via se TUTO
Arrivé a la partie Tester notre fonction Lambda mon test sur amazon Dev j’ai des erreurs…
Une idée d’ou viens les erreurs ?
[center]## System Information
version |
core-2023.3.6 |
installation_type |
Home Assistant OS |
dev |
false |
hassio |
true |
docker |
true |
user |
root |
virtualenv |
false |
python_version |
3.10.10 |
os_name |
Linux |
os_version |
5.15.84-v8 |
arch |
aarch64 |
timezone |
Europe/Paris |
config_dir |
/config |
GitHub API |
ok |
GitHub Content |
ok |
GitHub Web |
ok |
GitHub API Calls Remaining |
5000 |
Installed Version |
1.31.0 |
Stage |
running |
Available Repositories |
1251 |
Downloaded Repositories |
30 |
logged_in |
true |
subscription_expiration |
1 janvier 2018 à 01:00 |
relayer_connected |
false |
remote_enabled |
true |
remote_connected |
false |
alexa_enabled |
true |
google_enabled |
false |
remote_server |
null |
can_reach_cert_server |
ok |
can_reach_cloud_auth |
ok |
can_reach_cloud |
ok |
host_os |
Home Assistant OS 9.5 |
update_channel |
stable |
supervisor_version |
supervisor-2023.03.2 |
agent_version |
1.4.1 |
docker_version |
20.10.22 |
disk_total |
116.5 GB |
disk_used |
9.4 GB |
healthy |
true |
supported |
true |
board |
rpi4-64 |
supervisor_api |
ok |
version_api |
ok |
installed_addons |
Terminal & SSH (9.6.1), SomfyProtect2MQTT (0.2.9), File editor (5.5.0), Mosquitto broker (6.1.3), Spotify Connect (0.12.3), Home Assistant Google Drive Backup (0.110.3), Duck DNS (1.15.0) |
dashboards |
1 |
resources |
17 |
views |
8 |
mode |
storage |
oldest_recorder_run |
16 mars 2023 à 12:44 |
current_recorder_run |
25 mars 2023 à 16:34 |
estimated_db_size |
163.32 MiB |
database_engine |
sqlite |
database_version |
3.38.5 |
Spotify
api_endpoint_reachable |
ok |
[/center]
une petite vidéo pour d’aidé
